Old 06-25-2013, 03:55 AM   #15
The359
X Rated
The359's Avatar
Drives: 2017 BRZ Series.Yellow
The left is the car color, the right is their "alternate color" for the white. It's a much closer alternate than some of the other colors they offer.
NULLA TENACI INVIA EST VIA
My BRZ
The359 is offline   Reply With Quote
The Following User Says Thank You to The359 For This Useful Post:
chanomatik (12-04-2013)
Old 06-25-2013, 05:57 AM   #16
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
I've got a Cusco antenna on order. Here are @mechaghost's pics of it (not mine):
Only because I wanted the JDM antenna for its similar shortness til I realized it's it tilts/folds requiring a different base that won't support sat radio which the USDM base does.
Old 06-25-2013, 02:35 PM   #17
DoomsdayJesus
In Autobahn withdrawl
DoomsdayJesus's Avatar
Drives: 2015 BRZ Limited Man., WRB
I don't know about anyone else, but I hate the satellite antenna. I had an aftermarket satellite radio in my old 3 series, and that thing never dropped it's signal on the way to work (I drive through heavily wooded areas of I-5). Now this thing consistently drops signal in several spots, any time the South/South East has any serious tree obstruction.
I work with satcom at work, there is almost no reason for it to be dropping the signal as often as it is, I think it's mainly because they integrated it with the FM antenna or because the housing is poor. I really can't wait to try another option when it comes out, or I'm just going to drop satellite radio.
DoomsdayJesus is offline   Reply With Quote
Old 06-25-2013, 05:08 PM   #18
BRZJonny
Drives: 2013 Satin White BRZ Limited
Have you had the TSB performed on your unit? They replace the antenna and housing. Mine has worked great since this was done.
BRZJonny is offline   Reply With Quote
Old 06-25-2013, 06:35 PM   #19
qoncept
qoncept's Avatar
I got this. http://www.ebay.com/itm/Scion-FRS-To...55da52&vxp=mtr
qoncept is offline   Reply With Quote
Old 06-25-2013, 10:40 PM   #20
White64Goat
Look in the radio section of the forums. I've tried several antennas and the FM reception is less than stellar with all the ones I tried. http://www.ft86club.com/forums/showt...ht=White64Goat
Old 06-25-2013, 10:50 PM   #21
Outlawstar98
SLOW BRZ
Outlawstar98's Avatar
Drives: 2013 328i xDrive; 2013 BRZ
beat sonic for days!
Outlawstar98 is offline   Reply With Quote
Old 06-26-2013, 10:14 AM   #22
meeskee2
meeskee2's Avatar
Drives: World Rally Blue BRZ Limited, MT
I have a WRB BRZ! I will be getting a Beat Sonic for sure!!!
- World Rally Blue BRZ | Limited | Manual -
"Some guys think that having a better car makes them better than other guys, and those guys are right." -Top Gear
meeskee2 is offline   Reply With Quote
Old 06-27-2013, 04:01 PM   #23
tinma
Drives: '13 BRZ
how hard is it to install these aftermarket antennas? I have a feeling the fin will be a little bit difficult, but the stubs r just twist on and off? not sure if im correct
tinma is offline   Reply With Quote
Old 06-27-2013, 04:13 PM   #24
cnk
Drives: '13 DGM BRZ Limited
Yup. Twist off, twist on the new one. Even the fins are easy. Just twist off stock, twist/screw on the connector for the fin, wipe down the area the fin will sit on with IPA, line it up the way you want and then peel and stick.
Old 06-27-2013, 06:36 PM   #25
BRZJonny
I actually used some blue painters tape to line up the fin with the center of the car, then mounted it as you mentioned. Took me all of 10 minutes.
Old 06-28-2013, 09:44 AM   #26
DoomsdayJesus
I should have specified, I'm having a problem with the Sirius XM antenna, not the GPS antenna. Mine was produced after the fix. Or is there a TSB for the Sirius antenna too?
Old 06-28-2013, 01:17 PM   #27
BRZJonny
Mine was also produced after the problem was supposedly fixed. When I took it in for a service, I told the tech about my intermittent problems with reception etc. when they checked it, they discovered that the upgrade had NOT been performed on my car even though the vin# was after the problem range. Subaru authorized the fix and since then everything works perfect.
Old 06-30-2013, 06:39 PM   #28
DarkestBuddha
Drives: BRZ limited GBS
There's a VG one that I've been trying to get my hands on
Kelvin you ever get the VG yet?
DarkestBuddha is offline   Reply With Quote
Torn on Antenna Options. 2pt5RS Cosmetic Modification (Interior/Exterior/Lighting) 17 02-18-2014 07:16 PM
Scion FR-S options:what options did you have dealer installed? Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 42 01-06-2014 02:35 AM
Bushing upgrades, geometry options and other component options? der_rainman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-26-2013 01:53 PM
WTT: Beat-Sonic Antenna for Modelista Antenna joergasm Canada Classifieds 4 12-10-2012 10:13 AM
Antenna Options Re~Mix Electronics | Audio | NAV | Infotainment 10 07-20-2012 01:02 PM
