Old 06-16-2013, 11:39 AM   #505
wootwoot
Drives: FRS
What he said....
Old 06-16-2013, 02:30 PM   #506
ft_sjo
Drives: GT86
Originally Posted by regal View Post
Can you post the rescaled ignition retard tale you came up with to eliminate the knock? This alone would justify buying Brzedit and help a lot of people avoid engine failure.
Replace the load cells in red with -30 degrees or so should see you safe.
Old 06-16-2013, 03:15 PM   #507
s2d4
s2d4's Avatar
Originally Posted by Sithspawn View Post
Not necessarily. If the tuner is not aware of the isse and doesn't correct it, then you would still have the stock Transient Ignition Retard Map and you'd still have detonation on shifts. Period. The ecutek or brzedit software doesn't fix the issue: the tuner must fix it.
So if you do a 4th/5th gear pull to redline, will it behave the same as what you've demonstrated?
Old 06-16-2013, 10:25 PM   #508
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
Everyone is worried about 2-3 3-4 4-5 5-6 gear shifts at wot! But what about 1-2 shifts at wot. This is mainly a concern for those of us that Autocross.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 06-16-2013, 10:40 PM   #509
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
That is because Toyota South Africa has acknowledged that the issue happens on those shifts, and not on the 1-2 shift. Toyota South Africa says the issue only happens above 5200rpm. You have to shift out of first AFTER the redline in order to land in second above 5200 rpm according to the Toyota South Africa TSB.
That TSB shows that you land into third at just over 5200 rpm, but it says the issue is on the 3-4, 4-5, 5-6 shifts, not 2-3.
Sellout is offline   Reply With Quote
Old 06-16-2013, 10:41 PM   #510
sierra
Drives: Skoda Yeti DSG diesel 4x4
Doesn't the ECU reduce the max power in 1st and 2nd gears?
That might reduce this problem?
sierra is offline   Reply With Quote
Old 06-17-2013, 01:52 AM   #511
Traum
Drives: Honda POS
Moto East has a very good ECU tune for the FRS/BRZ. I wonder if this would be enough to avoid the factory ECU tuning's detonation?
Traum is offline   Reply With Quote
Old 06-17-2013, 01:41 PM   #512
spitz
spitz's Avatar
Drives: '13 SWP BRZ-L
They must tune specifically to address the issue or it will still be there.
spitz is offline   Reply With Quote
Old 06-17-2013, 03:47 PM   #513
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
I've NEVER heard of that (ECU "reducing power" for lower gears) outside of vehicles with very specialized motors/purposes (trucks or racing maybe?), would love to see evidence of that in commercial passenger vehicles, would be interesting.
It's considered not an issue because the gap in the ratios is large enough that the rpms fall down below 5200 with the 1>2, 2>3 gear changes, as such the lean condition that results in detonation does not occur. At least that's the "official logic" at the moment.
ineedyourdiddly
Old 06-17-2013, 03:53 PM   #514
ft_sjo
Drives: GT86
I've NEVER heard of that (ECU "reducing power" for lower gears).
Lots of passenger vehicles do. Don't belive the '86 does though. AFAIK it reduces power depending on water/oil temp.
Old 06-17-2013, 04:11 PM   #515
Hanakuso
That's not what they are talking about. That safety feature is in place for regardless of any gear until things are warmed up
Hanakuso is offline   Reply With Quote
Old 06-17-2013, 04:18 PM   #516
ft_sjo
Drives: GT86
I know, I should have used separate paragraphs.
Old 06-17-2013, 04:22 PM   #517
strat61caster
Source?
I'm not saying it doesn't happen, I'd just love to see some evidence aside from "trust me".
ineedyourdiddly
Old 06-17-2013, 05:19 PM   #518
ft_sjo
Drives: GT86
Mazda 3.
Ford Focus ST.
Volvo something.
It's usually to protect the transmission.
We Ask Toyota & Subaru about James May's Claim that Toyota Gets 90% of GT 86/FR-S/BRZ vh_supra26 Scion FR-S / Toyota 86 GT86 General Forum 94 09-15-2013 08:55 PM
Denied service... Chen Northwest 37 09-13-2013 08:37 PM
HELP with diminished value claim! zohare Scion FR-S / Toyota 86 GT86 General Forum 41 04-03-2013 11:17 AM
Hit and Run Insurance Claim CharlieChaos Off-Topic Lounge [WARNING: NO POLITICS] 9 12-26-2012 08:54 PM
Japan loses its claim to "Creepiest Asian Country" reni Off-Topic Lounge [WARNING: NO POLITICS] 3 05-07-2012 11:57 PM
