Old 06-14-2013, 03:16 PM   #57
FR-S Matt
If you want an honest opinion, you aren't going to find a lot of difference between UEL and EL on this engine unless you're going above 400 whp. Its negligible at best. EL sounds more racier like a 4 cylinder does. UEL sounds like the WRX rumble that everyone loves, which I like a lot too.
For someone who wants to squeeze every ounce of HP out of their setup, EL is the way to go regardless of sound.
If you want the best of both worlds, go UEL.
EL's have catted options.
UEL's are only catless due to the design.
Just some things to consider when you make a header purchase. Just don't go Borla.... piece of junk.
The Following User Says Thank You to FR-S Matt For This Useful Post:
spgrizz22 (06-14-2013)
Old 06-14-2013, 03:32 PM   #58
stockysnail
Just the tip
stockysnail's Avatar
Originally Posted by Biggdogg View Post
Just installed my 3 inch axleback yesterday. Ive never tuned or messed with cars before in my life, but this was such an easy install. Called up Matt and asked him a couple questions and it took no time to unbolt the old and bolt on the new. It sounds and looks flat out amazing. The craftsmanship is just stellar. My only complaint has absolutely nothing to do with the exhaust itself, I just wish I went with the 4 inch mufflers so it was a bit louder. Absolutely nothing to do with the quality of the product. Believe me this thing sounds flat out freaking amazing. Nice deep growl, just a bit quiet for me. I ordered the op/dp with high flow cat with it, but it seems thats still 2 weeks out Im hoping that will add to the noise a bit. Plus I plan on getting the header once they make that available. I think that should set it off. But for anyone who is looking for an exhaust, words cant describe how pleased I am with this exhaust. I didnt really notice any power increase for anyone interested, but again it was just the axleback, so none was expected. Cant wait for the rest to come in. If anyone is on the fence about this exhaust, get off of it now and call Jason or Matt.
When you install the overpipe, you'll need to do the install on a lift if you ordered the helmholtzs as a jack and jack stands can't get the car high enough to get it in there. (speaking from experince unfortunately) If you didn't get the helmholtz, you should be ok as long as you can get your car up high on jack stands. So much easier on a lift though so I suggest renting one or using someone's if you're going to do it yourself.
Old 06-14-2013, 04:23 PM   #59
Biggdogg
Drives: Crystal Black Silica BRZ Limited
Power is a factor in it but it seems im one of those people who like to keep the same brand for the setup. I fell in love with nameless when I heard a youtube clip in the exhaust compilation well before I even bought my car. Honestly I dont even know the full numbers on all the headers out there. But you are right I wouldnt go with Borla for anything, which is a shame as when I was considering a 5.0 their exhaust sounded amazing. I guess they just didnt put in the time for our cars. Are Nameless making both designs, or just one?
And yea I dont have access to a full lift, so im gonna have to figure something out. Have a bit of time to ask around for options though. Wish I didnt, as I want my op/dp! But I dont mind the wait since im sure it will be worth it.
Biggdogg is offline   Reply With Quote
Old 06-14-2013, 04:35 PM   #60
OrbitalEllipses
Drives: Attitude
Did this in my garage on jack stands...no lift required. You DO need to undo the engine mounts though.
Old 06-14-2013, 05:41 PM   #61
FR-S Matt
Nameless is only making one design because they only care about one thing, POWER. Catted for staying legal in stx events and a catless version, both longtube and interchangeable from N/A to FI.
You don't need a lift to do any of this work, but it sure makes it easier.
Old 06-14-2013, 05:52 PM   #62
Biggdogg
Thanks. Now just need them to release it and will be good to go.
Old 06-17-2013, 12:48 AM   #63
DaBrz
Just put on the 2.5 exhaust. It's actually pretty loud lol (not riced out). But then again, I've never had an aftermarket exhaust. I'm going to order the down pipe soon. Just waiting on the headers for final release info and will probably go full nameless the neighbors will not be pleased when i wake up for work.
DaBrz is offline   Reply With Quote
Old 06-28-2013, 05:38 PM   #64
riironman
riironman's Avatar
Drives: asphalt fr-s
So I will be purchasing a axleback. Just confused. ..the 4 inch is louder than the 5 inch? Are the tips the same size as the mufflers? The 2.5 are direct bolt ons but the 3 inch arent. Kind of lost
riironman is offline   Reply With Quote
Old 06-28-2013, 06:20 PM   #65
OrbitalEllipses
Drives: Attitude
4" refers to the length (IIRC...probably not diameter) of the muffler. A longer muffler will be quieter.
Old 06-28-2013, 09:15 PM   #66
FR-S Matt
4 inch is louder than 5 inch, (length). 2.5" and 3" both bolt to the stock mid pipe. I have the 3" Axleback and it uses a gasket to connect to it. I plan on getting a 3" downpipe and 3" midpipe to complete the setup with the Nameless turbo header.
Old 07-31-2013, 08:24 PM   #67
Biggdogg
So I got my OP/DP combo a couple weeks ago but have been in and out of town so couldnt install it until now. For you guys who have this and have done it with jackstands, where did you jack the motor up at? As said before I am a complete novice at working on cars so will have a friend help me, and he wasnt sure since hes never been under a BRZ before, he just said not to use the oil pan. So where is the best point to jack the motor up at? And is it just an inch or two after you undo the passenger side motor mounts? Thanks.
Old 07-31-2013, 11:20 PM   #68
pche
Guy on internet
Drives: Slowly
Undo passenger side 14mm motor mount nut. Carefully and slowly jack under exhaust manifold. Don't need much, about 3-5" should do. You need to undo two 14mm nuts on the manifold, one 14mm bolt for the mid hanger and two 12mm nuts on two 14mm spring bolts.
Leave everything loose and tighten with the motor back at regular height. Push the overripe upward while tighten to gain all the clearance you can to clear frame.
pche is offline   Reply With Quote
Old 08-03-2013, 09:30 AM   #69
Biggdogg
Thanks man. Have to say that sounds a kinda intimidating to someone without any experience. Jacking up under the exhaust manifold wont hurt anything? I assume thats what everyone is using as well?
Old 08-03-2013, 04:02 PM   #70
umpadupa
umpadupa's Avatar
Drives: 94 civic hatch, Whiteout frs
i have heard of some people doing thi without jacking up the engine. but u need to take off the heat shields from the over pipe. and unbolt everything and then twist everything out slowly. that IF you dont want to undo the engine. BUt its gonna be harder.
Anyone wanna chine im regarding doing this with out jackaing up the engine
umpadupa is offline   Reply With Quote
Perrin Catback Exhaust vs Nameless Performance Exhaust. vignesh Engine, Exhaust, Transmission 201 06-05-2013 09:47 PM
Nameless Exhaust System pornflakes AUSTRALIA 2 02-01-2013 07:24 PM
Anyone in SD have a nameless exhaust? Or want to help install mine? :) gonzo Southern California 0 09-26-2012 02:06 PM
