Old 06-28-2013, 02:39 AM   #183
Hiros86
Hiros86's Avatar
Drives: whiteout FR-S
Originally Posted by apexaddict View Post
All I have at the moment that's recent.
more pics of this please
Hiros86 is offline   Reply With Quote
The Following User Says Thank You to Hiros86 For This Useful Post:
karma003 (10-12-2013)
Old 06-30-2013, 02:23 AM   #184
jshum
jshum's Avatar
Drives: Scion - FRS
Asphalt with 17" Black RPF1!! (HAVENT SEEN ANY!!)
This is what I am planning to do.
17x9 +35 on asphalt FRS. I havent seen anything like that yet.
Can anyone do a quick photoshop for me or post any picture of that if there are any??
I do think it will be a good combination with the tint valenti tail light!
I would like to know how it looks like. Thanks!!!
jshum is offline   Reply With Quote
Old 06-30-2013, 10:18 PM   #185
Amir4571
Drives: FRS RS1.0 #82
found these pics in another thread. hope it helps
Amir4571 is offline   Reply With Quote
The Following User Says Thank You to Amir4571 For This Useful Post:
Old 06-30-2013, 10:35 PM   #186
jshum
jshum's Avatar
Drives: Scion - FRS
Thx!! Now I do have an idea how its like
Old 07-01-2013, 12:02 PM   #187
loogs
Drives: on cruise control
those are not x9's though. it will look much better than that
loogs is offline   Reply With Quote
Old 07-01-2013, 06:15 PM   #188
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Anyone have pics of Asphalt with Silver/Gold rims similar to these?
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
Old 07-01-2013, 07:53 PM   #189
apexaddict
Asphalt + 17x9 +45 RPF1s
Andrew P.
#14 STX Scion FR-S - powered by Stranoparts and Moto-East
apexaddict is offline   Reply With Quote
Old 07-01-2013, 09:43 PM   #190
pche
Guy on internet
Drives: Slowly
Just bought a set on eBay for a good price. Do they poke out or rub at all? Planning on getting 245/40/17.
pche is offline   Reply With Quote
Old 07-01-2013, 10:46 PM   #191
SportInjected
SportInjected's Avatar
Drives: for the sake of driving
Are you on stock suspension? If yes, then they will most likely rub without a spacer, depending on the tire.
'13 Argento FR-S
SportInjected is offline   Reply With Quote
Old 07-01-2013, 10:58 PM   #192
pche
Guy on internet
Drives: Slowly
Yea, planning on getting springs, how much are you dropped?
Old 07-01-2013, 11:10 PM   #193
loogs
Those look like 18's :/
Old 07-01-2013, 11:20 PM   #194
SportInjected
Not much, but I have +35 offset 17x9's, so rubbing is not an issue to begin with.
If you plan on getting just springs, versus coilovers, I would suggest you look into a 3-5mm spacer and go from there.
'13 Argento FR-S
Old 07-04-2013, 10:26 PM   #195
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
need confirmation on wheel set up
I plan on buying 17x9 rpf1's with a 35 offset and plan to run at least 245-40 tires. Suspension wise, i have swift springs comming in, and i was wondering if i will have any rubbing issues regarding me hitting my fender liner or any suspension parts on full lock? If this set up wouldn't work i was then gonna buy the 17x8 nt03's with 245's. So my worry is the same, if there would be any rubbing on the fender liner/suspension parts on full lock etc.
bkblitzed is offline   Reply With Quote
Old 07-05-2013, 11:45 AM   #196
djdnz
1337
Drives: 2013 BRZ WRB S/C
It should fit fine. Shouldn't have any issues with the fender unless you are going fairly low - camber and tire size will determine this. The +35 will poke slightly at that drop unless you add camber. 245/40/17 is a good size.
The +45 will rub the tie rod at full lock.
There is a whole thread on the 17x9 RPF1.
http://www.ft86club.com/forums/showthread.php?t=15160
djdnz is offline   Reply With Quote
The Following User Says Thank You to djdnz For This Useful Post:
bkblitzed (07-05-2013)
Wheel Directory: Enkei RPF1 17x9.0 +45 LevinPhan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 265 06-04-2024 11:13 AM
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** LSD Motorsports Groupbuys 246 08-29-2013 01:35 PM
WHITE Enkei NT03+M 18x9.5 / Enkei RPF1 17x9 Touge Factory Wheels and Tires 2 02-05-2013 04:53 PM
