Old 06-17-2013, 03:17 AM   #43
8686
8686's Avatar
Drives: 86
Originally Posted by bkblitzed View Post
just wondering, will it be better to run the brz springs on the frs? or just run the frs made ones? I mainly care about handling with no understeer.
I think you should install the BRZ version
8686 is offline   Reply With Quote
Old 06-17-2013, 09:23 AM   #44
normanb21
Drives: black frs
Why? Isn't the brz version stiffer up front which would promote understeer
normanb21 is offline   Reply With Quote
Old 06-17-2013, 11:10 AM   #45
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
I would assume the higher front spring rate would help with turn in response, but may cause more understeer.
G_Ride is offline   Reply With Quote
Old 06-17-2013, 11:13 AM   #46
8686
8686's Avatar
Drives: 86
You are right and the ratio on the BRZ setup will give more balanced driving.
Old 06-17-2013, 06:40 PM   #47
troek
troek's Avatar
Drives: 2012 Toyota 86
i am by no means an expert driver, but i feel when i realy start pushing the car it oversteers a little too easily with very little throttle. i am realy leaning towards the brz swift or the rce yellows. have yet to make up my mind.
troek is offline   Reply With Quote
Old 06-18-2013, 02:14 AM   #48
8686
8686's Avatar
Drives: 86
Just ordered my set of BRZ Swift
Old 06-18-2013, 03:29 AM   #49
normanb21
Drives: black frs
Right now I am riding on 17x8 with 245/40/17 pilot super sports and subi crash camber bolts. The rest is stock. The car feels very planted vs stock with an upgraded wider tire. I have autocrossed the car a few times with a wider tire and it only oversteers if I ask it to. Its very awesome setup for autox. Just for some proof, my brother has a stock frs and we have went head to head on stock tires a few times already and we were always within .1 seconds. This past sunday we ran our cars head to head in an autox and I beat him by 2 seconds with just a wider tire and camber bolts. (40 second autox). I believe the swift frs would be better for autox, especially if your going to upgrade your tires, and the swift brz would be better for road racing. If I do decide to go with swift, it will be the swift frs and I will be making those bumpstops shorter.
The Following User Says Thank You to normanb21 For This Useful Post:
Fly Guy (03-25-2014)
Old 06-18-2013, 04:12 AM   #50
troek
troek's Avatar
yeah i like how well the rear end rotates tight corners up in the mountains, but on some sweepers it can get a little unsettling. but i am still a novice which is some of it. im running 225 hankook v12s, wich to be honest im not too impressed with. ive found they are very finicky to a specific pressure range.
Old 06-18-2013, 10:00 AM   #51
normanb21
Drives: black frs
If your doing high speed sweepers on mountains then its probably better to go with the swift brz springs imo
Old 06-18-2013, 01:35 PM   #52
SWAMechFRS
SWAMechFRS's Avatar
Drives: 2013 Scion FR-S Asphalt 6-Spd
Just ordered the last set of FRS Sport Mach springs they had at Evasive Motorsports. $295 w/ free shipping.
Sent from my iPad using Tapatalk HD
Don't Text and Drive
KCCO:happy0180:
SWAMechFRS is offline   Reply With Quote
Old 06-18-2013, 03:43 PM   #53
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
Well i just ordered the swift frs springs. Sounds like the FRS springs will make it act like my old STi did. Fast sweepers, itll over steer a little so ill be fine with that. I just want no understeer at all.
bkblitzed is offline   Reply With Quote
Old 06-18-2013, 05:33 PM   #54
troek
troek's Avatar
yeah, now to just wait for pay day, lol.
Old 06-19-2013, 07:58 PM   #55
taimysho0
Drives: frs
i have stance coils with swift springs and they feel great, i will have the opportunity to try stock struts on rce yellows in a few weeks so i can compare and let u guys know!
taimysho0 is offline   Reply With Quote
Old 06-20-2013, 03:50 PM   #56
VenomRush
Thee O-ri-gi-na-tor
VenomRush's Avatar
so i was trying to install the Swift Springs for the FRS and i noticed the springs on the front only fit correctly on the strut with the swift logo upside down, is that the right way to install them? or does the logo have to be right side up
VenomRush is offline   Reply With Quote
Prototype Swift Springs for FR-S mines13 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 137 09-17-2013 09:36 PM
Stance coilovers with Swift Springs clickfiveZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 06-05-2013 06:20 PM
Swift springs rate ID subaruferrucci Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 04-02-2013 04:26 PM
Fortune auto with swift springs? DarkCard Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 03-29-2013 03:15 PM
SWIFT lowering springs ? rikdrt1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 10-31-2012 06:15 PM
