Old 04-16-2013, 05:11 PM   #155
DriftEm
DriftEm's Avatar
Great write up
After reading all the trouble some folks were having getting the crack bolt off, I was surprised how easy mine came off. It took me 5 minuets to finish the install (I have a Perrin CAI installed so no stock air box to remove)
DriftEm is offline   Reply With Quote
Old 04-17-2013, 07:38 PM   #156
ramiram1984
Drives: 2016 STi DGM
This is great. Ordered 3 pulley set from Tomioka and am pretty sure this DIY will help me install the pulleys.
Unless, someone else has done this. Don't see any issues though.
Sam
ramiram1984 is offline   Reply With Quote
Old 06-04-2013, 11:01 PM   #157
200hp/tonne
200hp/tonne's Avatar
Drives: Raven Fr-S
Originally Posted by 2point0 View Post
Is this before or after you replaced the frayed belt?
I installed a pulley this past week and notice what sounds like gear whine. Searching hasn't yielded much result, but my best guess is that the lighter pulley transmits more NVH. This sound is directly related to engine speed and not the car speed. In or out of gear, it is noticeable at around 2500 RPM and higher. Seriously sounds almost like a supercharger, but once the revs get high enough, the exhaust (Nameless axleback) drowns it out.
Nothing else seems to be affected, the pulley doesn't wobble and I've seen no leaks. All Subarus make funny noises anyway, so I'm not freaking out. Just looking for a little validation in my life.
Aside from all that, I really like the more natural feel of rev matching. I no longer have to double-blip!
I noticed the whine after my kartboy pulley install as well.
Sounds like straight gear/supercharger whine but low volume and completely rpm dependent, and i thought it was induction noise from my k&n filter. Your post is the only instance of this whine i have found so far.
How many miles have you had the pulley on? Is it still making the noise?
FR-S Mod target: 200 BHp / Tonne
4lb Li Battery, RPF1 17x9, 245 RE71R, RCE T2, OFH, OFT Stg 2, Berk Over+Front Pipe, , STI Eng/Trans Mts, PU Bushings, Forrester Liq-Liq oil cooler, Al Driveshaft, OSGiken Diff
200hp/tonne is offline   Reply With Quote
Old 06-05-2013, 12:33 AM   #158
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
I'm over 21k now, I'll have to look up when I installed that. But several thousand miles, at least. And yeah, I can still hear it but I'm pretty much numb to it now.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
The Following User Says Thank You to 2point0 For This Useful Post:
200hp/tonne (06-05-2013)
Old 06-13-2013, 08:32 PM   #159
Brzzee
Brzzee's Avatar
Drives: 2015 Subaru BRZ WRBP Limited 6MT.
Just finished the install of the Perrin crank pulley.
Thanks for your DIY pictures. Checked here before loosening the pulley bolt.
Two alternatives that others might find helpful.
1. Remove the air filter cover. Leave the air box in place.
2. Use an extension on the breaker bar. I used the handle section (about 36") from my floor jack to give more leverage. Didn't need sneakers to break the bolt loose. ;-)
Thanks for the great help.
- When men make plans the gods laugh.
Brzzee is offline   Reply With Quote
Old 06-13-2013, 11:13 PM   #160
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
I did this too!
The Following User Says Thank You to continuecrushing For This Useful Post:
Brzzee (06-14-2013)
Old 06-29-2013, 08:09 AM   #161
SciOnDrifTtSlIdeR
Drifter
Send a message via MSN to SciOnDrifTtSlIdeR
This was a good read up, I did a full pulley swap on my old 1jz, can't wait to do it to my coming frs.
SciOnDrifTtSlIdeR is offline   Reply With Quote
Old 06-30-2013, 07:04 PM   #162
wdninja
wdninja's Avatar
Drives: 2023 Toyota GR86 Premium
Originally Posted by Teknian_Culprate13 View Post
having trouble with my AT frs, the shops cant even get that flexplate tool, its not available
to independent shops guess ill take it to subaru
http://www.etoolcart.com/subaru-cran...498497100.aspx
2023 Toyota GR86 Premium, Neptune Blue Gasket Ninja.
wdninja is offline   Reply With Quote
Old 07-03-2013, 05:16 AM   #163
Alfalasy
2013 BRZ
Alfalasy's Avatar
Can anyone suggest if it is a good option to use this pulley with the Vortech Supercharger?
Alfalasy is offline   Reply With Quote
Old 07-10-2013, 09:27 AM   #164
jdm-az-fuk
Drives: 2013 Fr-S
great write up
jdm-az-fuk is offline   Reply With Quote
Old 08-02-2013, 04:17 PM   #165
blue_frs
blue_frs's Avatar
Great write up just used it to install mine today
Sent from my DROID4 using Tapatalk 2
blue_frs is offline   Reply With Quote
Old 08-09-2013, 11:38 AM   #166
jx86
Drives: -
To the OP,
You are a life saver, thank you! Was able to smoothly install my pulley in 30 mins flat thanks to your instructions which are far more comprehensive (read: pictures) than the Perrin one.
Was surprising how much force the oem pulley required to remove. For a few seconds I thought my 30" breaker bar was gonna snap!
jx86 is offline   Reply With Quote
Old 08-11-2013, 03:48 AM   #167
BRZ68
Drives: BRZ m/t
Did anybody notice the tensioner vibrating after the pulley install? Not sure if this is a normal vibration with the stock pulley..i didnt notice. The vibration on the tensioner stabilizes when there is throttle. Any input is appreciated. Thanks
BRZ68 is offline   Reply With Quote
Old 08-14-2013, 10:13 PM   #168
CaliaceX
CaliaceX's Avatar
Drives: 2013 Toyota GTS 86
Excellent DIY guide mate I will definately use this in weeks to come when I recieve mine just a question, whats the name of your bumper skirt that sits underneath your exhaust pipes. Will they fit with the Aero bumper skirt? Cheer
CaliaceX is offline   Reply With Quote
brz, crank pulley, diy, frs, perrin, raceseng
Perrin Crank Pulley now available milenko11 Engine, Exhaust, Transmission 96 12-10-2017 06:45 PM
Crank Pulley and the warranty Brimford Scion FR-S / Toyota 86 GT86 General Forum 4 07-08-2012 03:47 PM
Perrin Lightweight Crank Pulley for the BRZ/FRS at Redline360 Redline360 Engine, Exhaust, Bolt-Ons 2 07-07-2012 10:24 PM
