Old 06-29-2013, 01:02 AM   #1
JDM FRS
JDM FRS's Avatar
Drives: Scion FRS(Whiteout)
DIY: iJDMTOY LED DRL Foglight Bezel Install
Here you go! It's my first DIY Video so go easy on my! I also kept calling the glovebox a toolbox for some reason. The total time on the install if you go through the firewall and make everything look pretty is about 2.5 hours if you take your time. If I were to do the install again I'd say it would take about half that. And I cant get the "auto stabilization thing" to go away
Oh and the inspiration/power routing idea came from @FR-Shadow
[ame]http://youtu.be/19kW9Lzj6K4[/ame]
JDM FRS is offline   Reply With Quote
The Following 3 Users Say Thank You to JDM FRS For This Useful Post:
FR-Shadow (06-29-2013), mike_ekim1024 (09-20-2013), NABoxer (03-26-2016)
Old 06-29-2013, 01:37 AM   #2
Bt216
Bt216's Avatar
Drives: Scion frs
Nice!! They're really bright
Bt216 is offline   Reply With Quote
Old 06-29-2013, 01:49 AM   #3
JDM FRS
JDM FRS's Avatar
it might just be the exposure on my camera lol. they kinda aim down though which is good lol
Old 06-29-2013, 01:19 PM   #4
JDM FRS
JDM FRS's Avatar
Oh yeah with the blue going to green wire of the high beam the LED Bezel will be low when the DRLs are on and high when the headlights are on
The Following User Says Thank You to JDM FRS For This Useful Post:
Old 07-01-2013, 03:28 PM   #5
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
These DRL strips confuse me. Are they OEM or just fit perfectly? I went to the dealer and he said he thought they were OEM for 2014 as an option too.
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
Old 07-01-2013, 07:14 PM   #6
JDM FRS
JDM FRS's Avatar
From what people are saying they are a regional item. The set I got from ijdmtoy aren't OEM they just fit the bezel perfectly. The way they set up there is no switch or anything so they don't function like a fog light. They just look awesome Imo
Sent from my HTC VLE_U using Tapatalk 2
Old 08-07-2013, 03:08 PM   #7
JDM FRS
JDM FRS's Avatar
Lol thanks for the special mention ijdmtoy
http://store.ijdmtoy.com/Scion-FR-S-...ghts-a/556.htm
Old 08-09-2013, 11:04 AM   #8
invaliduser
Drives: 2017 86
Installed these yesterday and I do like.
There is an open slot in the fuse box with accessory power (near the wiper fuse if I remember correctly). A spade connector fits in nice and snug. Much easier than running into the cab for power.
I think (personal opinion) the LEDs are too bright at 100%. I will likely wire the blue wire to the same accessory power slot for 50% brightness all the time.
invaliduser is offline   Reply With Quote
The Following User Says Thank You to invaliduser For This Useful Post:
Old 12-31-2015, 07:09 PM   #9
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
What amp fuse did you use in that accessory power fuse slot?
Old 12-31-2015, 07:27 PM   #10
invaliduser
Drives: 2017 86
https://goo.gl/photos/KPp3i4s9ibLRDQK18
Sent from my Nexus 6P using Tapatalk
Old 12-31-2015, 07:50 PM   #11
FRSBRZGT86FAN
thanks!
Old 03-26-2016, 12:14 PM   #12
NABoxer
Drives: 2013 DGM Brz
Kind of reviving this from the dead but how long was the install? I'll be likely doing it this way since going to the fuse box seems much easier than inside the cabin. Any problems since then? And I agree I would like the dim output throughout.
I see the picture but I'm a noob when it comes to electrical stuff, but could you tell me the actual fuses you use?
Thanks so much!
NABoxer is offline   Reply With Quote
Old 03-26-2016, 12:16 PM   #13
invaliduser
Drives: 2017 86
Thanks so much!
That is a blank spot for a fuse. Just use a spade connector to push in to that spot.
And no issues since original install. I autocross once a month and never had a problem.
Old 03-26-2016, 01:51 PM   #14
NABoxer
Thanks!
Just received mines and no blue wire for dim option kind of bummed hopefully they send me a new set of wires. Must be the new version.
Zeta Performance - High-power LED Strip DRL Kit - Foglight Bezel Replacement ZetaPerformance Exterior Parts - Lighting 16 06-30-2016 05:40 AM
Zeta Performance - High-power LED Strip DRL Kit - Foglight Bezel Replacement ZetaPerformance Cosmetic Modification (Interior/Exterior/Lighting) 0 03-13-2013 01:26 PM
Carbon Fiber Foglight Bezel JonMotoring Exterior Parts - The Rest 0 02-10-2013 05:51 PM
Removing the HU Bezel Xdragonxb0i DIY (Do-It-Yourself) Guides 1 02-05-2013 08:20 PM
