Old 06-10-2013, 01:45 PM   #253
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
Originally Posted by xxscaxx View Post
Nice meeting you yesterday man. Car looked great. Not sure where you disappeared to but I meant to say goodbye haha.
sorry had to run to push a car to start, then went on track for a minishoot with RSD.
your car was so clean man. hope to see you around this summer!
-ivan
Jive Turkey is offline   Reply With Quote
Old 06-12-2013, 07:09 PM   #254
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
One of these is not like the rest....
Ivan, it was nice to meet you in person. Your car looks freaking amazing! Keep on Keeping on!
Kirill
RallySportDirect.com
RallySport Direct is offline   Reply With Quote
The Following User Says Thank You to RallySport Direct For This Useful Post:
Voodoo Rufus (06-12-2013)
Old 06-12-2013, 10:50 PM   #255
Turbowned
Turbowned's Avatar
Aww, mannnn I wish I went just to see this car!
Old 06-13-2013, 12:46 PM   #256
Jive Turkey
the tuna, no crust.
Kirill
it was a pleasure to meet you guys, i wish i lived close to utah
and uh...i'll just leave this here.
The Following User Says Thank You to Jive Turkey For This Useful Post:
SkAsphalt (06-24-2013)
Old 06-15-2013, 03:20 AM   #257
humanshield
Drives: bucket
omg those brembos...
humanshield is offline   Reply With Quote
Old 06-15-2013, 11:20 AM   #258
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
-ivan
AZP's First Private Track Event, June 19 at NJMP Thunderbolt $315 including Classroom and Mentor!
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Call directly as We carry almost every manufacturer now, so before you buy parts call us.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
Old 06-19-2013, 07:24 PM   #259
jedichimp
OG <FR-S'less> Member
jedichimp's Avatar
Drives: yes
Where is the OEM armrest/center console from?
Flickr // SarapBuhay
merrill.joes@gmail.com
panda cheez
Old 06-21-2013, 12:09 PM   #260
Jive Turkey
the tuna, no crust.
ordered it from a guy on here. just search for OEM armrest and it should pop up!
Old 06-21-2013, 12:10 PM   #261
Jive Turkey
the tuna, no crust.
so the car was dialed in and i have the chance to track it. Wednesday @AZP installs had a track day. the brz was an animal. so planted. even the pro drivers said how balanced it was which was really incredible to hear from someone.
i had NO rubbing issues. the brakes were perfect, no serious bias even under full pressure. car was very planted and i can carry so much speed through corners that its just down right scary.
here is a good video Steven got chasing my brz...until i missed an Apex thus leading to a point by because i couldn't carry enough speed his forester was so fucking fast as well as his driving. i can't get over it
[ame="http://www.youtube.com/watch?v=7hYc99woZcE&feature=c4-overview&list=UUN4sc7nXhe0DLQcZ0_L4w-Q"]http://www.youtube.com/watch?v=7hYc99woZcE&feature=c4-overview&list=UUN4sc7nXhe0DLQcZ0_L4w-Q[/ame]
also....my interior is shipped out.
since my last post i've added whiteline rear diff inserts, subframe inserts are here waiting to be put in. kartboy trans mount insert...and some more goodies on the way.
AZP Installs (06-21-2013)
Old 06-24-2013, 11:30 AM   #262
TrogDor the Burninator
TrogDor the Burninator's Avatar
Drives: 2013 Hot Lava FR-S 6 MT
First of all, your car and your skills are pretty damn impressive ...
I'm a new FR-S owner, and I'm trying to find a way to put 18x9.5 +45 Volk TE37SL Black edition rims on my car as a first upgrade, with 245/255/265 35 rubber ...
Problem is, I can't seem to get a clear answer if I can do this on stock suspension, and if so at what tire width. I have seen the wheel threads of people able to get this done, already on springs or coilovers, but then will say "you could do this on stock with perhaps a 3mm spacer on the front to avoid the strut tower" ...
Any advice would be appreciated if you have it ... And again - your car is nuts man!
TrogDor the Burninator is offline   Reply With Quote
Old 06-24-2013, 01:03 PM   #263
djdnz
1337
Drives: 2013 BRZ WRB S/C
Your setup is going to require either a generous spacer or coilovers without question. You will also be 5mm inset compared to JiveTurkey's 57Xtreme setup, so maybe he can comment on his clearance at present. I found a 18x9.5+45 square setup at the link below, when I was looking at Enkei Raijins in that config.
https://www.facebook.com/STM.Project86
I asked them about it and they said they didnt have any clearance issues with the coilovers installed. They are running 235/40/18.
You're never going to fit with stock suspension without a spacer, especially when you drop and add camber. For reference, my wheels I just installed, at stock height, stock camber there is 3mm of clearance from perch to wheel/tire. This is on a 18x9 +42 with 245/35/18. Now your setup will be 9mm further in than mine, so interfering 6mm at stock height. Now when you lower and add camber you are likely interfering closer to 10-15mm. Hope that helps. Coilovers are the way to go if you are dead set on those wheels. If Jive could measure his clearance it will be a good indication of what tire size you can run.
djdnz is offline   Reply With Quote
The Following User Says Thank You to djdnz For This Useful Post:
King Tut (06-24-2013)
Old 06-24-2013, 02:47 PM   #264
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
This guy hit it right on the head. If you want to run those wheels with no spacer than you will need coilovers. Otherwise you will probably need at least a 5mm spacer or so to get what I would call a comfortable amount of strut tower clearance.
Jive Turkey (06-24-2013)
Old 06-24-2013, 05:06 PM   #265
Jive Turkey
the tuna, no crust.
here is my $.02 on wheel fitting and etc.
for starters, IN STOCK FORM this is a very balanced car. if you plan to remain on STOCK suspension i would not go wider than a 9' wheel. the reason being as mentioned above is strut clerance.
My views are different then most. i will always do suspension BEFORE wheels. reason being, if you do an aggressive wheel before suspension work/lowering it. the offset look horrible. wheel gap mixed with lack of camber = poke. and that to ME look horrendous. dont get me wrong, it would drive fine, but i'm the type of person that like to have a 100% all around car, meaning it drives AND looks great.
as for inner clearance, i never tried fitting hte rays on stock suspension becuase i knew it wouldn't work. If you're going to be spendiing $3k for te37's you should really look into a good coilover. unless all you want is a drop then go with BC's or something. but SERISOULY think about doing suspension before wheels.
Now to your question. can you make it work on stock suspension? the plain answer is YES. however you WILL need a spacer depending on the tire size you run, and even if you run a smaller tire i'm afraid aht being 2.5' wider than stock, 1' taller and having a not so aggressive offset will still be an issue. and you dont want to run more than a 5mm spacer without extended studs IMO.
as for tire size. it depends on the tire you go with. but on a 9.5 i wouldn't go smaller than a 255/35. i have a passionate HATE for stretched tires. a 255/35 depending on what brand will be square, i run 265's but RE11's dont run as wide as say a MPSS or a ZII. on my STi i used to have 18x9.5 +38 and ran a 275/35 all around.
CLIFF NOTES:
DO SUSPENSION WORK BEFORE WHEELS, OR ELSE BE MEXIFLUSH. 255/35 IS THE TIRE YOU SHOULD GO WITH IF THE BRAND RUNS WIDE. I HATE POKE AND STRETCH.
The Following 6 Users Say Thank You to Jive Turkey For This Useful Post:
akahenry (09-11-2013), DAEMANO (08-08-2013), mrdanyo (10-05-2013), SkAsphalt (06-25-2013), Swabe (06-25-2013), white_knight (06-25-2013)
Old 06-25-2013, 09:26 AM   #266
86CH
Drives: ZN6
is hks coilovers would work on 18x9.5 265/35 all around?.
86CH is offline   Reply With Quote
The Breeze GoSharks Member's Car Journals 1 06-05-2012 12:09 PM
BReeZe Out Music Video Draco-REX BRZ Photos, Videos, Wallpapers, Gallery Forum 4 04-01-2012 02:44 AM
