Old 06-27-2013, 03:17 AM   #1
SleekMachine
SleekMachine's Avatar
Drives: Whiteout
Swapping springs need HELP!
Okay, I have bc racing br coilovers and I have the 8k spring rates. I wanted to buy lower spring rates, roughly 4-5k, and I was wondering what the specs were for the standard bc br springs, so I could get the correct springs that will fit.
Also, since I am changing out the springs to one that is considerably different, so do I need to get the shocks revalved? And if so, can I do this myself or do I need to take it to a shop?
If anyone can help, thanks a bunch.
SleekMachine is offline   Reply With Quote
Old 06-27-2013, 01:33 PM   #2
wparsons
wparsons's Avatar
Watch your spring rates vs your ride height, too low with too soft of a spring will have you bottomed out all the time over the slightest bump and isn't good for the shock.
flickr
Old 06-27-2013, 01:43 PM   #3
CSG Mike
CSG Mike's Avatar
The dampers *probably* are not valved for springs that soft, so you may end up way underdamped on compression and way overdamped for rebound.
Are you just trying to get a softer, more comfortable ride?
Old 06-27-2013, 09:18 PM   #4
SleekMachine
Drives: Whiteout
Well, I can adjust the ride height, so that isn't a problem. The only thing that would worry me is the dampers and the amount of travel in the spring, but as it now with the 8k springs I don't need to worry about the amount of travel. All that is left is the dampers.
Old 06-27-2013, 09:21 PM   #5
SleekMachine
Drives: Whiteout
Yea, trying to get a softer more comfortable ride.
If worse comes to worse I'll just get 6k. I know on the bc website they said that it is fine to go 10k on the dampers that were valved for 8k. So, I'm assuming it would be + or - 2k.
But seriously, can someone give me the specs on the springs?? I can't find it anywhere.
Old 06-27-2013, 09:30 PM   #6
SleekMachine
Drives: Whiteout
Oh btw, can anyone let me know where I can just purchase the swift springs for my coilovers? I know they offer it as an option, but I never see it offered alone, so I don't know where to get em.
Thanks.
Old 06-27-2013, 09:31 PM   #7
cto424
i called swift springs the other day and they told me the fronts are 5" and the rears are 6" and both 65mm.
the softest spring swift has in 5" is 10k rate, but i swear i saw a FS thread where someone was selling a BC setup with 5k swift springs front and rear.
cto424 is offline   Reply With Quote
Old 06-27-2013, 09:35 PM   #8
SleekMachine
Drives: Whiteout
So, just to make sure, these are the specs for the replacement on the bc br coilovers?
Old 06-27-2013, 09:38 PM   #9
cto424
yup, that is what the guy at swift springs said.
Old 06-27-2013, 09:38 PM   #10
SleekMachine
Drives: Whiteout
Oh man, I just checked swifts website and the lowest they have in 5" is 10k, what heck.
Old 06-27-2013, 10:05 PM   #11
cto424
i'm wondering how that one seller had 5k front and rear from swift. PM'ed the seller but no reply. if you find a softer spring rates for the front let me know too, cause i would like to try the same thing.
Old 07-17-2013, 04:05 PM   #12
SleekMachine
Drives: Whiteout
I've finally give up on my quest for lower spring rates on the bc br. I'm just going to get softer/lower springs on my stock suspension. GL on your search.
Swapping the motor. Either 3uz or 2gr diss7 Engine Swaps 34 11-16-2015 04:31 PM
Swapping OEM FRS Spoiler for 5 Axis CamryDS Cosmetic Modification (Interior/Exterior/Lighting) 4 10-30-2013 01:59 AM
Buying and swapping brz Bumper for frs rhood168 Cosmetic Modification (Interior/Exterior/Lighting) 1 05-12-2013 01:11 AM
Swapping back to summers mezdup NY / NJ / CT / PA 8 03-29-2013 11:43 PM
swapping out stock Lugs lbroskee Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 07-26-2012 10:21 AM
