Old 06-21-2013, 05:34 PM   #43
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by iketeru View Post
I'm intrigued by this discussion... being a total noob, I didn't know these components were available for way cheaper than the kit price. would be nice if someone could put together a DIY, with mounting options on our car.
for example, found one for 350z's here:
http://my350z.com/forum/engine-drive...n-a-na-hr.html
This isn't really a DIY.. but here's my setup with pics. Anyone should be able to figure theirs out from this, the line cutting, routing, fittings, etc took the longest and caused the most bloodshed
Post 1: http://www.ft86club.com/forums/showp...&postcount=113
Post 2:http://www.ft86club.com/forums/showp...&postcount=126
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
iketeru (06-21-2013)
Old 06-21-2013, 05:40 PM   #44
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by jasper View Post
I was told the car starts to pull load at 230 not entirely sure how accurate that info is but it came from a reliable source that has never given me bad information before.
Sent from my Q10
I don't doubt that, I just meant from an oil health/protection point of view. I've heard similar on it pulling power, on the track I haven't noticed any difference between 230 and 235 I'd have to look at datalogs to see if top speeds were lower without the cooler, but sadly there were other changes also so that's probably not a good real world test of anything.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-21-2013, 05:59 PM   #45
Accurate Race Shop
Accurate Race Shop's Avatar
Drives: Scion FR-S
Oh yeah I totally agree that for oil health on a 0 weight oil 250 is far to high. I was just letting you know because you said your temps were going past 230 so just encase you were noticing it losing a little bit once it gets hot that is probably the culprate.
Sent from my Q10
Old 06-21-2013, 06:18 PM   #46
Accurate Race Shop
Drives: Scion FR-S
I like the mounting style I was just going to use the $7 zip connectors and mount it to the ac condensor. Also if anyone has questions about the lines or the fittings they are looking at send me the part number and the question and I will do my best to help you out.
Sent from my Q10
Old 06-21-2013, 06:21 PM   #47
iketeru
Drives: Whiteout 6MT FR-S
awesome, thanks!
iketeru is offline   Reply With Quote
Old 06-21-2013, 06:23 PM   #48
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
I am not sure but I don't think your statement is correct. I am suggesting it is not 0 weight at 250F.
Old 06-21-2013, 06:24 PM   #49
Dezoris
Dezoris's Avatar
Well the question of pressures is also critical, and more so for track use which I have not started to monitor yet.
I think this is the first thread of its type to actually discuss anything relevant on this topic with data.
There is definitely the divide as usual, what is good for the track is not so good for the street and vice versa. The question is where is that middle ground. If you are in a hot climate and track all the time 0w20 is not your oil and you should absolutely monitor oil pressures.
Dave do you have data on where your pressures are at and what oil you are running.
Example: (Oil temps, Ambient Temps, Coolant Temps, Intake Temps)
WOT PSI, HIGH AND LOW RPM
IDLE PSI
CRUISING PSI
Old 06-21-2013, 06:25 PM   #50
Accurate Race Shop
Drives: Scion FR-S
I'm not a huge person on quality oil but I was under the impression 0w-20 was a 0 weight oil. On air craft if it's a 10 weight it is 10w.
By saying I'm not huge on quality engine oil doesn't mean I'm against using it just that I'm not very good on all the detergents and weight classes for it. Normally use what the dealer recomends.
Sent from my Q10
Old 06-21-2013, 07:13 PM   #51
Captain Snooze
Drives: Red Herring
There are 2 numbers there: 0 and 20. This means it's a multiweight oil. The "0" refers to the viscosity at the testing temperature for that "W" grade and the "20" refers to the viscosity at 100C. So it would be better to say "Oh yeah I totally agree that for oil health on a 20 weight oil 250 is far too high."
http://www.upmpg.com/tech_articles/m...ity/index.html
http://www.kewengineering.co.uk/Auto..._explained.htm
Accurate Race Shop (06-21-2013)
Old 06-21-2013, 08:35 PM   #52
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
IDLE PSI
CRUISING PSI
I gathered data with 0w20, after switching to 5w30 pressures were great but I don't recall documenting them. I posted a thread on here somewhere
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-21-2013, 10:45 PM   #53
Accurate Race Shop
Drives: Scion FR-S
Ok that makes sense now in hydraulic fluids we only have one number so I never paid attention to the second number. I am very much an old school V8 no ecu type of guy and the only oil I have ever bought until now has been 10w-30 I am trying to find time to read up on engine oil but it's been pretty crazy with time lately. Thanks for the links!
Sent from my Q10
Old 06-21-2013, 11:12 PM   #54
Dezoris
Dezoris's Avatar
Sent from my Q10
The more you read about modern ecus and setups the more annoying it becomes when you realize how much of it revolves around emissions.
Old 06-21-2013, 11:18 PM   #55
Accurate Race Shop
Drives: Scion FR-S
Yes emmisions are a big enemy of the V8 people I'm working on a 351 Windsor that will gain 125hp once I remove the emmsion control stuff. But now that's it's not as simple as ripping some stuff off and tossing it in the dumpster I have to start hitting the books.
Sent from my Q10
1.1 vs 1.3 Radiator Cap JPxM0Dz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 01-21-2014 01:21 AM
KOYO Radiator In-Stock!!! Free Shipping!!! Titanmotorsports Engine, Exhaust, Bolt-Ons 24 07-09-2013 05:55 PM
WTB: Stock Radiator RYU Engine, Exhaust, Bolt-Ons 2 01-12-2013 11:21 AM
Koyo performance radiator in stock at B2autodesigns b2autodesigns Engine, Exhaust, Bolt-Ons 6 11-23-2012 12:28 PM
Anyone else have a lot of dents on the radiator? Norcalmav23 BRZ First-Gen (2012+) — General Topics 16 09-02-2012 11:07 PM
