Old 06-25-2013, 01:44 PM   #1
ML
ML's Avatar
Drives: 13 White MT FR-S
DIY side skirts
http://forums.corvetteforum.com/c5-g...-part-1-a.html
I have been really contemplating taking on this project. I already have a carpenter shop that would route the PVC board for me. PVC board at Lowes is thicker than I want (3/4"), maybe 1/2" thick. But hey if its good enough for the corvette guys the outcome must be pretty nice. $50 vs $200 of something your going to beat to hell.
The Following 4 Users Say Thank You to ML For This Useful Post:
Dadhawk (07-05-2013), Grip Ronin (06-27-2013), Nguyenstreak (10-17-2013), sidnacious (06-25-2013)
Old 06-25-2013, 03:02 PM   #2
FRSfan111
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
That actually turned out surprisingly well on the vett! If you got the tools go for it.
FRSfan111 is offline   Reply With Quote
Old 06-25-2013, 04:25 PM   #3
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
Looks good.
Why not find some poly plastic instead of wood.
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 06-25-2013, 04:26 PM   #4
ML
ML's Avatar
Originally Posted by DriftEightSix View Post
Looks good.
Thats what pvc board is
The Following User Says Thank You to ML For This Useful Post:
charged86 (06-29-2013)
Old 06-25-2013, 04:39 PM   #5
Frostyman
Drives: 2013 Raven FRS
Yeah, I gotta attempt this. I don't have lottery money to be tossing around at thousand dollar side skirts and junk. Time to hit up some of that out-of-the-box thinking it's claimed humans are capable of.
Originally Posted by Don@Accelerated
For the sake of argument I went and cut my factory filter housing up.
Frostyman is offline   Reply With Quote
Old 06-26-2013, 12:27 AM   #6
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
In for more info...it's an awesome idea
Old 06-26-2013, 12:31 AM   #7
YDNA
YDNA's Avatar
Drives: Raven FR-S
im using abs plastic for something like this, and a front splitter as well.
YDNA is offline   Reply With Quote
Old 06-26-2013, 05:15 AM   #8
mrlewistan
Driver of FR-S 1467
mrlewistan's Avatar
Drives: 2013 scion frs 001467
hope it turns out well. n take it slow. you dont want to redo any drilling
mrlewistan is offline   Reply With Quote
Old 06-26-2013, 08:16 AM   #9
ML
ML's Avatar
Going to lowes to get a 3/4"x6"x12' pvc board today. I just hope they can cut it in half for me or I'm going to have a long piece sticking out my FRS trunk. Then I will take it to the carpenter shop and have them round off top and bottom of both pieces, and round off the ends as well, and if the can shave off a 1/4" of the thickness. Then I will take it home, line it up, drill it, and go get some hardware to mount it. Maybe post some pics.
Old 06-26-2013, 09:07 PM   #10
ML
ML's Avatar
OP Delivers...sorta. I think this will work out very well! But I do see some issues.
Here is my horrible photoshop of a finished product lol
The board is to long right now and I have two ideas of making it shorter. Also it is about a inch ~ to wide. I want the very rear to be flush with the beginning of the rear fender.
For making it the board shorter (its 6' now) i was thinking about curving the front of it down to be completely flush with the OEM "mud flaps", or just take the quick way out and just cut it straight.
Next I need to figure out how to mount it. I'm going to get metal screws, and pretty big washers, but I don't know where to drill under the car? How do other side skirts usually connect?? I couldn't find a good picture.
Suggestions?
Old 06-26-2013, 09:36 PM   #11
White64Goat
Check around some suppliers to home builders for Azek Trim Board. It is available in different thicknesses, however, you may have to buy a 4x8 sheet.
Old 06-26-2013, 09:49 PM   #12
ML
ML's Avatar
That's what this is! This is not wood. This is trim board/ Polyvinyl chloride / plastic
Old 06-27-2013, 01:00 PM   #13
ML
ML's Avatar
free hardware!
Old 06-28-2013, 08:28 AM   #14
jonghyun
Drives: '13 BRZ Ltd MT WRB
This is an awesome mod. But as mentioned before, do you actually have to do any physical drilling? the guy in the DIY instructions said you have to "make sure the template holes line up with the holes on the car" but does that mean the car already has places to bolt the skirt on?
jonghyun is offline   Reply With Quote
Side skirts for BRZ cslntuee Cosmetic Modification (Interior/Exterior/Lighting) 23 04-27-2017 12:27 AM
BRZ Polyurethane CS Side Skirts JPxM0Dz Cosmetic Modification (Interior/Exterior/Lighting) 102 10-02-2014 07:02 PM
TRD side skirts only, opinions? JoeBoxer Cosmetic Modification (Interior/Exterior/Lighting) 17 04-24-2014 12:36 AM
S> used HT auto side skirts $150 GT 86 Brah Exterior Parts (Aero, Lighting, Etc.) 4 05-17-2013 10:32 AM
Side skirts Ryan86 AFRICA 6 01-17-2013 08:08 AM
