09-19-2022, 06:00 PM | #11229 |
Drives: 14 FRS Monogram, 05 Mazdasped Miata
My Borla header and Werks free-flow cat front pipe made a noticeable difference, but I was already running E85 by then. If I had a gen 2 I would probably consider a real SC, but mine has a build date of 1-14 and I suspect that engine is not as robust as later models.
10-11-2022, 12:20 PM | #11230 | |
10-11-2022, 01:01 PM | #11231 |
Drives: FR-S,GTI
No
It's still at the machine shop. Going on a month now. I dropped it off on a Friday. Gave them a week unharassed. Called them the next Monday and they didn't know what I was talking about. Turns out I went to the wrong shop. The right one is down the street. So I went to the shop I left it at and the guy says "Oh he's on vacation this week." Well I wish he would have told me that. Next week he was too busy on other things. Next week there's a hurricane. Called them yesterday and he said he would do it tomorrow. Well, now tomorrow is today. I'm getting tired of this. Why is it so hard to get anybody to do anything anymore? |
10-11-2022, 02:45 PM | #11232 | |
Drives: frs
The Following User Says Thank You to Teseo For This Useful Post: | Target70 (10-11-2022) |
10-11-2022, 03:48 PM | #11233 |
10-14-2022, 09:45 AM | #11234 |
Drives: FR-S,GTI
Just a quick observation. If you unplug the connector to the activation switch, it runs continuously. I ran the thing in a vice and it would make one hell-of-a leaf blower. This thing is scary.
I'm putting it all back on the car today. My hopes are high. Let you know how it goes. |
10-14-2022, 12:03 PM | #11235 |
Drives: FR-S,GTI
Got it all back together and on the car.
Butt dyno says it works good as new. YAY. The new modified wheel fit almost perfectly. It fit super tight. Tight enough that it rubbed the housing a bit. My first idea was to just run it and bed it in. But I figured I've come too far to fukitup now. So I painted the housing, spun it, and sanded where it rubbed. The biggest pita was the snap ring that holds it all together. Played with that for awhile. The other pita is mounting the switch on the gas petal. I'll do that later. Had one casualty along the way. I dropped the machinist's vice on the bumper testing it. Made a nice new gouge. Anyway, I'll do a log tomorrow morning when it's cooler. I'll record boost, atmospheric pressure, temperature, RPM, and speed. |
10-15-2022, 09:46 AM | #11236 |
Drives: FR-S,GTI
I'm declaring it fixed.
Did a third, forth, fifth run and it feels great. Running in 6th gear it consistently hits 4.6 with intake temperature of 89 degrees. Not bad. And it costs less than 200 bucks to fix. Next up, I'm going to replace the controller fan. I don't usually fix things that ain't broke. But I'm making a special exception for this. By all rights it should have failed years ago. |
10-15-2022, 01:11 PM | #11237 |
Drives: FR-S,GTI
Well,
I was right about the controller fan. Maybe it did fail years ago. Or maybe this morning. All I know is it doesn't work now. The part number is: Gdt 6020s which of course is no longer available. I ordered a Wathai 6025B12V2P2.5 from Amazon for $8.99. Should be here tomorrow. Under an abundance of caution I decided to turn it off until I get the new fan. Just got the damn thing fixed and now I'm going to turn it off. Jeez |
10-16-2022, 06:54 PM | #11238 |
I'll try to trace back your posts and make a list of the parts, numbers and modifications, unless of course you feel charitable and post them yourself. We all owe you a great debt for this blueprint for repair.
10-17-2022, 10:15 AM | #11239 |
Drives: FR-S,GTI
I replaced the controller fan. At first I didn't think it really did anything because the controller gets too hot to touch even when it's off. Just from the heat from the engine. And the way it works is pretty hokey. It blows air toward the controller. It's spaced off by two nuts and blows air into the controller though a filter material covering holes through the box. Very strange. but after driving around for a while, it does stay cool now. So I guess it works.
10-17-2022, 10:29 AM | #11240 |
Drives: FR-S,GTI
Now that I have a basic understanding of this thing I'm thinking about building my own.
I know the compressor is from a Cummins 11 liter diesel engine and I know the spec on the motor. I'm thinking it might be cool to make a 36 volt system. Since the motor speed is directly proportional to the voltage, I'm thinking that 36 volts should be good for 75,000 rpm which should be good for 7.5 lbs of boost. I think it would be worth trading some duration for more power. In normal driving I've never run out of boost with 24 volts. In reality you're never going to be boosted for more a few seconds on the street unless you want to go to jail and forfeit your car. This thing is great. Everybody should have one! |
10-17-2022, 11:42 AM | #11241 |
Drives: FR-S,GTI
I found THE motor! Check this out! 85,000 rpm! And these guys will custom build whatever you want!
https://www.tppowerusa.com/index.php...product_id=575 |
10-17-2022, 02:06 PM | #11242 | |
In my case, part of the appeal is the 5lb boost since I have a 2014. I might go for more boost If I had a later model with what I suspect have been several engine improvements, both known and unknown. |
Similar Threads | ||||
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 04:45 PM |
Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 06:43 PM |
86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
