Old 06-08-2013, 06:33 AM   #29
troek
troek's Avatar
Drives: 2012 Toyota 86
lighter springs in the front will promote more over steer. the reason between the two different spring sets is to try to retain the characteristics of the stock springs, in wich subaru is supposedly stiffer in the front.
troek is offline   Reply With Quote
Old 06-10-2013, 01:48 PM   #30
SeeSharkySwim
SeeSharkySwim's Avatar
Drives: Scion FRS
Ive driven my car on the road course in completely stock form with both factory tires and 225/45/17 advan neovas. The car has a higher tendency to understeer than I had originally hoped for. If you have an frs, i feel the spring rate stagger is necessary and the swift springs definitely helps the car rotate just enough without being tail happy.
i ordered mine from modern automotive performance, great to deal with and fast shipping.
SeeSharkySwim is offline   Reply With Quote
The Following 2 Users Say Thank You to SeeSharkySwim For This Useful Post:
OICU812 (06-17-2013), TouchMyHonda (06-10-2013)
Old 06-10-2013, 03:05 PM   #31
garfull
garfull's Avatar
Drives: FRS(sold), AP2, R35, FJC, ED9
i guess im still torn between the frs spring rates vs the brz. ive never driven a brz so im not sure how the the handle differs on brz compared to the frs. i guess ill have to wait till i do the hpde event to see if the stock frs feels tight or loose and go from there.
garfull is offline   Reply With Quote
Old 06-15-2013, 02:44 PM   #32
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Are cutting bump stops necessary?
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 06-15-2013, 05:00 PM   #33
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
No I didn't. It rides phenomenal.
TouchMyHonda is offline   Reply With Quote
Old 06-15-2013, 05:43 PM   #34
toyoman
Drives: DGM BRZ Limited 6MT
I cut mine - It was really simple to do. I was hesitant at first b/c I thought that if I wanted to go back to stock height, I would now have to buy new stops. However, after seeing my car with the swift springs and new wheels, I will never put the stock springs back on. The ride is amazing too!
toyoman is offline   Reply With Quote
Old 06-15-2013, 05:48 PM   #35
tonystewart
I'm adding Koni's next week, just want to make sure I measure correctly, therefore how much did you cut?
Old 06-15-2013, 05:49 PM   #36
Steve
Steve's Avatar
Drives: 6MT
how much rear camber was added after the springs installed?
Steve is offline   Reply With Quote
Old 06-16-2013, 11:21 AM   #37
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
you could cut, but you dont have to cut. it's up to u.
how much? up to u. the manufacturer does not suggest the cut.
hanabie is offline   Reply With Quote
Old 06-16-2013, 12:03 PM   #38
toyoman
I followed this thread when I did mine
http://www.vorshlag.com/forums/showt...7516#post57516
Old 06-16-2013, 05:41 PM   #39
tonystewart
Thank you!
The new Swift (BRZ) springs on my daughters FRS is everything we expected.
Old 06-16-2013, 06:23 PM   #40
SWAMechFRS
SWAMechFRS's Avatar
Drives: 2013 Scion FR-S Asphalt 6-Spd
Originally Posted by Coaster View Post
Every time I go to the Swift website my computer blocks a virus.
Yeah, mine too. they need to fix that.
SWAMechFRS is offline   Reply With Quote
Old 06-16-2013, 07:51 PM   #41
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
just wondering, will it be better to run the brz springs on the frs? or just run the frs made ones? I mainly care about handling with no understeer.
bkblitzed is offline   Reply With Quote
Old 06-16-2013, 11:33 PM   #42
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
Originally Posted by SeeSharkySwim View Post
I too was pleasantly surprised after installing the swift springs on my frs. I was never one to buy lowering springs after driving cars with lowering kits in the past that made the cars handle horribly. But I just couldnt stand the 4x4 height and was highly recommended this brand by a buddy that runs these on his GTR. This is more of a dd/weekend car for me but it does see the autox course fairly often along with the road course every once in a while. The car transitions much better than stock and they seem to suit the factory dampers perfectly. One thing I noticed after driving on these springs is how well they ride on the street, given the aggressive springrates they somehow feel more comfortable than stock. Although these will probably stay on my car for a couple more months until my AST dampers come in so they might be up FS soon Speaking of which, does anyone have experience with swift coilover springs?
I do have experience with swift coilover springs. Swift makes great quality coilover springs.
G_Ride is offline   Reply With Quote
Prototype Swift Springs for FR-S mines13 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 137 09-17-2013 09:36 PM
Stance coilovers with Swift Springs clickfiveZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 06-05-2013 06:20 PM
Swift springs rate ID subaruferrucci Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 04-02-2013 04:26 PM
Fortune auto with swift springs? DarkCard Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 03-29-2013 03:15 PM
SWIFT lowering springs ? rikdrt1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 10-31-2012 06:15 PM
