Old 06-14-2013, 01:10 AM   #449
Bach415
Bach415's Avatar
Drives: Whiteout FRS
Originally Posted by HRTROB View Post
The Unichip does not disable the CEL.
Just use an angled o2 sensor cable and call it a day.
An angled o2 sensor spacer would work as well right?
Bach415 is offline
Old 06-14-2013, 03:57 AM   #450
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Oops I meant spacer, not cable. Edited my post
HRTROB is offline
Old 06-14-2013, 09:30 AM   #451
sinigang_guy
sinigang_guy's Avatar
Drives: argento frs; 90 mustang gt
wonder if i installed mine incorrectly.. still throwing the cel at least once a week.
ive an angled spacer from bigdaddiesgarage. i screwed it in close to bottoming out the spacer, then tightened the secondary nut on it. should it be higher?
sinigang_guy is offline
Old 06-14-2013, 01:12 PM   #452
HRTROB
HRTROB's Avatar
Drives: Toyota 86
The angled spacer I got was a bit long, so I wasn't able to screw it in that much since the header to overpipe flange was in the way. I just used the secondary nut to tighten it down. If you're still gettig a CEL, maybe you can try backing off the spacer a bit?
HRTROB is offline
The Following User Says Thank You to HRTROB For This Useful Post:
sinigang_guy (06-16-2013)
Old 06-16-2013, 02:34 PM   #453
sinigang_guy
yup, will have to try this until im able to get a tune..
Old 06-16-2013, 03:21 PM   #454
sinigang_guy
Originally Posted by ft_sjo View Post
Is that just the perrin catback and the header, no overpipe/mid-pipe etc? Any other videos of it under load? Sounds pretty awesome on that vid, want more!
yup, just the borla manifold and perrin catback. 2 other pipes are stock.
working on in-cabin and outside samples..
Old 06-17-2013, 01:17 PM   #455
DJCarbine
Thupercharged
DJCarbine's Avatar
Did anyone hear about the even more recent tooling changes?
I'm waiting on my third header, and they said that the newest tooling batch was completed on 6-7-2013....
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline
Old 06-21-2013, 03:48 PM   #456
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
That was for the flange fix. Those have all gone out by now.
FT-86 SpeedFactory is offline
Old 08-16-2013, 02:38 AM   #457
6speed_Sam
Thumper
6speed_Sam's Avatar
Drives: 2013 FRS
I just ordered this header from you guys. I haven't quite found a video of my setup.. borla uel, perrin resonated catback, invidia catless front pipe, motiv overpipe. Which of your setups that you have tested would sound most like this...in your opinion?
Just cant seem to find one with the combo of resonated catback/catless front pipe with the header.
Car is gone - parts for sale
6speed_Sam is offline
Old 08-20-2013, 04:32 PM   #458
FT-86 SpeedFactory
Probably closest sound will be our V1 videos. The V1 is a bit deeper but close to the perrin.
Old 08-20-2013, 10:54 PM   #459
6speed_Sam
Thumper
6speed_Sam's Avatar
Drives: 2013 FRS
Just got it installed! Everything was super simple and... OHHH that sound! LOVE it!
Only one issue. I torqued everything down to spec...even made sure the flanges looked straight and were clean. The header is making a weird sound. As I've seen someone describe it as a tinny(not tiny) sound..not quite like a hissing leak, though. I've only made one 10 minute trip it in but it does it whenever on the gas. It's especially noticeable in the first few gears. I'm hoping it's not a leak but just that the metal is thin. It's not a pleasant sound.
Also, the pipes at the first o2 sensor are about touching...its a tight enough fit that you cant push a piece of folded paper through it.
Old 08-20-2013, 10:57 PM   #460
Taber
Drives: 2013 BRZ Limited
I just installed my UEL Borla's today as well, I dont have this sound though.
Taber is offline
Old 08-20-2013, 11:00 PM   #461
6speed_Sam
Thumper
6speed_Sam's Avatar
Drives: 2013 FRS
I hope I can figure it out. I won't be able to keep it like that.
Old 08-20-2013, 11:01 PM   #462
FT-86 SpeedFactory
Hard to say without hearing it first hand. The walls of the header due to thinness will create some extra noise that may fit this description. I'm half deaf anymore though..
Borla UEL Header, any dynos yet? FR-S Matt Engine, Exhaust, Transmission 111 05-16-2016 10:31 PM
AEM Tuned Intake - Pics / Videos / Dynos - FT-86 SpeedFactory Review FT-86 SpeedFactory Engine, Exhaust, Transmission 136 11-05-2015 08:48 AM
Fortune Auto - SpeedFactory Review - Video / Pics - Tracked / Autoxed / Drifted FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 47 01-29-2015 10:15 PM
Buddy Club Spec II - FT-86 SpeedFactory Review - Photos and Videos FT-86 SpeedFactory Engine, Exhaust, Transmission 35 03-17-2013 11:46 PM
