Old 06-27-2013, 06:35 PM   #1
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
DashCam hardwire question
I've been reading the threads regarding hardwiring your dash cam but have a question I'm not too sure about and don't want to blow anything.. From what I understand the DashCam uses a 12V signal; do you just take the wire that comes with the dash cam, cut the male side to expose the wires and tap/solder to a 12V wire/ground or are one of these required: http://www.ebay.com/itm/DC-Converter...-/251009862646. If I wanted to attach it with a fuse tap to the fuse box would it be required?
oh and I am considering this one (GT300W):
http://dashcamtalk.com/ls300w/
thanks.
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
Old 06-27-2013, 06:57 PM   #2
Foobar
SLO NO MO
Foobar's Avatar
thanks.
Don't need that. Just get a tap-a-fuse and two fuses to go in it. One to replace an existing fuse and one for the new camera. Positive to the tap ground to the grounding bolt on the fuse box.
Sent from my Nexus 4 using Tapatalk 2
Old 06-27-2013, 07:11 PM   #3
l0aded
Addicted
l0aded's Avatar
Does the fuse rating matter? I have a few 3A ones lying around I'd like to use if possible =)
Old 06-27-2013, 07:48 PM   #4
Foobar
SLO NO MO
Foobar's Avatar
I just checked the specs on that camera - Looks like it uses USB to power it, not a standard 12V connection as USB is 5V. You will need that converter, or just get a cigarette lighter USB charger and plug your camera into that (so long as you're OK with it being on only when the car is powered). It has its own battery so you just need to plug it in to charge it.
The Following User Says Thank You to Foobar For This Useful Post:
l0aded (06-27-2013)
Old 06-27-2013, 10:29 PM   #5
l0aded
Addicted
l0aded's Avatar
Yeah I had a feeling. DashCamTalk forums has a section on this model and someone mentioned it. So from what I understand it will go like this:
Dashcam -> female usb cable -> strip male side to expose 2 wires (red/black) -> solder to converter 5v to 12v -> connect 12V wire to tap-a-fuse and put in fuse box -> connect black ground to nut?
Is there supposed to be a third wire? Should I be fuse tapping a constant power source (brake light) or an ignition one?
Old 06-27-2013, 10:50 PM   #6
Foobar
SLO NO MO
Foobar's Avatar
Just two wires. As for constant or accessory power - depends, does this camera's battery last long enough to stay on for your usual parking duration? If so, then I guess you could just charge it whenever you're driving under accessory power.
Old 06-27-2013, 11:23 PM   #7
l0aded
Addicted
l0aded's Avatar
It's only 500mah so not too good or bad. Guess I gotta look into if it has an autooff when the voltage drops to make sure I don't end up with a dead battery.
Old 06-27-2013, 11:46 PM   #8
Foobar
SLO NO MO
Foobar's Avatar
Could get one of these to auto off for you: [ame="http://www.amazon.com/electronics/dp/B008B8ERIO"]Amazon.com: Power Magic Pro BlackVue vehicle Battery Discharge Prevention for Parking Mode (for BlackVue DR350, DR300G and DR400G HD): Car Electronics[/ame]
DIY-Replacing Rear View Mirror/Hardwire Radar Detector Lil Abner DIY (Do-It-Yourself) Guides 40 06-11-2020 03:48 PM
FRS Radar Detector Easy Hardwire Doc DIY (Do-It-Yourself) Guides 37 05-27-2015 02:18 PM
BRZ hardwire radar. Jive Turkey DIY (Do-It-Yourself) Guides 12 03-20-2015 01:11 AM
Another radar detector and dashcam hardwire nalc Electronics | Audio | NAV | Infotainment 3 12-13-2013 12:14 PM
Anyone here using a Dashcam? Jahdai42 Mid-Atlantic 18 02-21-2013 10:36 PM
