Old 07-01-2013, 08:53 AM   #15
Admiral Ballsy
Shorter of breath
Admiral Ballsy's Avatar
Drives: a soft bargain
Originally Posted by suaveflooder View Post
You think the plugs will last 100k?
Subaru apparently doesn't, since the spec is 60K.
My experience with long-term use of platinums has been mixed. I had one car go to ~95K with no issues, but three others needed new plugs in the ~50K-60K area. So the factory spec is probably reasonable.
Admiral Ballsy is offline   Reply With Quote
Old 07-01-2013, 09:21 AM   #16
Bt216
Bt216's Avatar
Drives: Scion frs
Hopefully someone will make a diy kn this
Bt216 is offline   Reply With Quote
Old 07-01-2013, 09:35 AM   #17
retrosmiths
Drives: Scion FR-S Whiteout
Honest question. What happens if one of the 4 spark plugs went out? How will you feel/know it? An engine code? And what happens to the fuel that gets pumped there and not get burned?
-Sent from outer space
2013 Scion FR-S
retrosmiths is offline   Reply With Quote
Old 07-01-2013, 10:18 AM   #18
Admiral Ballsy
Shorter of breath
I've never had, nor heard of (in non-motorsports operation) a spark plug failure.
If one did, you'd definitely know it. You'd have tremendous vibration, lack of power, and CELs galore.
Spark plugs just wear out. Platinum, iridium, and other materials are used recently because they wear very very slowly - not because they're good conductors (which they aren't). Depending upon the design, though, they may not last as long as intended.
Some plugs use/used a little 'puck' of the material tack-welded to the cathode. AC/Delcos used to be made that way. And those little pucks tended to fall off, long before 100K, which didn't cause any failures, but resulted in incorrect gapping.
Regular old copper-conductor plugs are as good or better in terms of performance, all else equal. But they don't last anywhere near 100K, so automakers use platinum, et al so that they can 1) advertise really long tuneup intervals, and 2) design so that you can't change plugs without helluva work.
The Following User Says Thank You to Admiral Ballsy For This Useful Post:
ProjectD (07-02-2013)
Old 07-03-2013, 12:57 AM   #19
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
I haven't even got my car yet and I'm already dreading the day I will have to swap them out
hmong337 is offline   Reply With Quote
Spark plug removal? Changed your feelings for BRZ? BMWDavid Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 89 02-07-2015 09:46 AM
spark plugs subaruferrucci Engine, Exhaust, Transmission 22 04-10-2013 11:24 AM
NAV Install -Pulling VSS, Reverse and factory USB plug from HU 28 pin plug sikest Electronics | Audio | NAV | Infotainment 7 01-21-2013 09:38 PM
Spark plug type and heat ft86-UAE Engine, Exhaust, Transmission 4 06-10-2012 10:21 AM
Car won't start, no spark? #87 Other Vehicles & General Automotive Discussions 5 12-19-2011 12:29 PM
