Old 06-17-2013, 11:36 PM   #1
gatorbushmen
Amateur Drifter
gatorbushmen's Avatar
Drives: '13 FRS
4 gauge wiring?
So I am going to start installing my Kicker L7 tomorrow with a Kicker IX1000.1, and I am wondering if anyone has had problems using 4 gauge power wire. Will it fit through interior of the cabin?
gatorbushmen is offline   Reply With Quote
Old 06-17-2013, 11:43 PM   #2
GaDgeT
GaDgeT's Avatar
Fed 0 gauge from the battery, though the firewall to the boot.. you will have no probs with 4 gauge.
Just make sure you add an inline fuse <30cms from the battery
GaDgeT is offline   Reply With Quote
The Following User Says Thank You to GaDgeT For This Useful Post:
gatorbushmen (06-17-2013)
Old 06-17-2013, 11:46 PM   #3
mashal
DADA
mashal's Avatar
Drives: 2013
This. I'm running 0 too
mashal is offline   Reply With Quote
Old 06-17-2013, 11:49 PM   #4
gatorbushmen
Amateur Drifter
Drives: '13 FRS
Where would you recommend running the power wire through, underneath the trim on the right side of the car?
And I've seen people run the RCA's and remote wire through the center console , under the passenger seat and finally underneath the rear seat. Would that be any good?
Old 06-18-2013, 12:10 AM   #5
GaDgeT
GaDgeT's Avatar
Either left or right side fine for power wire, prop easier to do same side as battery, less cable required.
Dont run audio cables (RCA's and speaker) down the same side as power, that will cause noise gremlins and interference.
Also make sure that you use the same gauge earthing cable as power ie if you have 4AWG power, you need 4AWG earth
Old 06-18-2013, 01:33 AM   #6
Gir
Gir's Avatar
Drives: 86 GT Manual - Sonic Blue
I ran power down the side with the battery, Speaker cable down the opposite side and RCA down the middle. Fixed a bit of noise I was getting with the RCA's down the same side as the speakers.
Gir is offline   Reply With Quote
Old 01-21-2014, 05:15 PM   #7
Dsmith1992
10 Series Colorado
Drives: Scion FR-S 10 Series
this is a bit late but how the heck did you get the 0 gauge thru the firewall, i cant find the best place to run it and i plan on installing everything tomorrow?
Dsmith1992 is offline   Reply With Quote
Old 01-21-2014, 06:24 PM   #8
oldpueblo
oldpueblo's Avatar
Drives: Scion FR-S 10 #853
Just a thought, if you don't have RCA outs on your head unit and you have to splice, you might as well tap everything from the back amp and just run the power cable from the front. Less hassle.
oldpueblo is offline   Reply With Quote
The Following User Says Thank You to oldpueblo For This Useful Post:
mmontes (01-25-2014)
Old 01-23-2014, 01:56 PM   #9
rmjjensen
rmjjensen's Avatar
Drives: 2013 Subaru BRZ Limited in WRB
Why are there so many threads on this?
Edit: Just realized this thread is older than dirt
REMOVE THE BATTERY and you'll find an absolutely enormous rubber grommet you can run the wire through on the passenger side.
I'm also running 0 gauge.
rmjjensen is offline   Reply With Quote
Old 01-24-2014, 04:19 PM   #10
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
I just ran 4 gauge through the intake sound tube hole and killed 2 birds with one stone.
protpibe is offline   Reply With Quote
The Following User Says Thank You to protpibe For This Useful Post:
Old 01-25-2014, 01:20 PM   #11
mmontes
Drives: limited brz
^^^i did the same thing ^^^
it fit 0/1 guage perfect. I also covered the wire with black shielding.
being that close to exhaust worried me a little
but works perfect
mmontes is offline   Reply With Quote
Old 01-27-2014, 11:49 AM   #12
labskaus
labskaus's Avatar
Drives: Toyota GT86
labskaus is offline   Reply With Quote
wiring harness so26 Electronics | Audio | NAV | Infotainment 5 10-30-2013 03:19 AM
Wiring a sub in a BRZ Shizuma Electronics | Audio | NAV | Infotainment 22 06-08-2013 01:02 PM
Is foglight wiring in the car? FastLap Scion FR-S / Toyota 86 GT86 General Forum 7 08-26-2012 11:54 PM
Temperature Gauge a dummy gauge? bambbrose BRZ First-Gen (2012+) — General Topics 40 08-19-2012 04:29 PM
wiring diagrams? xpicer Engine, Exhaust, Transmission 4 08-13-2012 07:16 PM
