Old 06-16-2013, 03:52 PM   #99
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
I was thinking about getting these as a cheap solution for more camber on my KWs but after reading this thread I think I might just get more expensive camber plates...
Old 06-16-2013, 07:16 PM   #100
BlaineWasHere
Grip>Drift
Drives: FRS
Also, these don't impact ride height correct?
Old 06-16-2013, 09:01 PM   #101
makinen
makinen's Avatar
Drives: Toyota 86
At least for the stock strut, no.
makinen is offline   Reply With Quote
Old 06-16-2013, 09:02 PM   #102
Calum
That Guy
Drives: 2013 asphalt FRS MT
No, they don't. But neither do Group-N.
Old 06-16-2013, 09:04 PM   #103
BlaineWasHere
Grip>Drift
Drives: FRS
I'm gonna put them on KWs, but should make no difference.
What's the Group-N?
Old 06-16-2013, 09:09 PM   #104
Calum
That Guy
It's a subaru made "Group-N" ralley part. Basically it's stiffer then the stock part, which makes a surprising difference, but doesn't have the bearing issues that these have. They don't add camber, but you can get that with some bolts for less then the cost of an alignment.
Old 06-16-2013, 09:22 PM   #105
BlaineWasHere
Grip>Drift
Drives: FRS
I don't need stiffer, I need adjustment!
Old 06-18-2013, 08:59 AM   #106
makinen
makinen's Avatar
Drives: Toyota 86
Originally Posted by feldy View Post
How long is the warranty on these?
look into this link:
http://www.whiteline.com.au/docs/ter...Feb2012COD.pdf
Old 06-20-2013, 12:56 PM   #107
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
The popping is back on the new sets. This time fuck it. Its only happening when pulling backwards out of my driveway. I'm going to use them. The car was fantastic two weeks ago so I'm not making any changes.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
The Following User Says Thank You to feldy For This Useful Post:
Calum (06-22-2013)
Old 06-20-2013, 01:23 PM   #108
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
Not what I wanted to hear.... got my replacements on and so far it's quiet, but it's only been two days. Seems with the other set the rubber was starting to separate from the metal causing air pockets/friction - if it happens again I'm going back to the stock tops, not interested in a suspension failure.
mikalem is offline   Reply With Quote
Old 06-20-2013, 01:35 PM   #109
feldy
feldy's Avatar
Sorry not what I wanted to hear either. The set Jan sent me last 12 days or so before doing it again. Just sent him another email letting him know. These things were made for a imprezza I just dont think they are going to work on the frs. Something needs to change. They mount up but I have yet to talk to anyone thats been problem free.
Old 06-20-2013, 01:42 PM   #110
OrbitalEllipses
Drives: Attitude
Then get a camber plate, which is adjustable and also makes noise. Com-C mounts add static amounts of camber and caster, so perhaps they're not what you're looking for.
Old 06-20-2013, 02:12 PM   #111
BlaineWasHere
Grip>Drift
Drives: FRS
Can you explain this a little further?!? TIA. I really don't want to loose suspension travel that a camber plate will add. I'm very close to the bumpstops on compression.
Old 06-20-2013, 02:18 PM   #112
OrbitalEllipses
Drives: Attitude
You said you wanted adjustment. The Com-C is NOT adjustable, it is shaped such that it locates the strut differently, adding both camber and caster in a STATIC (unchangeable) manner. Furthermore, the solid-mounted nature of camber plates means that they will make more noise as they are metal-metal instead of using rubber to isolate suspension noise/harshness.
If you get proper (non-stack-height altering) camber plates, you will not LOSE suspension travel. You can also cut your bumpstops if you're still using the stock ones. TIC (Turn In Concepts) sells the camber plates you're looking for if you want to NOT lose travel AND adjust camber/caster. @Racecomp Engineering also sells some, but they've been out of stock forever I hear; perhaps Andrew or Myles could better explain what I'm saying.
EDIT: http://www.ft86club.com/forums/showthread.php?t=29567
upgraded mounts? 7thgear Engine, Exhaust, Transmission 19 01-11-2013 11:31 PM
Buyer Beware: Motor Mounts cobrabyte Engine, Exhaust, Transmission 5 01-04-2013 08:14 PM
Autocross Camera Mounts? fritzy BRZ First-Gen (2012+) — General Topics 7 08-03-2012 10:48 PM
SEAT BRACKETS / SIDE MOUNTS - Planted Technology - Font Motorsports Font Motorsports Interior Parts (Incl. Lighting) 2 07-03-2012 06:43 PM
Dash Mounts for gadgets smbrm Cosmetic Modification (Interior/Exterior/Lighting) 0 06-28-2012 07:07 PM
