Old 06-25-2013, 03:21 PM   #1
markitect
Drives: Scion FRS
Cooked my brake fluid!!!
I ran my second HPDE this weekend, the car is over a year old, and my stock brake fluid rapidly degraded. It had no noticeable change after the first track day last year, but the result this time were this:
I didn't notice any color change until after the last session, when I noticed I had spongy brakes at the end of the last session(clearly boiled some fluid), and then the color changed significantly.
I find it odd that it would go that quickly. I've tracked with toyota stock fluid in my last car, and never had this happen. I also checked the other 3 FR-S at the track, and their fluid is the proper color (their cars are all newer). Is subaru brake fluid known for doing this? Is is simply designed to change color to indicate it needs replaced? Or is their possibly some other problem?
markitect is offline   Reply With Quote
Old 06-25-2013, 03:32 PM   #2
CSG Mike
CSG Mike's Avatar
You're just improving as a driver (and your original fluid is getting old). Time to step up to a better fluid.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
amram (03-27-2014), orthojoe (06-25-2013), raul (07-11-2013)
Old 06-25-2013, 04:42 PM   #3
Rejor11
Drives: Mini Cooper
I find it odd that you didnt notice any fluid boiling before on your first session! Youre simply braking harder than you initially did. Time to step up to race pads and high temp fluid. I recommend carbotech pads.
Rejor11 is offline   Reply With Quote
Old 06-25-2013, 04:48 PM   #4
kvnchu
Drives: 2005 S2000
Yeah agreed, rbf600 is a pretty good standard and xp10 all around. Prty much what alot of us use. CounterSpace carries it all if you were wondering, js ask Mike.
Scion FR-S '13 - Track Toy
BMW M Roadster '06 - Track Toy
Suzuki GSX-R750 '07 - Track Toy
Lexus IS350 '07 - Sold
kvnchu is offline   Reply With Quote
The Following User Says Thank You to kvnchu For This Useful Post:
amram (03-27-2014)
Old 06-25-2013, 05:41 PM   #5
orthojoe
Congrats! This means you're a better driver now. Time to flush with some RBF600 and get some track pads now.
2013 Subaru BRZ
orthojoe is offline   Reply With Quote
Old 06-25-2013, 06:53 PM   #6
Dezoris
Dezoris's Avatar
Looks like a nice aged whiskey. Get rid of it save the headaches, it's not designed for steady high temps.
Old 06-26-2013, 05:22 PM   #7
icemang17
Drives: Scion FR-S/ Subaru BRZ
interesting................I have found my FRS brake fluid just fine, but the pads are horrible...granted I am a racer who pushes the car quite hard.....but I don't think 1 year old fluid will boil.....
The stock brakes are good for maybe 15 minutes at best when pushed hard...I think your driving improved and now you are pushing beyond the limits of the stock brake pads.....fresh pads and better fluid will solve the issue...
My example...when I run on track I run with all traction control off.... I can almost make a 20min session before the brakes are cooked....with traction in sport mode....5-6 minutes at best....
A properly setup brake system will run for HOURS with no issues......my racer can run for around 25 hours before the pads wear to a point I need to replace them and change the fluid
icemang17 is offline   Reply With Quote
Old 06-30-2013, 07:31 AM   #8
Feffman
Drives: None
The Motul and Elf HTX brake fluids are what I've used a in a variety of cars for years and never had any brake fading issues. Contact Barry at Performance Oil Store (www.PerformanceOilStore.com) for either brake fluid.
Feff
Feffman is offline   Reply With Quote
Old 07-01-2013, 01:21 PM   #9
markitect
Drives: Scion FRS
We were running 15 min sessions, on stock tires, so I was surprised to see it happen too.
Old 07-01-2013, 01:23 PM   #10
CSG Mike
CSG Mike's Avatar
A few guys at the track cooked their brake fluid on stock pads, fluids, AND tires this past weekend. Novices too.
Maybe we need to put together a "first time track go-er" package.
suaveflooder (07-08-2013)
Old 07-01-2013, 01:41 PM   #11
RAWR BRZ
Drives: 2010 BMW M3, 2013 Subaru BRZ
Well it was 117F that day... Track package sounds like a great idea.
There is no way your car can run for 25hr with the same braking performance without replacing at least the pads... Unless you arent driving it hard the whole time.
RAWR BRZ is offline   Reply With Quote
Old 07-01-2013, 05:59 PM   #12
sw20kosh
Drives: 2013 Black FR-S
Cooked fluid does not mean better driver. All it tells you is you are using your brakes harder than the fluid can withstand.
Not saying you are one but I have seen bad drivers, who think that flailing the car back-and-forth and side-to-side braking as hard as they can makes them faster around the track, cook their fluid and pads.
/ducks for cover
Old 07-08-2013, 07:40 PM   #13
kosoku
Drives: 2013 fr-s
rbf600 DOT4?
kosoku is offline   Reply With Quote
Old 07-08-2013, 07:45 PM   #14
CSG Mike
CSG Mike's Avatar
Originally Posted by kosoku View Post
rbf600 DOT4?
Sure is.
Amount of Brake Fluid.... THEmailman Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 04-13-2013 11:46 PM
Brake fluid leak.. tintumz22 Issues | Warranty | Recalls / TSB 9 02-01-2013 03:20 PM
Track Day Brake Fluid Skorov AUSTRALIA 2 11-11-2012 07:10 PM
$98 Brake Fluid Upgrade Texas BRZ Tracking / Autocross / HPDE / Drifting 15 10-22-2012 02:50 AM
Brake fluid volume celica73 Tracking / Autocross / HPDE / Drifting 1 08-20-2012 02:05 PM
