Old 06-19-2013, 01:17 PM   #15
jamesm
my mazdaspeed mx-5 came with a comically small intercooler that would actually heat soak on the dyno and become an 'interheater'.
here's an example of an aftermarket kit for a high compression car (cayman/s) that has no intercooler. they're also only running 4psi.
http://www.tpcracing.com/tpcracing-987-stg1-turbo.html
everyone here is correct in that 'can i do it' and 'should i do it' are two very different answers. there are a lot better ways to save money when piecing together a kit. even an ebay core would be better than nothing. but, it can work if necessary at low boost.
Old 06-19-2013, 01:19 PM   #16
mid_life_crisis
Drives: FR-S 10 #103 AT
Originally Posted by nonicname View Post
Toyota uses non intercooled turbo engines outside the US. I couldn't believe it when I saw it. I actually believe it was a diesel engine though so I'm not sure if that makes a big difference.
Diesel engine is essentially controlled pre-ignition, if that makes any sense at all to you, so it wouldn't surprise me in the least.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 06-19-2013, 01:20 PM   #17
Drift-Office
Drift-Office's Avatar
Drives: AE86 / FRS / FC3S / GC8 / S14 / R32
Originally Posted by ft_sjo View Post
It's bad. Like crossing the streams.
I got that reference!
While I was @ 86EXPO this last weekend, this was exhibited by fellow member @ 86ZN6 - presumably the WORKS non-intercooled turbo kit that's currently under development...
FYI...
Drift-Office is offline   Reply With Quote
Old 06-19-2013, 01:31 PM   #18
AVOturboworld
4~5psi on a 9:1 motor vs. a 10:1 motor vs. a 12.5:1 motor is going to yield vastly different results, with many other modifiers such as the size of the stock oiling system, radiator size, engine size, and a host of other factors.
If you lived in a year-long cool climate, and had access to 93 octane gas or better, you may be able to get away without intercooling on this particular motor. But never go near a circuit, don't do extended driving at high rpms, and make sure you never run 91 octane gas.
Personally, the trade-off isn't worth it. In exchange for 4 hours of your life installing a FMIC along with the $1000~1500 for the parts, you can go from having to be always careful with it to just being able to drive without worrying if you'll have a $5~6k engine replacement bill in the near future.
And definitely go nowhere near Nevada without that intercooler - the combination of 91 octane and 110+ degree heat is going to be deadly unless you are very light footed. OTOH, we were giving test drives to 85 Expo members without issue in 115 degree heat at higher boost levels.
The Following 2 Users Say Thank You to AVOturboworld For This Useful Post:
DAMotorsports (06-19-2013), Fast_Freddy (06-20-2013)
Old 06-19-2013, 01:35 PM   #19
mid_life_crisis
It didn't help matters that it was mounted inside the engine compartment.
I guess my real point here is: if your goals are modest and it isn't necessary, can you save the bucks for something else and not have to tear apart your front end? Less money, less trouble installing, if everything works and meets the goals reliably without it, why do it?
Star Trek fans will recognize this line: "the more they fancy up the plumbing, the easier it is to stop up the drain." Keep it simple. That article in the second post was an eye opener.
Old 06-19-2013, 01:35 PM   #20
ft_sjo
Drives: GT86
Originally Posted by Drift-Office View Post
this was exhibited by fellow member...
Hilarilous......
Old 06-19-2013, 02:10 PM   #21
Whitigir
Drives: 450 awhp twin turbo vr4
This is Correct
Diesel doesn't have Spark Ignitions. Diesel ignite itself on designed Compression, and heat created from compression.
The compressed Diesel + Air Mixture will be Exploded instead of Fired and burn like Gasoline engine. That is why Diesel engine are Heavier and have more Torques due to high Compression.
It is possible to engineer a Turbo Diesel without Inter cooling
Whitigir is offline   Reply With Quote
Old 06-19-2013, 02:31 PM   #22
nonicname
Drives: it has 4 wheels and a motor
case closed! i believe this guy!
nonicname is offline   Reply With Quote
Old 06-19-2013, 03:19 PM   #23
qoncept
qoncept's Avatar
I wouldn't bother with the modest gains you'd see on a non-intercooled turbo on a 12.5:1 compression engine, but ...
What you're saying above just doesn't make any sense to me.
- The radiator has nothing to do with intake air temp. Same with water and oil temps and capacities. The only thing you could be thinking that makes any sense is the temperature under the hood increasing intake air temp, which is going to be practically zero compared to the increase due to compression. Yes, you'll want a bigger radiator or oil cooler because these engines already run hot and will get hotter with higher output, but that has nothing to do with an intercooler.
- Wherever you are, and whatever gas you use, you're going to tune your car. If you're in superhot Nevada you'll have appropriate levels of fuel and timing advance. Octane levels aren't some magical threshold, it's a scale and the levels tuned for (including from the factory) are what is available. You tune the car so it doesn't knock, period. Tune your car (well) for 91 and it will be fine on 91.
- How long you're able to stay in boost is ... well, it makes no sense at all to me. You're tuned to deal with the heat. If anything, how long you're on it matters LESS because you'll never have a heatsoaked intercooler.
qoncept is offline   Reply With Quote
Old 06-19-2013, 03:20 PM   #24
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Originally Posted by Whitigir View Post
How bad ? Very Bad.
1/ Turbo Works by using the Wasted Exhaust Hot Air to spin the Wheel, which is connected to the Turbine by the Shaft, which then turn the Turbine wheel, which will suck air in for you.
2/ Compressed air, or anything compressed will be Heated up, together with the Hot Air from the other side which heat it up faster = Recipe for Pre-ignition or Knocks....
3/ Your engine goes BOOM! in time
Sorry but you're spreading fear more than information. Yes inter coolers are key but there are turbo applications without inter coolers installed. They just do not produce tuns of power.
You could pull the intercooler out of the first celica-supra turbos and route things differently and barely notice as long as you didn't track the thing. the intercooler was the size of a 1 litre coke bottle.
Old 06-19-2013, 03:23 PM   #25
mad_sb
Drives: 2013 Asphalt FR-S
FYI...
1. EWWWWWW
2. They put the passive cooler on the intake side?
Old 06-19-2013, 03:29 PM   #26
s2d4
s2d4's Avatar
Originally Posted by mad_sb View Post
1. EWWWWWW
Not sure if you can call that a cooler...
Old 06-19-2013, 03:30 PM   #27
qoncept
qoncept's Avatar
1. EWWWWWW
Lol, I didn't notice that. So now, instead of your intake being ambient temp at the turbo, it's very slightly heatsoaked. And, of course, nothing cools it after that. Genius.
Old 06-19-2013, 04:19 PM   #28
AVOturboworld
If the engine is already running hot in n/a form, especially at the track, then adding power is only going to increase that heat. The heat is, in the main, generated in the combustion chamber - and your oil and water cooling system is there to lower that temperature as much as possible. Running without an intercooler will raise those combustion chamber temperatures even higher. Knock and detonation will increase exponentially.
What I'm saying is that the situation is complex. If your engine was already at the limits of the standard cooling system, adding boost without cooling the charge temperature will tax it beyond the cooling capacity of the system. What's the point of adding a FI system if you could only run 1psi of boost?
Seriously? You make it sound like you could tune the car to run boost on 87 octane, and the stock motor isn't even barely capable of that. That's because you can only do so much ignition retard before your EGT's get too high and start melting other components. So, yes, octane levels *are* some magical threshold.
The other problem in that statement is that it ignores what happens when you drive cross-country.
Motors overhead in racing because the longer you stay at extended rpm's, the more heat in the engine that the cooling system has to deal with. 95% of street (OEM) systems are designed for occasional high-rpm usage, and can (and usually do) start failing when used constantly at high rpm's.
Adding boost - hot, compressed air - is doing similar things as running at higher rpm's. All FI systems are equal in this regard. Intercoolers are there to help alleviate that fact. Given that the discussion is about non-intercooled FI, it's even more relevant on how long you remain in boost. Intercoolers are not the only component in the engine that become heat soaked.
91 MR2 Turbo with KO Racing GT35R for sale/trade for FR-S turbo kit Unleashed Cars for Sale/Trade 8 02-20-2013 06:26 PM
Turbo Tuesday 12/4/2012 (Dynamic Turbo Miami) F3dzo Southeast 46 12-06-2012 01:49 PM
Another turbo with but water to air intercooler ahaghshenas Forced Induction 8 09-24-2012 02:22 AM
Using Subarus other turbo Boxers as an idea, how much HP could a turbo BRZ/FR-S have? HitTheGas BRZ First-Gen (2012+) — General Topics 12 02-21-2012 01:24 PM
Geneva Preview: Techart to debut 911 Turbo, Turbo S vh_supra26 Other Vehicles & General Automotive Discussions 1 02-22-2010 06:20 PM
