Old 06-20-2013, 05:10 PM   #71
Dezoris
Dezoris's Avatar
Depends on the size of the women you like...
I will have to get back to you with weight information.
Old 06-20-2013, 05:22 PM   #72
CSG Mike
CSG Mike's Avatar
Oh I said nothing about weight....
Old 06-20-2013, 05:44 PM   #73
Dezoris
Dezoris's Avatar
This is what I am looking to do:
Old 06-20-2013, 06:04 PM   #74
CSG Mike
CSG Mike's Avatar
Can't help you if they don't actually fit IN the car....
Old 06-21-2013, 12:24 AM   #75
distracteddev
Drives: 2013 Ultramarine FRS
Do hub centric wheel spacers negatively effect performance on the track?
distracteddev is offline   Reply With Quote
Old 06-21-2013, 04:27 AM   #76
CSG Mike
CSG Mike's Avatar
Hubcentric RINGS:
No, but I don't use them, because they might get stuck on the hub, which means you're going to potentially have issues putting on another set of wheels later. Additionally, plastic ones may deform and/or melt onto the hub or rim.
They're nice for "centering" the wheel, and taking the stress off of the lug nuts when you're initially tightening them, but ultimately, the lug nuts are what hold the wheel on, as well as force the wheel to center.
If you want to get super technical, they are added unsprung rotational mass.
Hubcentric SPACERS:
I wasn't aware that they made these, but spacers are fine as long as either you're using the proper extended studs, or are properly torquing them if the spacers give you an alternate set of studs.
Personally, I'd recommend you get extended studs (ARP) and use cheap ebay spacers, if you need spacers at all. There are times where I spend money, and there are times where I don't, and spacers are just giant shims in this case. The studs you should never skimp on.
Old 06-26-2013, 12:55 PM   #77
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
Will removing the weatherstrip at the top of the engine bay under the hood help with ventilating and removing heat?
Are there downsides to removing this?
JDKane527 is offline   Reply With Quote
Old 06-26-2013, 03:41 PM   #78
robispec
Drives: Black frs project
cowl induction....
robispec is offline   Reply With Quote
The Following User Says Thank You to robispec For This Useful Post:
JDKane527 (06-27-2013)
Old 06-26-2013, 05:07 PM   #79
CSG Mike
CSG Mike's Avatar
It does precisely what you don't want. Like @robispec said... think muscle cars with that hood cowl. You're sucking in air.
Old 06-26-2013, 07:07 PM   #80
ayau
Drives: Some rust bucket
When can we expect the CSG BRZ to be on the track again?
Old 06-26-2013, 07:19 PM   #81
CSG Mike
CSG Mike's Avatar
I wish I knew...
Old 06-27-2013, 02:41 AM   #82
derek1ee
Drives: BRZ/FRS/STI/M3
1. what's your tire temperature difference (outside/inside of front/rear) on track and on street? is 10F difference outside to inside on street driving to much?
2. what's your tire temperature difference front to rear? I have rear temp higher than front, ~5F, normal? how can i make them even?
thanks!
derek1ee is offline   Reply With Quote
Old 06-27-2013, 02:29 PM   #83
ja1217
Drives: 2004 Toyota RAV-4 5M
How much drop would you recommend on a set of coilovers (Ohlins Road and Track to be specific) that will see around 10 track days a year and will be daily driven the rest of the time? I'm not really concerned with how it looks, lap times and not scraping on every imperfection on the road are more important to me.
ja1217 is offline   Reply With Quote
Old 06-27-2013, 03:01 PM   #84
CSG Mike
CSG Mike's Avatar
I haven't specifically set up ride height on that particular coilover. However, as with every other coilover, it's highly dependent on how well you can compensate for having a roll center that's a bit lowered (increased response time to input is a simple way to explain the effect).
Don't focus on the drop as much as getting the dampers dialed to your taste.
To me, a street car is too low if you gotta worry about scraping. Since it's a daily driven car, make the daily driver aspects primary, and tracking secondary.
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
