Old 06-14-2013, 08:00 PM   #155
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
Originally Posted by spitz View Post
Here are a few shots of the gurney flap I received from japanparts.com. The quality is OK in my opinion, it seems to be abs plastic or urethane.
Not sure if I'll install it on the car, but it does require two holes to be drilled into the wing and clips mounted, from what I could translate from the instructions (in Japanese).
Big disappointment.
I wish japanparts.com had disclosed that information. However, they shipped super fast!
Damn! mine comes without badge and clips!
Trap63 is offline   Reply With Quote
Old 06-14-2013, 08:45 PM   #156
DSOmegaX
DSOmegaX's Avatar
No drilling required. The tape holds just fine. Just put some adhesive promoter to be conservative. Cut the bolts to half size and they will snugly fit into the holes. What I did on mine was buy a replica metal sti badge (matches the badge on the lip and side skirts) to replace the sticker.
@dsomegax.cars
Old 06-15-2013, 04:32 AM   #157
Basti
Basti's Avatar
That sticker went straight to my dashboard.
I didn't want that strip on the outside of my car cuz frankly, it doesn't look all that good
Basti is offline   Reply With Quote
Old 06-25-2013, 05:33 PM   #158
cmspooner
cmspooner's Avatar
Drives: 2013 SWP Limited BRZ - Manual
I didn't want to pay for the price for the official one, so I made my own. It cost ~$25, and took me 30 minutes to trim and attach.
I picked up an m3 trunk spoiler and trimmed it down to fit the BRZ.
cmspooner is offline   Reply With Quote
The Following 7 Users Say Thank You to cmspooner For This Useful Post:
chanomatik (08-14-2013), Createddeleted (04-04-2016), ericmpena (10-26-2013), humanshield (08-12-2013), Sgtfluffy16 (01-10-2016), ShoGun (02-14-2014), SliverBrz (08-14-2013)
Old 06-25-2013, 05:34 PM   #159
zoomzoomers
zoomzoomers's Avatar
Can't see your pictures.
The Following User Says Thank You to zoomzoomers For This Useful Post:
cmspooner (06-26-2013)
Old 06-26-2013, 11:05 AM   #160
cmspooner
cmspooner's Avatar
I stupidly grabbed the url from my gmail attachment...I wasn't thinking; they are fixed now.
The Following User Says Thank You to cmspooner For This Useful Post:
zoomzoomers (06-27-2013)
Old 06-26-2013, 11:15 AM   #161
ScottDRFT
Space Cowboy
ScottDRFT's Avatar
Drives: '13 BRZ SWP Ltd --> '24 Trueno Ed
Nice! That worked out pretty well!
ScottDRFT is offline   Reply With Quote
The Following User Says Thank You to ScottDRFT For This Useful Post:
Old 06-26-2013, 11:25 AM   #162
Basti
Basti's Avatar
Neat, is this solution more solid than the rubber STi thingie? And more importantly, can you paint it?
Wonder if the effects on the aerodynamics are the same. It IS shaped differently.
Old 06-26-2013, 12:48 PM   #163
cmspooner
cmspooner's Avatar
It is definitely more solid than the sti lip. You can paint it, but I think you will have to be more careful about shaping it. I was able to get it soft enough to shape by leaving it in my car, in the sun and then use the tape to hold it in shape. You would probably have to shape it with a heat gun to the rear wing then paint it so that the paint wouldn't crack from bending it.
As to aerodynamics, I'm not sure either makes a huge difference at normal speeds.
Old 06-27-2013, 11:16 PM   #164
zoomzoomers
How did you get it to stick on the wing? Double sided tape? Looks good from what I can see and you probably saved a cool buck.
cmspooner (06-27-2013)
Old 06-27-2013, 11:22 PM   #165
cmspooner
cmspooner's Avatar
It's attached with 3M tape that actually came on the lip! I am very happy with it, although I can see a few imperfections with how it is laid...nobody else notices until I have them run their finger along the back edge and I point it out.
Of course I could pull it and re-attach it; but I'm not up to that. Maybe if somebody points it out with out me bringing it up.
Old 06-27-2013, 11:38 PM   #166
MikeM5
Drives: E90 M3, BRZ Limited
^ nice work! Turned out nicely!
I keep going back and forth on this thing...
UNSCENE MEDIA GROUP | | Follow Us on Instagram
Melbourne E90 M3 | Techno E36 M3 | ZN6 BRZ | CB550
MikeM5 is offline   Reply With Quote
The Following User Says Thank You to MikeM5 For This Useful Post:
cmspooner (06-28-2013)
Old 06-28-2013, 12:40 AM   #167
zoomzoomers
Yeah, nice work there.
Old 07-01-2013, 04:18 PM   #168
virjose
Drives: X5d
Nice work! Was the trimming just on the ends or did you actually have to cut somewhere else? Dremel? A write-up would be great if you have one
virjose is offline   Reply With Quote
The Following User Says Thank You to virjose For This Useful Post:
cmspooner (07-01-2013)
APR Wing? track_warrior Cosmetic Modification (Interior/Exterior/Lighting) 14 03-06-2013 03:36 PM
Varis FRS Wing for FRS/BRZ vividracing Cosmetic Modification (Interior/Exterior/Lighting) 31 02-01-2013 05:17 AM
GT-R style wing quik1987 Cosmetic Modification (Interior/Exterior/Lighting) 16 11-12-2012 03:56 AM
i like the gt86/brz wing. pr086 Scion FR-S / Toyota 86 GT86 General Forum 24 08-15-2012 05:12 PM
Wing or no wing? (rear spoiler) quik1987 Scion FR-S / Toyota 86 GT86 General Forum 123 12-12-2011 07:11 PM
