Old 06-24-2013, 10:54 AM   #827
Vten
Drives: Too heavy
I was thinking 17x9.75 +25 .....225 or 235/40 tires ...sir rub a lot ??
Vten is offline   Reply With Quote
Old 06-24-2013, 11:03 AM   #828
djdnz
1337
Drives: 2013 BRZ WRB S/C
Originally Posted by blugbox View Post
Hey guys I'm pretty excited to join the XXR party! Picked up my 527 18x8.75 +35 flat black today. I'm particularly happy with these because they are drilled ONLY for 5x100 and I haven't seen these from XXR before. Also ordered Eibach Sportline springs which are on the way!
Honestly the dual bolt pattern was my main complaint with the XXR wheels. I wonder how you ended up with this version - look great! Get some pics mounted
djdnz is offline   Reply With Quote
Old 06-24-2013, 11:20 AM   #829
Vten
Drives: Too heavy
you save a little weight on a dual drilled , but I also wonder how he gets them that way ?
Old 06-24-2013, 12:32 PM   #830
blugbox
blugbox's Avatar
Drives: 2013 Raven Scion FR-S
Sorry about the delayed reply Vten and djdnz! I knew these were drilled like this from the start, and I also didn't like the dual drilled look.
I first want to say I am not affiliated with the following company, I just want to help out fellow members:
I ordered these from motorsportsr.com but I called (909) 989-1807 and talked to Jason. He may have more sets in stock and might be able to order more. Let him know Brandon sent you, so he can gauge traffic coming in from the forum.
They are located in Rancho Cucamonga, CA and I believe they ship nationally for $120 but I picked mine up locally. Hope this helps you guys with another source for these wheels!
WHEELS: XXR 527 18x8.75 +35 flat black 5x100 only
TIRES: Hankook Evo V12 225-40-18
Last edited by blugbox; 06-25-2013 at 11:16 AM. Reason: added pics to avoid double post.
blugbox is offline   Reply With Quote
The Following User Says Thank You to blugbox For This Useful Post:
Vten (06-24-2013)
Old 06-26-2013, 12:22 AM   #831
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
does anybody have a shot of some Gunmetal's with colored lugs (preferably blue)?
lbroskee is offline   Reply With Quote
Old 06-26-2013, 03:58 PM   #832
SMOKETREES
Lowered Lifestyle
SMOKETREES's Avatar
Drives: Scion Fr-S
Just showing some love, haven't been on here for awhile
Sent from my HTC One
SMOKETREES is offline   Reply With Quote
The Following 2 Users Say Thank You to SMOKETREES For This Useful Post:
ML (06-26-2013), Wes (07-05-2013)
Old 06-28-2013, 05:11 AM   #833
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Can I haz XXR club membership plz thank u
Don't think I've seen anyone post this exact same setup yet:
18x8.75 +35 in 235/40-18 Hankook Ventus1 noble2 (square)
Eibach Sportlines
F/R camber: -1.2 (maxed OEM camber bolt)/-2.0 (natural)
I used data from @DarrenDriven's sticked wheel thread and geometry to approximate fitments. The following are expected distances out from hub using stock 17x7 +48 as 0mm reference.
Ideal fitment to be flush on Sportlines drop:
F: 25.8mm
R: 36mm
XXR w/ front cambolt fitment:
F: 27.225mm (square setup but front neg cambolt makes this number smaller)
R: 35.228mm
Delta between XXR+cambolt fitment and ideal fitment:
F: +1.43mm (poke)
R: -0.8mm (tuck)
I calculated all this before buying anything to give myself confidence to buy everything because, like I said, I couldn't find this setup having been done anywhere. My numbers may be hard to follow but just know that after install, the visual results somewhat agree. I see poke in front and tuck in rear (both tiny). But my numbers are off... rear looks more tucked in person than the calculation suggests. >_<
Right after I installed these of course I'd find out sgmotoring/MotorsportsR has these in 5x100 single-drilled. Slight remorse there but I resolved that dual-drilled fills out the lug pocket design better + 10 holes to match 10 spokes + more holes shave weight.
The Following 4 Users Say Thank You to switchlanez For This Useful Post:
CodyFRS (07-12-2013), Killerbee (06-28-2013), mwjcyber (09-20-2013), trigger happy (10-27-2013)
Old 06-28-2013, 05:21 AM   #834
GeeTee86
86 Nut
GeeTee86's Avatar
Drives: 86 Satin 6MT High
Front looks spot on
Me and ryan have both ventus V12 (225) on 8.75 but no correction
GeeTee86 is offline   Reply With Quote
The Following User Says Thank You to GeeTee86 For This Useful Post:
switchlanez (06-28-2013)
Old 06-28-2013, 05:39 AM   #835
Osiris
Osiris's Avatar
Drives: Asphalt FR-S
Hey guys, I've been searching around for an answer to my question to no avail. Can the stock tires be safely used on the 527 in 17x8.25?
Osiris is offline   Reply With Quote
Old 06-28-2013, 06:53 AM   #836
Killerbee
Killerbee's Avatar
Drives: GR86 / Supra MK5 MT / MR-S / Z4
Well, you suck in searching then ;-)
http://www.ft86club.com/forums/showp...&postcount=670
http://www.ft86club.com/forums/showp...&postcount=688
http://www.ft86club.com/forums/showp...&postcount=809
All from this thread. Maybe you get in contact with Vten
Killerbee is offline   Reply With Quote
The Following User Says Thank You to Killerbee For This Useful Post:
Vten (06-28-2013)
Old 06-28-2013, 06:55 AM   #837
Killerbee
Killerbee's Avatar
Really fits the car perfectly. me haz
Old 06-28-2013, 07:08 AM   #838
Code:Red
Code:Red's Avatar
Drives: 2013 Firestorm 6MT
As much as i want to join this club NOW, i gotta be patient for a bit. The 527 is the multi-spoke wheel i'm looking for.
Code:Red is offline   Reply With Quote
Old 06-28-2013, 07:15 AM   #839
Osiris
Osiris's Avatar
Originally Posted by Killerbee View Post
Wow, apparently, I do suck at searching! hahah! Thanks, buddy!
The Following 2 Users Say Thank You to Osiris For This Useful Post:
Killerbee (06-28-2013), Vten (06-28-2013)
Old 06-29-2013, 10:13 PM   #840
pghfan19
Drives: honda civic ex
Car looks really good! What are your wheel measurements and what size tires? Where did you get the xxr 527s in matte bronze? The xxr site only has them available in gold. Thanks!
Originally Posted by VADER View Post
Just slapped'em on yesterday. Still have to align and add a bit more negative camber (aligning it today) because I'm rubbing in the rear and a little in the front. Loving the new look though, aggressive. I went to a car show last night with these for the first time, got a photographer to stop me within 2 minutes of parking my car and offered a free photo shoot this weekend
CRAPPY PICS FROM A CRAPPY PHONE (getting the new Samsung Galaxy S4 SOOOOON)
Better pics to come after this photo shoot weekend
pghfan19 is offline   Reply With Quote
17 wheels
Wheel Directory: ProDrive GC-012L 18x8.5 +48 MarkMash Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 05-12-2013 03:55 PM
Is there a thread for 'people doing stupid things in their brand new car' thread? Symbiont FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 36 02-18-2013 12:24 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
Are there any RWYB Wheel to Wheel road races? LexusFman Other Vehicles & General Automotive Discussions 1 11-05-2011 12:28 PM
