Old 06-16-2013, 12:01 AM   #449
Foobar
SLO NO MO
Foobar's Avatar
Originally Posted by Dezoris View Post
It comes full from Vortech so I figured why drain the factory fill. But apparently you need to.
Mine came properly filled, but I checked it anyway, per the documentation.
Old 06-16-2013, 12:28 AM   #450
Dezoris
Dezoris's Avatar
My level was perfect as well but still puked some out.
Old 06-16-2013, 08:29 AM   #451
BenArmstrong
BenArmstrong's Avatar
Drives: White GTS, Vortech, Aero kit
Is Vortech or and other vendor supplying this kit to Australia??
I've been talking to Perrin and they say they're no longer shipping the kit overseas due to high shipping costs and breakages.
Personally I'm willing to pay pretty much whatever it takes to get the kit here..
BenArmstrong is offline   Reply With Quote
Old 06-16-2013, 08:58 AM   #452
Foobar
SLO NO MO
Foobar's Avatar
So yours was exactly in the middle of the hash pattern as well? How much oil came out? Was it only during the first run, or did it come out gradually over time?
I'd think Vortech themselves should have no problem doing that, did you reach out to them?
Also, since you're in Australia, have you considered the Bullet/Sprintex kit?
Old 06-16-2013, 02:28 PM   #453
djdnz
1337
Drives: 2013 BRZ WRB S/C
Have you tried www.ft86speedfactory.com
djdnz is offline   Reply With Quote
Old 06-16-2013, 07:49 PM   #454
Dezoris
Dezoris's Avatar
No level was right at top of hash per Vortech instructions. (pdf) It came out after a week of driving. Around vent plug and on top of SC.
Old 06-17-2013, 02:30 PM   #455
draggin_az
Small penis big dreams
draggin_az's Avatar
Drives: '13 Scion FR-S
I did have some stink. Went away quick though. The charge pipes are painted and so is the intercooler probably burning off. My supercharger also burped out oil from the vent plug for a week after. It was to the full line but apparently it was too high I could smell the oil. Check for seepage around that hole.
The oil level on the dipstick should be exactly in the middle of the hash pattern. If it's higher than that, that might explain the oil spewing out and possible causing the smell. Shouldn't be any burning smell coming from the charger pipes or intercooler.
I had oil burp out as well. I called Vortech and they informed the oil level needs to be in the middle of the hash grid. if its full, it'll burp out and you'll get that nice oil on your engine smell.
not to mention its a bitch cleaning it up.
v3 -> v2 Vortech SC / 2.87 pulley
Fuel pump, FIC 770 injectors, custom header back, perrin resonated CBE
277hp 93 octane
370hp on E-85
draggin_az is offline   Reply With Quote
Old 06-17-2013, 02:35 PM   #456
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
Kinda has me worried, would it be a bad idea to put something around the vent pipe to catch some of it for the first day or two?
pheoxs is offline   Reply With Quote
Old 06-17-2013, 02:39 PM   #457
draggin_az
draggin_az's Avatar
theres no need
just drain it to where the oil level is in the middle of the hash marks and you'll be good to go
277hp 93 octane
370hp on E-85
The Following User Says Thank You to draggin_az For This Useful Post:
pheoxs (06-17-2013)
Old 06-17-2013, 02:43 PM   #458
pheoxs
theres no need
Kk Thanks
The Following User Says Thank You to pheoxs For This Useful Post:
draggin_az (06-17-2013)
Old 06-18-2013, 04:34 PM   #459
shu5892001
Ontario's FT86
Drives: 2016 Lexus GS-F
So I have a question about the kit.
Besides the kit, what else is necessary to make this a reliable setup? I guess a oil cooler? What else? Do i really need a catch-can? Do i need fuel pumps and any other stuff?
I plan to DD this.
Thanks
shu5892001 is offline   Reply With Quote
Old 06-18-2013, 04:44 PM   #460
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I plan to DD this.
Thanks
Nothing. No. Nothing. No. No. Buy the Vortech kit straight from Vortech, run their soon to be CARB approved kit and enjoy life.
The Following 3 Users Say Thank You to King Tut For This Useful Post:
Brian@Vortech (06-19-2013), Pete (06-18-2013), shu5892001 (06-18-2013)
Old 06-18-2013, 09:51 PM   #461
SonnyBRZ
SonnyBRZ's Avatar
Drives: 15 WRX 6mt (DD), 13 BRZ Sports Tech
I plan to DD this.
Thanks
Just my opinion and my approach, but i purchased a bigger radiator and an oil cooler to go with the SC. Personally prefer doing everything at once during the install and not have to remove the bumper multiple times which is prone to misalign after. Also, if you ever goto track, your oil temp is within safe range (stock car's oil temp runs very hot already under extended load).
06 Infiniti G35x - Black 5AT (DD)
13 BRZ Sports Tech - White 6spd (June 18, 2012!) - Vortech SC
15 WRX Sport - ISM 6spd - Ordered May 3, 2014
SonnyBRZ is offline   Reply With Quote
The Following User Says Thank You to SonnyBRZ For This Useful Post:
shu5892001 (06-20-2013)
Old 06-19-2013, 01:28 AM   #462
Tradewind
Drives: 2006 Subaru Liberty EZ30 S/charged
CAPA
Ben
CAPA are supplying them. They are located in South Australia
Cheers
Toyota 86 test driver
Tradewind is offline   Reply With Quote
The Following 2 Users Say Thank You to Tradewind For This Useful Post:
BenArmstrong (07-01-2013), Brian@Vortech (06-19-2013)
Vortech Supercharger denverizzles Forced Induction 176 10-19-2013 06:48 PM
New Vortech Supercharging System Information... Brian@Vortech Forced Induction 306 11-08-2012 05:49 PM
Supercharging the GT86 Billy2224 Engine, Exhaust, Transmission 13 06-05-2012 03:58 PM
Turbo/Supercharging Your FRS BoostJunkie Engine, Exhaust, Transmission 123 05-18-2012 06:26 PM
Supercharging: the forgotten form of FI madfast Engine, Exhaust, Transmission 76 03-02-2012 05:06 PM
