go_a_way1
Old 06-18-2013, 04:55 PM   #43
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Can't afford AP brakes. How about "cheap" blanks such as [ame="http://www.amazon.com/Centric-Parts-120-47021-Premium-E-Coating/dp/B000IY4A0Y"]this[/ame]. Paired with some better pads?
post_break is offline   Reply With Quote
Old 06-18-2013, 05:45 PM   #44
Stevo22
Stevo22's Avatar
Drives: GR86
CSG is working on a cooling solution that will be a direct drop-in replacement for the OEM radiator that is more efficient. As with all the products we offer, it will not be the cheapest on the market, but it certainly will be one of the best products you can buy.
Details......
Stevo22 is offline   Reply With Quote
Old 06-18-2013, 06:03 PM   #45
kvnchu
Drives: 2005 S2000
Do springs from company to company vary? i.e eibach v tein v swift v hr?
Scion FR-S '13 - Track Toy
BMW M Roadster '06 - Track Toy
Suzuki GSX-R750 '07 - Track Toy
Lexus IS350 '07 - Sold
kvnchu is offline   Reply With Quote
Old 06-18-2013, 06:50 PM   #46
CSG Mike
CSG Mike's Avatar
Originally Posted by post_break View Post
Can't afford AP brakes. How about "cheap" blanks such as this. Paired with some better pads?
That's precisely what I do on my s2k. The cost does add up though... I've spent more on pads and brakes than I would have spent on a BBK + consumables.
It's also what we recommend to our clients who don't have 2k to spend up front on a BBK; blanks and upgraded rotors do the job just fine.
Originally Posted by Stevo22 View Post
Details......
When it's ready
Here's teaser
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
Anthonytpt (06-19-2013), MyRx (06-18-2013), RYU (06-19-2013)
Old 06-18-2013, 09:20 PM   #47
kster1
kster1's Avatar
When it's ready
Here's teaser
I am also interested. Is there a rough ETA yet?
kster1 is offline   Reply With Quote
Old 06-18-2013, 09:34 PM   #48
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
If I were to illustrate a slip angle on a graph, with the peak grip coming at 6 degrees of slip and I have 2 drivers that turn identical lap times but one runs on the front side of the curve (5-6 degrees of slip angle) while the other operates on the backside of the curve (6-7 degrees of slip), who is the better driver and why?
And yes, there is a right answer.
Hint and cheat: It's in the Ross Bentley "Speed Secret" books.
PRO86 | WTCC | STL
Old 06-18-2013, 11:33 PM   #49
CSG Mike
CSG Mike's Avatar
Yes. The metallurgy is different, although difficult to quantify in words. Consistency is key though.
Old 06-18-2013, 11:36 PM   #50
CSG Mike
CSG Mike's Avatar
Psh, you must be kidding.
The lesser angle is the winner in a "general" sense, because he will grease out the tires slower.
Old 06-19-2013, 02:51 AM   #51
rice_classic
That's half of it and a damn important half!
The other half is that any driver operating on the wrong side of the slip angle, even by a little, puts him too close to the "edge" leaving nothing left in the tire. If he needs to make a sudden change when he's committed to a corner, he cannot without great difficulty and penalty. There will be a quicker drop off of traction and this will result in A) any mistake will be amplified resulting in greater time lost and/or B) a mistake will lead to an "off" or incident. As a driver, I am extra cautious when racing next to drivers who drive like this and it's easy to spot them (they're usually in the dirt).
OK Mike, I'll stop terrorizing your thread now.
PRO86 | WTCC | STL
The Following 2 Users Say Thank You to rice_classic For This Useful Post:
CSG Mike (06-19-2013), u/Josh (06-19-2013)
Old 06-19-2013, 10:52 AM   #52
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
background
My HPDE experience consists of just 1-2 events per year for the last several years. I would run my S2000 100% stock, except for Direzza SS Z1s and Carbotech XP10/XP8 pads. All fluids 100% stock, nothing special. I would usually run in one of the faster groups and never had any overheating issues.
question
I'm taking the BRZ to the track for the first time later this summer, to VIR (first time there) for a 3 day event. I had just been planning to slap on some Carbotech pads (still using the OEM tires) and hit the track. Is there anything else I should do before hand? I ask b/c I never had any issues doing it this way with the S2000 (I realize they're similar cars but obviously not the same). Typically I would bleed the brakes and change the oil but both are quiet fresh at the moment already.
Thanks Mike
Old 06-19-2013, 12:25 PM   #53
CSG Mike
CSG Mike's Avatar
Originally Posted by WolfpackS2k View Post
background
question
Thanks Mike
You got away on OEM brake fluid on the S2k?!?
I'd recommend changing to RBF600 brake fluid, and your preferred engine oil, not because the fluids in your BRZ are not fresh, but because they're not really suited to hard track duty.
Remember that this car has significantly softer springs than the S2k (stock vs stock), and that you need to ease the car into the turns, rather than being able to manhandle it like the s2k.
WolfpackS2k (06-19-2013)
Old 06-19-2013, 12:27 PM   #54
ayau
Drives: Some rust bucket
Should we wait for an ECU update before taking the car to the track? Wouldn't want another siezed motor.
Old 06-19-2013, 12:36 PM   #55
CSG Mike
CSG Mike's Avatar
I saw ANOTHER BRZ develop the misfire just this weekend... so I would recommend it...
Old 06-19-2013, 12:38 PM   #56
GTM_Challenge
GTM_Challenge's Avatar
Drives: On track
Mine throws a PO351 code every session at the track now. Hoping this new tune from Moto-East will help that.
GTM_Challenge is offline   Reply With Quote
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 07:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 01:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 08:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 08:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 10:54 AM
