Old 06-19-2013, 08:03 PM   #1
Hanakuso
Saikou Michi Catch Can Installed!
Installed my Saikou Michi catch can yesterday and overall i'm very happy with my purchase. It's a very high quality can and the welds are nice. Best thing about these catch cans is the vast amount of options you can choose. I did run into a small issue with the clip that mounts onto the catch can, but they are sending me another one. I will update once I receive the clip.
Thanks to @neutron256 for the attachment idea! This is the U-Bolt that was used. I painted it black. http://www.mcmaster.com/#cadinlnord/3176t49/=n9lzvx
If anyone wants my specs here they are.
Installed picture. I'll take some more pictures once I get the updated clip. Right now it's only being held on by 1 bolt.
Hanakuso is offline   Reply With Quote
The Following 3 Users Say Thank You to Hanakuso For This Useful Post:
FrX (06-20-2013), GT86_PRAGUE (05-28-2015), Marcoscrdo (01-04-2015)
Old 06-19-2013, 09:21 PM   #2
SportInjected
SportInjected's Avatar
Drives: for the sake of driving
Nice and stealthy. I like!
'13 Argento FR-S
SportInjected is offline   Reply With Quote
Old 06-19-2013, 10:22 PM   #3
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
does this blow to the atmosphere?
where can i buy it?
Old 06-19-2013, 10:50 PM   #4
mad_sb
Drives: 2013 Asphalt FR-S
where can i buy it?
No, it is designed to recirc. I mounted the pair i took off my ralliart a long while ago.
http://www.saikoumichi.com/index.html
Old 06-19-2013, 11:01 PM   #5
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
These are great catch cans. I had one in my MazdaSpeed 3. Worked like a charm. Caught tons of gunk. Cans last forever. I took the one out of my Speed 3 and it's been sitting outside for ages and still looks great. Might use it again if I go FI.
JimmyMac is offline   Reply With Quote
Old 06-19-2013, 11:16 PM   #6
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
I wonder if i need ine to blow to the atmosphere or this?
Old 06-20-2013, 07:33 AM   #7
mad_sb
If you do some reasearch on why pcv systems are closed and it will be easy choice. A proper closed system is the best bet NA OR FI. You will need some check valves when you go FI. I have never seen a vented system work better than a properly configured closed system. On the other hand, i have seen MANY vented systems perform VERY poorly. It is a never ending debate and people will stubbornly defend their preferred system, myself included
You will need two cans for a complete system on this car. One for the driver side (pre throttle body to crank case), under WOT this becomes the primary scavenging system (boosted or NA) because there is a constant vacume under WOT. If boosted, the line will need to be sourced pre turbo or SC. And one for the passenger side (crank case to intake manifold), this is the primary system when off throttle as the vacuum is strongest at the intake manifold when off throttle.
The Following 2 Users Say Thank You to mad_sb For This Useful Post:
Fast_Freddy (11-11-2014), PoorMansRacing (01-02-2014)
Old 06-20-2013, 04:33 PM   #8
Hanakuso
where can i buy it?
What mad_sb said. If you are planning on using same setup, you should probably wait till I get the revised clip to make 100% sure it fits.
How nessessary do you think the 2nd can will be if staying NA? My impression is that it would only see very minimal blow by
Old 06-20-2013, 05:03 PM   #9
qoncept
qoncept's Avatar
No one will ever suspect he is burning less oil than everyone else.
qoncept is offline   Reply With Quote
The Following 2 Users Say Thank You to qoncept For This Useful Post:
mad_sb (06-21-2013), Sportsguy83 (11-10-2014)
Old 06-21-2013, 08:08 AM   #10
mad_sb
I have my second one mounted, but not plumbed yet so i cant say.... but the more time you spend on the go pedal the more important the 2nd can pre throttle body) becomes, especially if you are boosted.
The Following User Says Thank You to mad_sb For This Useful Post:
Hanakuso (06-24-2013)
Old 06-24-2013, 12:31 PM   #11
Hanakuso
Received the new clip and it fits perfectly. Here is a couple of pictures.
The Following User Says Thank You to Hanakuso For This Useful Post:
Laika (06-24-2013)
Old 09-22-2013, 04:52 PM   #12
Hanakuso
Small update. Driven about 1500 miles of normal street driving. FYI this is a small water bottle. So in reality it's about 25-35% of a shot glass worth of liquid
Old 10-04-2013, 04:05 PM   #13
Pablitomarrero
Pablitomarrero's Avatar
Drives: FR-S 10 series
Im about to buy this, can you tell me the hose sizes and lengths you went for? Thanks!
Pablitomarrero is offline   Reply With Quote
Old 10-04-2013, 07:58 PM   #14
timerbob
Drives: 2013 FRS Argento
Pretty cool. Thanks for sharing.
timerbob is offline   Reply With Quote
Is my Cusco catch can correctly installed? wbradley Engine, Exhaust, Transmission 9 02-24-2014 09:49 PM
Catch Can ArKiTeCkT Engine, Exhaust, Transmission 31 09-15-2013 03:07 PM
Innovative SC Installed!!! Pics and dyno installed. uspspro Forced Induction 15 04-02-2013 12:09 AM
Oil Catch Can? eblamble3 Engine, Exhaust, Transmission 4 03-15-2013 10:58 AM
Catch Can Help wootwoot Engine, Exhaust, Transmission 2 12-02-2012 02:35 AM
