Old 06-29-2013, 02:18 PM   #1
Cal3000
Drives: Panda FR-S
Vortech SC question
May be a silly question but I need to get educated. I ordered a Vortech SC from Visconti with a base map. If I install a crank pulley with the base tune, will it screw up the tuning characteristics? Will I need a tune accompanied with the pulley?
Cal3000 is offline   Reply With Quote
Old 06-29-2013, 02:20 PM   #2
charged86
charged86's Avatar
Didn't affect my car. Idle is better than stock. I have visconti tune as well perrin crank pulley
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 06-29-2013, 02:26 PM   #3
Cal3000
Drives: Panda FR-S
I see. Sounds good. What about the lack of a harmonic dampener. I'm kind of iffy on installing one. I had one on my tC before i traded it. It worked fine. I'm just seeing horror stories online.
BTW, I was following your car. Get it dynoed yet?
Old 06-29-2013, 03:38 PM   #4
charged86
charged86's Avatar
apparently this car does not use the crank pulley to balance the crank. probably because boxer the crank is basically inline with the heads and rods cams etc. I say go for the perrin crank pulley. I would install crank pulley first drive it for a day or 4 to make sure you have no issues which I believe you will not. because once the blower setup is on and you have a problem with the pulley it will be hard to diagnose and or repair.
haven't dyno-ed yet but will soon at @Hal@Dynosty and with a 12psi pulley on e85. I hope my car is atleast 250whp I did stomp a 02 wrx with plenty of mods and max psi on stock turbo
Old 06-29-2013, 03:45 PM   #5
Deepseadiver
Drives: 2013 BRZ DMG manual Limited
Did you get a different pulley? Where did you get the pulley? Looking forward to the dyno!
Deepseadiver is offline   Reply With Quote
Old 06-29-2013, 03:49 PM   #6
charged86
charged86's Avatar
I actually bought a 3.125 inch pulley before I got the kit, from perrin drop shipped from vortech. stock pulley is 3.48.
I want to get this boost relief wastegate from here the also can make custom 6 rib pulley that fit the blower.
http://www.928motorsports.com/parts/...mitervalve.php
I want the option of going back to 9psi and pump.
my e85 12psi tune will be custom made for my car. I also need a catch can and "want" a clutch and Light weight drive shaft
Old 06-29-2013, 04:09 PM   #7
Deepseadiver
I ordered the pulley from visconti and was told that vortech was supposed to drop it with the kit, but it never came. I guess I need to PM John and see where mine is. Do you know anyone else with the smaller pulley?
Old 07-07-2013, 12:30 PM   #8
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
I remember there being a thread on here of a bunch of people in the same boat. Ordered with the smaller pulley through John but didn't get it from vortech but I forget what came of it. Try searching it should be somewhere
Sent from my Nexus 4 using Tapatalk 2
Nolan
pheoxs is offline   Reply With Quote
Old 07-07-2013, 02:33 PM   #9
Deepseadiver
Got my pulley two days ago!
Old 07-07-2013, 02:47 PM   #10
pheoxs
I really need to stop looking through threads on my phone, didn't realize that was 2+ weeks ago oops
Old 07-09-2013, 07:14 PM   #11
tg_1981
If you go with a smaller pulley(3.125) do you need new shorter belt?
tg_1981 is offline   Reply With Quote
Old 07-09-2013, 07:35 PM   #12
Pete
Pete's Avatar
Drives: 22 BRZ
I think the belt tensioner takes care of the tiny amount of slack created.
2013 FRS -> 2011 CTS-V -> 2006 Cayman S -> 2015 GTI -> 2022 BRZ
Pete is offline   Reply With Quote
Old 07-31-2015, 05:05 PM   #13
Deepseadiver
what type and size injectors came with his kit?
Old 08-01-2015, 01:26 AM   #14
wootwoot
Drives: FRS
Lol
Vortech e85 question and help ft86me Forced Induction 20 06-09-2013 09:55 PM
vortech pulley ft86me Forced Induction 14 06-05-2013 03:27 PM
vortech hp ft86me Forced Induction 1 05-28-2013 10:44 PM
Installation PDF for Vortech please? official_george Forced Induction 7 05-12-2013 09:34 AM
BEspoke question and rattle question bdanisi Electronics | Audio | NAV | Infotainment 2 01-30-2013 02:11 PM
