Drives: 86 GT
Drain fuel without pulling half the car apart?
I have searched the forum and found many people asking the same question but no real answer. Some cars have a drain plug on the tank or you could disconnect a fuel rail etc.
I haven't done anything bad to the car, I simply am looking for an easy way to run the car on the dyno on current fuel, drain tank and then fill up with E85 so we can tune that all in the same night. Can anyone advise on the quickest and easiest method to achieve this? If removing rear seats and pulling the fuel system apart is the only way then I won't bother. |
You might try siphoning, or pumping, the fuel out through the filler tube ...
![]() humfrz |
Drives: 1FRS, 1 BRZ, 2S2000s, Evo8, Dak.R/T
Modern cars have anti-siphoning ball mechanisms at the fuel filler neck to discourage fuel theft and spillage in a rollover, so it's typically easier to do with specialized tools/hoses. Here's a video of an electric version that does it:
[ame]http://youtu.be/2mGeb9s6yFE[/ame] You can get simple/cheaper fluid hand pumps at lots of places like car parts stores, Wal-Mart, etc., but they can be really slow...1 gallon every 4 minutes or so. Just BE CAREFUL. Transferring fluid builds up static electricity, so keep static transfer situations to a minimum, (minimize touching metals with bare hands, etc) keep a fire extinguisher handy, (any time you're handling fuel) and work in a space with a good air flow so that fumes can't build up around you and cause an explosion as easily. The car has a low-pressure and high-pressure fuel pump for the 2 sets of injectors that would be ideal for doing the job for you, I'm just not sure how you could tap into the line and let it run the fuel out into a can for you. Maybe someone else can help there...
| The Following User Says Thank You to killboy For This Useful Post: | CB762 (05-23-2015) |
Drives: 13 Subaru BRZ, 02 Audi TTQ
I'm not too familiar with how the fuel system is setup in these but I assume you can pull the supply line off of the high pressure pump and jump the fuel pump relay for the other pump and drain it that way.
[Citation Needed]
Drives: 2014 WR Blue Subaru BRZ Premium
Just disconnect the line before it goes into the fuel rail and jump the fuel pump relay.
| The Following User Says Thank You to Whatabouteggs For This Useful Post: | CB762 (05-23-2015) |
| Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? | tracerit | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 20 | 01-04-2016 08:36 PM |
| Pulling up floor rug? | ndsleep612 | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 12-11-2013 02:23 AM |
| Brz pulling trailer? | subiesteve | Southwest | 7 | 11-20-2013 10:04 PM |
| 94 octane not pulling | Scalzo | Forced Induction | 44 | 10-08-2013 11:15 PM |
| Pulling your FRS off of the lot, what are you bumpin'?? | poormans_LFA | BRZ First-Gen (2012+) — General Topics | 201 | 06-09-2012 10:52 PM |
