Old 04-19-2013, 04:22 AM   #15
phatpanda
phatpanda's Avatar
Drives: Scion FR-S
Originally Posted by B L U E S L A T E View Post
I am not entirely sure what you are trying so say. You're telling me your spec without the actual offset.. and telling me that your setup works very well. But I don't see any relativity of your post compared to mine. My set up is 17x9.5 +40 all the way around with 255/40 tires. And no they don't rub either... just for comparison's sake.
17's and square.. I'm a fan! Btw, what did the 17's weight?
phatpanda is offline   Reply With Quote
Old 04-19-2013, 05:51 AM   #16
Cheeseballs
Cheeseballs's Avatar
Drives: Really slow
Do you have a lot of inner clearance with your setup? I am looking to get these wheels and tires too, but I have Koni/Eibach setup instead of coilovers.
Thanks
Cheeseballs is offline   Reply With Quote
Old 04-19-2013, 08:32 PM   #17
B L U E S L A T E
Drives: BMW E84
Didn't have a scale to weigh them before getting them mounted.., but according to my calculation, they should be in between 16.5 to 17 lbs.
Thanks
Enough for me to run -3.0 camber in the front and -2.5 in the rear. I'm also not too much dropped so I'd say if you're not too dropped, you shouldn't have a problem with it. 255/40 that I'm running is slightly taller than the OEM tires on OEM wheels as well. I would recommend running 245/40s. This is too much tires IMO... robbing too much power. lol
B L U E S L A T E is offline   Reply With Quote
Old 04-20-2013, 01:05 AM   #18
Cheeseballs
Drives: Really slow
Thanks for the insight. And your car is sick btw.
The Following User Says Thank You to Cheeseballs For This Useful Post:
B L U E S L A T E (04-23-2013)
Old 04-20-2013, 01:30 AM   #19
nix
nix's Avatar
Drives: AVO BRZ
Looks good.
nix is offline   Reply With Quote
The Following User Says Thank You to nix For This Useful Post:
Old 06-21-2013, 04:32 AM   #20
CSG Mike
CSG Mike's Avatar
What is this madness...
Old 06-21-2013, 04:44 AM   #21
WillBRZ
WillBRZ's Avatar
Drives: 2013 BRZ Limited 6MT GBS
Holyshit are you BLUESLATE from G35driver.com? I'm G35SedanGrn from driver!
2014 infiniti Q50 Daily 1996 Mazda Miata Racecar
SOLD -> Galaxy Blue Silica Subaru BRZ Limited 6MT
SOLD -> 2003.5 Infiniti G35 Sedan Emerald Mist
WillBRZ is offline   Reply With Quote
The Following User Says Thank You to WillBRZ For This Useful Post:
B L U E S L A T E (06-21-2013)
Old 06-21-2013, 07:17 AM   #22
troek
troek's Avatar
Drives: 2012 Toyota 86
love those meaty sidewalls!
troek is offline   Reply With Quote
The Following User Says Thank You to troek For This Useful Post:
Old 06-21-2013, 02:28 PM   #23
B L U E S L A T E
Drives: BMW E84
@WillBRZ yes! I've known about you for quite some time now as well. Hotdawwgman is my roommate so he told me about your new ride.
Old 06-21-2013, 04:02 PM   #24
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
Nice wheels bro!
Tye300 is offline   Reply With Quote
The Following 2 Users Say Thank You to Tye300 For This Useful Post:
B L U E S L A T E (06-21-2013), CSG Mike (06-21-2013)
Old 06-21-2013, 06:43 PM   #25
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
This and the gentleman with the red FRS with grey TE37's have completely changed my mind about TE-37's on this car. They look FANTASTIC!
Really shocked and glad to see that 17" doesn't look tiny on the BRZ given that the wheel doesn't even have the illusion of being bigger like the stock wheels do.
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
Old 06-21-2013, 08:23 PM   #26
mikemcberty
Drives: 86
love the red on the whiteout!
mikemcberty is offline   Reply With Quote
Old 06-21-2013, 08:41 PM   #27
wparsons
wparsons's Avatar
Originally Posted by CBR600RR View Post
Sick wheels. Do you notice your speedo being slightly off with 17 wheels and 40 tires? (Stock is 17 and 45)
You need all three measurements not just wheel diameter and aspect ratio.
245/40/17 is exactly the same diameter as stock, 225/45/17 is a slightly taller, etc.
The 40, 45, etc is the height of the sidewall as a percentage of the width, so a wider tire with the same aspect ratio will have more sidewall.
flickr
Old 06-21-2013, 09:20 PM   #28
mr. slim
SoCal86
mr. slim's Avatar
Drives: '13 Whiteout FR-S
saw your car at hungtinton this past wed! looks sick!
.: SUPER KAWAII :.
.: BUBSQUAD :.
.: LivinLow :.
.: FRS86 :.
mr. slim is offline   Reply With Quote
Wheel Directory: Volk Racing TE37 16x7.0 +46 BRZZZZZZZZZZ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 04-15-2018 08:47 PM
Wheel Directory: Volk Racing TE37 18x9.0 +45 OmegaKnight Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 63 06-24-2014 09:12 PM
Wheel Directory: Volk Racing TE37 17x7.5 +48 quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 03-12-2014 06:23 PM
Wheel Directory: Volk Racing TE37 18x7.5 +48 HI Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 07-10-2013 06:27 PM
Wheel Directory: Volk Racing TE37 18x9.0 +45 / 18x9.5 +45 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 09-04-2012 12:25 PM
