Old 06-13-2013, 07:02 PM   #421
415FRS
Drives: Red SCion FRS
Where is this rubber hose goes? Why it is so long? Do i suppose to cut it out?
Sent from my HTC One using Tapatalk 2
415FRS is offline   Reply With Quote
Old 06-13-2013, 07:21 PM   #422
Foobar
SLO NO MO
Foobar's Avatar
Brake booster vacuum line to bypass valve?
Sent from my Nexus 4 using Tapatalk 2
The Following User Says Thank You to Foobar For This Useful Post:
415FRS (06-13-2013)
Old 06-13-2013, 08:14 PM   #423
415FRS
got it figured out. ) thanks
Old 06-14-2013, 02:47 PM   #424
415FRS
Got everything installed but now the car would not start....
Old 06-14-2013, 03:12 PM   #425
reyruiz191
reyruiz191's Avatar
Drives: 2013 FRS Vortech Supercharged
What's going on when you try to start it? Did the tune upload successfully?
reyruiz191 is offline   Reply With Quote
Old 06-14-2013, 03:12 PM   #426
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Is your MAF sensor plugged in? Did you change the MAP sensor with your kit? Did you flash the ecu?
Old 06-14-2013, 03:58 PM   #427
Foobar
SLO NO MO
Foobar's Avatar
Need more input.
Old 06-14-2013, 04:00 PM   #428
415FRS
Everything is plugged in. I also changed the MAP sensor. And flash the file that john sent me before I tried to start the car.
Old 06-14-2013, 04:03 PM   #429
415FRS
Yes the flash was successful. The engine makes the noise like it should when I turned the key but that is it.
Old 06-14-2013, 04:06 PM   #430
415FRS
I skipped step 5 cutting the harness extension in the Vortech instruction since the cable was long enough.
Old 06-14-2013, 04:41 PM   #431
Foobar
SLO NO MO
Foobar's Avatar
So the starter is cranking but the engine won't run or is the starter not cranking at all? If it's not cranking, you might need to top off the battery with a jumper.
If it's cranking and the engine's not running, then perhaps you're not getting fuel or air through. All the hoses are connected to the right points, and the check valve is facing in the right direction? nothing's blocking the intake path and you reconnected any harnesses that you had to unplug? Did you install upgraded injectors/fuel pump or is this stage 1?
Because the kit came with the new MAF harness extension that's already wired up and plug-n-play, right?
415FRS (06-14-2013)
Old 06-14-2013, 05:53 PM   #432
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Anyone has the dimensions for the Vortech Intercooler? Trying to gauge if the Koyo Rad will fit with AVO kit and it will depend how the Vortech IC dimensions compare to the AVO one.
@Dezoris
Old 06-14-2013, 06:18 PM   #433
Dezoris
Dezoris's Avatar
@Dezoris
I never measured the Vortech IC. Sorry. I may have my bumper off again for about the 20th time so if thats the case I will measure.
The Following User Says Thank You to Dezoris For This Useful Post:
Sportsguy83 (06-14-2013)
Old 06-14-2013, 06:21 PM   #434
Dezoris
Dezoris's Avatar
If it is not starting it's probably related to the MAF either not being plugged in correctly or disconnected. Check the down pipe boost tube passenger side and make sure that MAF from your stock intake was moved to that tube properly and installed, also connected.
Also make sure you have zero air leaks after the MAF or you will stall.
I blew that tube off after my first installed because the tube was damaged and would not hold a good seal and the car stalled and would not restart.
415FRS (06-14-2013)
Vortech Supercharger denverizzles Forced Induction 176 10-19-2013 06:48 PM
New Vortech Supercharging System Information... Brian@Vortech Forced Induction 306 11-08-2012 05:49 PM
Supercharging the GT86 Billy2224 Engine, Exhaust, Transmission 13 06-05-2012 03:58 PM
Turbo/Supercharging Your FRS BoostJunkie Engine, Exhaust, Transmission 123 05-18-2012 06:26 PM
Supercharging: the forgotten form of FI madfast Engine, Exhaust, Transmission 76 03-02-2012 05:06 PM
