Old 06-30-2013, 01:04 PM   #1
JDM FRS
JDM FRS's Avatar
Drives: Scion FRS(Whiteout)
throttle dip?
I have sort of dumb question. I have been driving MT cars for the past 10years and I ended up getting my FRS with AT(don't judge me lol) but anyways I have noticed that whenever I really jump on the throttle from a standstill that the RPM dips for a split second then takes off. It feels like it has no power at first and the tires barely even chirp(evenin sport mode with assists disabled.. Could this be the same issue that is fixed with the ECU reflash? Or is this normal for an automatic? Even in neutral/park when I rev I see the rpm dip before revving.
JDM FRS is offline   Reply With Quote
Old 06-30-2013, 01:19 PM   #2
FRiSson
Drives: FR-S MT
There does seem to be a momentary lag.
FRiSson is offline   Reply With Quote
Old 06-30-2013, 01:23 PM   #3
JDM FRS
JDM FRS's Avatar
Its happening on your stick too?
Old 06-30-2013, 02:22 PM   #4
FRiSson
Drives: FR-S MT
Yes, MT. There is a tiny hesitation. And at other times, I don't get a linear development of power. Sometimes it seems to slightly dip or hesitate.
Old 06-30-2013, 02:25 PM   #5
Hindi
Hindi's Avatar
Drives: Frs
Typical with dbw throttle body cars. Probably seems worse with the at?
-Robert
Hindi is offline   Reply With Quote
The Following User Says Thank You to Hindi For This Useful Post:
strat61caster (07-03-2013)
Old 06-30-2013, 02:29 PM   #6
JDM FRS
JDM FRS's Avatar
Yea thats what I was thinking. Does the ecu reflash make it a little better?
Old 06-30-2013, 03:28 PM   #7
Hindi
Hindi's Avatar
Drives: Frs
I personally can't say. I'm thinking that even if pedal response wasn't adjusted, a good reflash helping get rid of the "torque dip" would make a big improvement. I wonder if you just happen to be in the low torque band of rpm when this hesitation seems the worst.
Maybe someone with a reflash can chime in.
I think they also make electronic pedal controllers which are suppose to help, again I've never used one.
-Robert
Old 06-30-2013, 04:35 PM   #8
Steve
Steve's Avatar
Drives: 6MT
also noticed this, when mashing the throttle RPMs drop below idle and make the car shudder before spiking up. Learned to ease into it slightly to avoid this when wanting to floor it
Steve is offline   Reply With Quote
Old 06-30-2013, 08:48 PM   #9
mikeg7827
mikeg7827's Avatar
Drives: 1995 Ford Probe
after my reflash this past saturday... i noticed this issue.. it doesnt happen every day and i even brought the car back to the dealer service shop and of course.. what do u know.. the problem doesnt happen!
good thing was i took a video and emailed it to my service advisor but it didnt do any good.
im uploading it to youtube so i can show ya what im experiencing
mikeg7827 is offline   Reply With Quote
Old 06-30-2013, 08:54 PM   #10
mikeg7827
mikeg7827's Avatar
[ame]http://youtu.be/BaxX3fBANpM[/ame]
Old 06-30-2013, 09:11 PM   #11
Barbarian
Barbarian's Avatar
Drives: Raven FR-S
I've noticed this a few times with my MT, but usually only when the engine is cold. I always just assumed it was related to the engine warming up.
Barbarian is offline   Reply With Quote
Old 06-30-2013, 10:08 PM   #12
01s0uljah
Drives: SWP Subaru BRZ Sport-Tech 6AT
If you have any HVAC on. it'll raise your idle abit to power it.. Its normal.. I see it mine
01s0uljah is offline   Reply With Quote
Old 06-30-2013, 11:43 PM   #13
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Originally Posted by mikeg7827 View Post
That might be the idle hunting issue, I want to say bad cam sensor? Not sure haven't read through the idle drop thread in a long long time. It couldn't hurt to skim that. (It's a sticky)
Mine idle dips every now and then. I figure if I end up getting a CEL and have to take it in, then my paranoia about a first model year car and buying the extended warranty was justified.
Via my Note 2
Freeman is offline   Reply With Quote
Old 07-03-2013, 12:13 AM   #14
JDM FRS
JDM FRS's Avatar
Via my Note 2
I think its just because im so used to driving a stick and being able to control thd engine speed before letting out the clutch.
Throttle Response CamryDS Northern California 27 03-31-2015 03:35 AM
BIG THROTTLE 70 KIT @ JAPANPARTS JPxM0Dz Engine, Exhaust, Transmission 10 12-19-2012 05:43 PM
5th Gear and 6th Gear 0% throttle to 80% throttle gear crunch? kharn83 Issues | Warranty | Recalls / TSB 9 08-06-2012 07:44 PM
Throttle Controllers harajukukei Engine, Exhaust, Transmission 31 07-28-2012 12:40 AM
