Old 06-19-2013, 05:03 AM   #1
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Rear Whiteline UCA bushings, possible dealer F**Kup?
So here I am getting my shit in gear to get ready to order me up some coil overs and make sure to take into account what I have now. I am educating myself taking a good look under car. I see this...
Now sorry I havent done this before but should there not be TWO sets of bushings installed on these UCAs?? The dealer did this for me out of the gate as I lowered it on springs "eibachs" and went with these to get the better alignment. To me this is HALF done at best, and probably actually more damaging then good yes?
I am pretty damn sure this is NOT correct and there should be two sets on each UCA according to WL instructions and data sheet, but wanted to confirm from folks here familiar with these if there would be ANY reason at all for there to be only one set on each UCA, both sides only front bushings were done. Back is not dirty, I confirmed simply by feeling it and wiping it that the backs "each side" are in fact the stock rubber bushings.
Before I go ape shit please correct me if I am wrong here in thinking there should be (4) bushing sets, all UCA front and back done to be proper....
Thanks!!!
Shawn
Old 06-19-2013, 05:29 AM   #2
Xauterus
Drives: GTS 86 Galaxy Blue
That is on the rear. Its a multi link so it doesnt have a top A arm as such.
Xauterus is offline   Reply With Quote
Old 06-19-2013, 05:30 AM   #3
OICU812
Just a dude
OICU812's Avatar
Originally Posted by Xauterus View Post
Front or rear?
Oops this is the REAR
Old 06-19-2013, 05:33 AM   #4
OICU812
Just a dude
OICU812's Avatar
Ok so it requires only the two total one set per side "front as shown" or requires two bushing sets per side, front and back each side??
Old 06-19-2013, 05:56 AM   #5
OICU812
Just a dude
OICU812's Avatar
Here's PDF that shows our cars arms and bushings.
To me it shows both in each arm?
http://www.whiteline.com.au/docs/ins...uides/Z395.pdf
Old 06-19-2013, 06:06 AM   #6
Calum
That Guy
Drives: 2013 asphalt FRS MT
All four are required so you don't move the outer pivot point fore-aft as you adjust the camber.
Old 06-19-2013, 12:58 PM   #7
derek1ee
Drives: BRZ/FRS/STI/M3
yes you do need both per arm
derek1ee is offline   Reply With Quote
The Following User Says Thank You to derek1ee For This Useful Post:
OICU812 (06-19-2013)
Old 06-19-2013, 01:06 PM   #8
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
So you are spending 300 dollars in bushings to do both sides? I thought the package came with enough for both sides.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 06-19-2013, 01:22 PM   #9
OICU812
Just a dude
OICU812's Avatar
Thought so and that makes sense of course.
Has anyone installed the whiteline steering rack bushings? was385 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 03-18-2013 05:40 PM
FS: Whiteline bushings. New, never installed stockysnail Brakes, Suspension, Chassis 0 02-05-2013 06:49 PM
