Old 06-14-2013, 10:48 AM   #71
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
that basically what i'm running! but i think you have 5mm more of tire. which really isn't anything special.
+45 would be sunk unless you run 0 camber.
you're on coilovers or just springs, this should fit like a glove!
Jive Turkey is offline   Reply With Quote
Old 06-14-2013, 11:05 AM   #72
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I would rather have sunk then rubbing. I am on BC coilovers.
Sportsguy83 (06-15-2013)
Old 06-15-2013, 02:07 AM   #73
humanshield
Drives: bucket
love this WRB. looks amazing.
humanshield is offline   Reply With Quote
Old 06-15-2013, 11:08 AM   #74
ebphoto
Drives: FR-S, NA8, S13
car looks soo good..
need to shoot soon.
ebphoto is offline   Reply With Quote
Old 06-17-2013, 10:20 AM   #75
King Tut
NASA SpecE30 Racer
King Tut's Avatar
need to shoot soon.
I'm waiting on you. Reminds me I need to post the shots from Summer Stance. Will do that today.
Old 06-17-2013, 10:27 AM   #76
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Pics of the car at the Summer Stance meet with the new Advans:
The Following 3 Users Say Thank You to King Tut For This Useful Post:
nix (06-18-2013), Sportsguy83 (07-09-2013), sprintertrueno86 (06-18-2013)
Old 06-17-2013, 10:37 AM   #77
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
MONSTROUS--looks awesome!
* ‘23 Corolla GR—AutoX/DE toy
* '13 Toyobaru P&L Turbo WRB BRZ SCCA XS-A build starting. SOLD
* '22 Z51 Vette--sold.
* '09 Nissan GT-R--gone, but not forgotten... 10.63 @ 131+ on streeties.
* '90 ZR-1 11.0 @ 130.2 & 11.2 @ 132.4 sprayed 120 shot.
GTB/ZR-1 is offline   Reply With Quote
Old 06-17-2013, 10:51 AM   #78
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Damm the car looks good.
FullBlown is offline   Reply With Quote
Old 06-18-2013, 10:00 AM   #79
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Thanks LJ. It is getting there.
Old 06-18-2013, 11:01 AM   #80
GuerillaRacing
GuerillaRacing's Avatar
Drives: Scion FR-S
Holy cow, this build rocks! And for it to be close to us in Jax -- we might have to check this out in person!
GuerillaRacing is offline   Reply With Quote
Old 06-18-2013, 11:25 AM   #81
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Love the WRB BRZ and everything you've done with it. It is extremely clean, everything looks right and a little understated (I like it), and all the decisions on which parts to use seems to complement each other. Well done my friend.
mit_peid is offline   Reply With Quote
Old 07-22-2013, 10:05 AM   #82
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Wanted to update this thread with my opinons on the Full Blown oil cooler kit. The majority of the pieces are off the shelf Mocal items and your standard AN oil lines. The only truly custom piece is the mounting bracket for the outside of the oil cooler that connects under the passenger side headlight. This is similar to the Perrin kit that only contains stand offs for the bottom of the oil cooler. I was e-mailed a set of directions, and they had good pictures that made sure I knew where things were supposed to go and made recommendations such as using high temp sealant on the fittings going into the oil cooler instead of teflon tape (which I usually use).
You will need to take special care when mounting the oil cooler to make sure that you leave clearance for the driver side fitting on top of the oil cooler. It is very close to the bracing that comes out and holds the bumper bar. I would recommend you install the fittings on to the oil cooler before mounting it and tightening everything down. The driver side of the oil cooler mounts to a hole in the bottom radiator core support. That happens to be the hole that the Full Blown turbo kit uses to remount the horn. The instructions didn't mention that, but I just relocated it to the bolt that holds the A/C condensor to the radiator. The only real downside to the kit was that both oil lines were about a foot too long. I had to take each AN fitting apart and cut the lines to the proper length and reassemble. Since the kit tells you exactly where to run the lines, I would have expected them to be the correct length, but I understand a little flexibility for possibly needing to modify that routing. At the end of the day, the kit fits great and had no leaks:
Old 07-22-2013, 10:09 AM   #83
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Here are the final dyno numbers for my car with what Toni @FA20Club.com could do with it. I set my EBC back to wastegate pressure and Toni got started. We did about 6 runs and had beat those numbers at less than 10 psi. Then we started turning up the boost and ended up with some great numbers at 12.5 psi. I was super happy with the results, the torque curve was huge and flat, and Toni had beaten my goals which were 300 hp and 240 ft-lbs. The final results of the day were:
322 hp
265 ft-lbs
12.5 PSI
Dynojet SAE Corrected
The dyno runs were all done in 90F degree heat with typical Florida humidity and rain showers throughout the 3 hours the car spent on the dyno. Now on to everyone's favorite part. DYNO PLOTS!!!
Dyno Plots:
First up we have a comparison of my @Visconti tune and the final @FA20Club.com tune:
You will see that Toni beat John's tune pretty much everywhere with less PSI. The only real advantage of John's tune was that it uses a lean spool and was making about 1 PSI more before peak boost. Here is a comparison of the boost and AFR curves:
You will note the weirdness in the boost curve at around 6000 RPM. These logs are from my AEM Failsafe gauge, and it always seems to have these weird areas where it gives results like that, but my EcuTek logs normally don't show those large swings in boost.
Videos:
[ame="http://www.youtube.com/watch?v=dctrsYvPTGE"]King Tut's Subaru BRZ Full Blown Turbo FA20Club.com Dyno - YouTube[/ame]
akuhei (07-22-2013), GTB/ZR-1 (07-22-2013), Sportsguy83 (07-22-2013)
Old 07-24-2013, 02:11 PM   #84
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Here you go @Sportsguy83 . This is what you don't want to do, add up the costs. Here are the majority of the costs to duplicate my car (approx):
Full Blown Turbo Kit $4,900
Full 08-12 STI Brake Swap $2,200
Advan RG-D 18" Wheels $2,800
Michelin Pilot Super Sports $1,000
BC Coilovers $900
EcuTek Cable and License $625
Visconti Tune $600
FA20Club.com Tune $500
ACT Clutch and Flywheel $600
Detail and Optiguard $675
FBM Oil Cooler $600
FBM Radiator $300
APR Brake Cooling Vents $300
GFB Electronic Boost Controller $300
Cusco Rear Camber Arms $525
JDL Overpipe and Midpipe $450
RAYS Lugs and Advan Center Caps $350
AEM Wideband/Boost Failsafe Gauge $300
D3PE Catch Can $300
Perrin Antenna, Bushings, and Shift Knob $180
PTP Turbo Blanket $150
MSL Single Gauge Pod A Pillar $100
TOTAL $18,655
The Following 2 Users Say Thank You to King Tut For This Useful Post:
humanshield (08-01-2013), Sportsguy83 (07-24-2013)
brz, king, limited, subaru, tut
Alex's 2013 WRB Subaru BRZ Limited Alex Member's Car Journals 51 01-03-2014 03:43 AM
2013 Subaru BRZ Limited Long-Term Test - InsideLine brianc BRZ First-Gen (2012+) — General Topics 0 08-01-2012 07:18 AM
2013 Subaru BRZ Limited Start Up, Exhaust, and In Depth Review delta86 BRZ Photos, Videos, Wallpapers, Gallery Forum 1 06-26-2012 03:25 AM
xcelir8brz's - 2013 Subaru BRZ Limited xcelir8brz Member's Car Journals 4 06-03-2012 05:44 PM
