Old 06-15-2013, 07:43 PM   #1
slowbrz
Drives: '13 black BRZ MT
How long is Opticoat supposed to realistically last
My detailer was very honest and told me about 2 years. Is this true? Im asking because I eventually want to polish swirlmarks up but dont want to do it while the OC is still lasting
slowbrz is offline   Reply With Quote
Old 06-15-2013, 08:52 PM   #2
Xauterus
Drives: GTS 86 Galaxy Blue
How is there swirl marks when you have opticoat on the car? The means the clear coat has swirls so the opticoat is gone?
Xauterus is offline   Reply With Quote
Old 06-15-2013, 10:00 PM   #3
Vmax911
Drives: WRB BRZ
Or he didn't get the swirl marks out before it was opticoated.
Vmax911 is offline   Reply With Quote
Old 06-15-2013, 11:56 PM   #4
504
504's Avatar
Drives: 2014 86 GTS
I think he meant eventually there will be swirl marks on the car which he would want to polish out later. Opticoat is essentially just another layer of clear coat which is 2 microns thick. If you decide to polish, you will remove the coating. Realistically, if you wash the car the ideal way to minimise swirls I dont see why the coating wont last a good 5-6 years before the swirls eventually accumulate to the point of requiring a polish
504 is offline   Reply With Quote
Old 06-16-2013, 04:17 AM   #5
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Exo lasts as long and is easier to apply. Personally optic coat is a fair bit of hype.
Old 06-16-2013, 04:52 AM   #6
Hawk77FT
Drives: GTS 86
Amen to that. It is really worth it if you do couple of coats. That even won't stop the swirls.
Sent from my HTC One X using Tapatalk 2
Hawk77FT is offline   Reply With Quote
Old 06-16-2013, 05:07 AM   #7
suaveflooder
It makes me laugh that so many put so much faith in opticoat. It's another gimmick! Your car will get swirls.....get over it!
suaveflooder is offline   Reply With Quote
Old 06-16-2013, 07:26 AM   #8
Clembo
'Senior' Junior Member
Clembo's Avatar
Drives: 13 FR-S,08 Mustang Bullitt,06 MX-5
When I read that it can waterspot like regular clear-coat, that was enough for me. It may be harder than many clear-coats (so they say) but it ain't no diamond.
"You'll never know if you don't try" - Shinroko Momose
Clembo is offline   Reply With Quote
Old 06-16-2013, 09:37 AM   #9
Paul_S
Drives: red
Looks like there are a lot of misconceptions about Opti-Coat 2.0 and Opti-Pro in this thread. First these two coatings are basically a sacraficial layer that will eventually get swirls or defects depening on treatment and your wash methods. It will remain on the surface until abraded off. Think of it as a tear-off on a helmet visor or race car windshield. When the coating gets scratched you can abrade it off and replace without removing any original clearcoat numerous times.OEM clearcoat is extremely thin and why remove any when not necessary.For the record I install Optimum plus numerous other coatings. Optimum is my most requested coating but I do explain the pros and cons to customers as I do with all the coatings I offer.Is OC 2.0 a gimmick ? Not in my opinion and thousand of other customers and detailers that are happy with it's performance.Will it outlast EXO ? yep and thats a proven fact. Ask the manufacturer of EXO. . If a installer claims that Optimum coating will be gone in two yrs then he is incorrect. Will it be swirled up by then ? Yes if not properly cared for. So if ease of maintaining and being clean is you goal , a coating is a good choice. And Optimum is a leader in this field at this time but other companies are coming out of the wood work and this could change at any time. IMO.
Paul_S is offline   Reply With Quote
Old 06-16-2013, 11:08 AM   #10
Type[R]+
Type[R]+'s Avatar
Drives: Lexus IS-F
BS! Exo lasts months at best. It is a short lived hybrid coating that has no chemical resistance what so ever.
Type[R]+ is offline   Reply With Quote
Old 06-16-2013, 03:23 PM   #11
suaveflooder
This is exactly my thinking. Cool idea, and I totally get that it's harder than traditional clear, but it suffers all the SAME problems that clear does. Not worth it to me. Sorry. I'll stick with just the paint and some good wax. Then go spend that money I saved on suspension mods
Old 06-16-2013, 04:12 PM   #12
Touge86
Touge86's Avatar
Drives: 2013 DGM BRZ M/T
I got my car opti-coated by James at Sunset Detailing... since then I've adopted a pretty refined 2 bucket wash system with foam gun for pre rinse... No swirls.
You can still get swirls/water spots/bird shit/rock chips on your paint with or without opti-coat. IMO opti-coat simply makes the cleaning process easier and helps significantly reduce the chance for swirls to appear on your paint.
Touge86 is offline   Reply With Quote
Old 06-16-2013, 07:37 PM   #13
Greg Nichols
Paint Correction Guru
Greg Nichols's Avatar
Drives: F150 Platinum
How do swirls happen? Poor washing and drying techiques, as well as QD techniques. Its not all that hard to reduce the chance of marring/swirls. Do some searching online about DI water systems, 2 bucket methods, foam guns or cannons....
What is the durability of OC 2. I had it for 33 months on my car. Think about how much it costs to wax a car twice a year at min vs. coating the car for almost 3 years!
Is this coating hype, if you haven't used it you won't know either way. You can look online for documented cases of people testing it for themselves.
Will the coating water spot? It will as will any other coating out there, its not because of the coating its because of the minerals that are left behind when the water evaporates off. The KEY POINT is that the minerals won't etch into the paint. If minerals are left behind you can use vinegar, CLR, or water spot remover and THE OC 2 WILL NOT COME OFF. When you get iron filings in your paint you can use and Ironizer to remove them and THE OC 2 WILL NOT COME OFF.
Is OC hard to apply? Its one of the easier to apply, other need curing lamps, or sunlight and most want two coats applied. Like most things the time is in the prep of the surface.
Can OC/OP get swirls? Duh yes by you putting them in there, is the coating harder than the clear coat yep, but its not a coating of diamonds. LIke paul stated you can use a fine polishing in most cases and remove towel swirls and the coating stays put, is it reduced.... yes but still does the job.
Right now OC is the easiest, high durabiltiy, and economical of all the coatings out there. I do lots of and lots of testing. So if you like waxing your car every 4-6 weeks, and swirls don't bother you....then don't change your habits.
I hope this helped answer or put to bed many of the misconceptions about Opti coat or Opti Pro.
Cheers,
GREG
Reflections Detailing of Utah
"Detailing for the discerning owner"
Meguiars/Ford detailing team SEMA 2010 and 2011
Ask a pro blog writer for detailed image
duPont Registry approved detailer
Greg Nichols is offline   Reply With Quote
Old 06-17-2013, 02:13 AM   #14
OICU812
Just a dude
OICU812's Avatar
And for those that park outside and dd with optician same can be said....touche'
I've asked more then a few professional shops nearby which they suggest as they apply both and they themselves have said they have seen easily as good results with exo vs opticoat and they're not back yard shops either...
Not much matter to me I park in garage anyhow so either would last long, I just get amused at how many folks think opticoat is the holy grail and misconceptions on its durability etc...
Opticoat best way to go Markone AUSTRALIA 22 03-05-2022 05:06 AM
Uhhh.. Is this supposed to happen? husker741 Issues | Warranty | Recalls / TSB 5 06-14-2013 11:54 AM
Cinco de Slamo Meet in Long Beach NY (Long Island) whitefrs New England 11 05-01-2013 09:03 AM
BMW F30 OptiCoat by Hamza7 Hamza7 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 0 10-18-2012 08:58 AM
Realistically, how difficult will it be to get one this year? eifer Scion FR-S / Toyota 86 GT86 General Forum 15 05-21-2012 05:46 PM
