Old 06-07-2013, 04:58 PM   #85
d1ck
Drives: Black 2013 FRS
Originally Posted by Calum View Post
Could you post a link to where it says that we're supposed to use those washers?
I can't, but I remember reading somewhere that it is necessary to prevent interference with the purple spring cup and the rubber of the whiteline mount. It's a beveled washer which ensures that only the centre of the bearing is in contact with the strut.
d1ck is offline   Reply With Quote
Old 06-07-2013, 05:02 PM   #86
OrbitalEllipses
Drives: Attitude
Only required if you're not using the OEM upper spring seat/perch/black thing.
ATL BRZ (06-07-2013)
Old 06-10-2013, 07:36 PM   #87
qtwre
Drives: White FR-S
So is the answer to these problems in the washer? Can someone in-the-know tell us which washer we should be purchasing?
Thanks much.
qtwre is offline   Reply With Quote
Old 06-10-2013, 08:24 PM   #88
OrbitalEllipses
Drives: Attitude
Thanks much.
Read my post. The washer is for those NOT using OEM size springs (RCE Yellow, Hotchkis, Eibach, most any lowering spring). If you have a threaded body coilover, you need these.
Old 06-10-2013, 11:30 PM   #89
qtwre
Drives: White FR-S
Right, I have coilovers. Just wondering what the washer is called so I can order a couple.
Old 06-10-2013, 11:32 PM   #90
OrbitalEllipses
Drives: Attitude
In Subaru circles it is simply referred to as the conical washer; the P/N should be enough to order.
I see you're in Canuckistan, not sure if your P/Ns are the same or not.
MAKE SURE YOU GUYS USE the GD CHASSIS OEM CONICAL WASHER on the fronts. These go BETWEEN the top PERCH and the mount( OEM, Group-n or COM-C).
[IMG][/IMG]
whataboutbob (08-05-2013)
Old 06-11-2013, 10:56 AM   #91
d1ck
It is the same. a little pricey at 10 bucks each though.
Old 06-11-2013, 12:45 PM   #92
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
After almost 300 miles and 8 runs on a autocross course sunday everything is still fine.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
The Following User Says Thank You to feldy For This Useful Post:
Calum (06-11-2013)
Old 06-11-2013, 05:38 PM   #93
wootwoot
Drives: FRS
Sweet! Keep us posted.
Old 06-13-2013, 11:38 PM   #94
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
mine are fine. but the drivers side just makes all kinds of noises.
Jive Turkey is offline   Reply With Quote
Old 06-14-2013, 01:56 AM   #95
wootwoot
Drives: FRS
Well then they are not fine... Are they?
Noise is an issue. They should not make any noise over stock IMO.
The Following User Says Thank You to wootwoot For This Useful Post:
Calum (06-14-2013)
Old 06-14-2013, 09:08 AM   #96
makinen
makinen's Avatar
Drives: Toyota 86
My warranty replacements are coming from Australia.
I wonder how can I manage to install them successfully at this time.
makinen is offline   Reply With Quote
Old 06-14-2013, 09:17 AM   #97
apexaddict
For the sake of collecting data, I had a set of the early model (non-Koyo bearings, no dust covers) last about 9k miles, and they just recently went kaput. Getting a new set under warranty.
Andrew P.
#14 STX Scion FR-S - powered by Stranoparts and Moto-East
apexaddict is offline   Reply With Quote
Old 06-14-2013, 12:02 PM   #98
feldy
feldy's Avatar
How long is the warranty on these?
upgraded mounts? 7thgear Engine, Exhaust, Transmission 19 01-12-2013 12:31 AM
Buyer Beware: Motor Mounts cobrabyte Engine, Exhaust, Transmission 5 01-04-2013 09:14 PM
Autocross Camera Mounts? fritzy BRZ First-Gen (2012+) — General Topics 7 08-03-2012 11:48 PM
SEAT BRACKETS / SIDE MOUNTS - Planted Technology - Font Motorsports Font Motorsports Interior Parts (Incl. Lighting) 2 07-03-2012 07:43 PM
Dash Mounts for gadgets smbrm Cosmetic Modification (Interior/Exterior/Lighting) 0 06-28-2012 08:07 PM
