Old 01-01-2013, 07:43 PM   #57
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
Originally Posted by MaXimus View Post
The whole metal bar is in the way. I've already soldered on the tabs of the headunit and faceplate. The headunit will be in the original location but the face will be mounted down in the pocket at the bottom. Just haven't decided if I wanna hack up the original pocket or do the cardboard cutting thing like the dude in Korea.
Cat5e to couple the headunit and faceplate together. I'm not sure about the nexus 7 anymore since I've done some testing and 3G is super shitty in this country. Plus the fact I've upgraded the sound system and streamed content sounds shitty.
Thanks for the pics, I don't think I'll have any problems just eliminating that metal bar, I was thinking it was something way worse than that in the way. FR-S is supposed to be here in a week so need to find a wiring kit soon to do the single din install and then hopefully a spare faceplate to fibreglass a touchscreen/tablet into
pheoxs is offline   Reply With Quote
Old 01-02-2013, 09:40 AM   #58
pezzie
Drives: Brz
has anyone actually tried to remove the metal bar? without cutting it off, but just unscrewing it or something?
or is it a permanent metal bar to support something?
i've been looking at this thread.
http://www.ft86club.com/forums/showthread.php?t=8336
and it looks like the metal bar isnt there, or i just cant see it in the photos.
I wish I had the car already so I could have a look myself
pezzie is offline   Reply With Quote
Old 01-02-2013, 06:48 PM   #59
pheoxs
That's really interesting ... in those pictures it isn't there at all unless its just the angle hiding it. Would be great to see if its removable instead.
Old 01-04-2013, 10:25 AM   #60
MaXimus
Meh!
MaXimus's Avatar
Drives: Satin White, 86, Manual
Problem is that everything seems to screw onto that metal bar. So you might end up with creaks from the dash if you cut it. I don't use CD so why not just relocate the faceplate.
MaXimus is offline   Reply With Quote
Old 01-04-2013, 06:47 PM   #61
xjohnx
Grip>Slip
xjohnx's Avatar
How difficult was the soldering?
Old 01-06-2013, 11:25 AM   #62
MaXimus
Meh!
MaXimus's Avatar
Umm I have tipped the faceplate and headunit but not done the wiring bit yet. It pretty easy but I'd recommend you tip both wire and headunit before soldering to avoid heat transfer. Plus you should apparently use untwisted pair cat5e. Not sure why though.
The Following User Says Thank You to MaXimus For This Useful Post:
CxG (04-01-2017)
Old 01-06-2013, 03:33 PM   #63
i_4got
i_4got's Avatar
Drives: Whiteout FR-S
Originally Posted by Yobiwan View Post
actually . lower place is very small. & real problem is that some strong steel
frame(?) is blocking inside . So if you want normal size 1 din receiver , you must cut that off. that one of above picture is normal size receicer so I cut some steell inside. It was very very very painful job.. car & my heart is hurting... =(. I can't recommend this style.
BTW there is Small size( 3/5 size depth) media receiver from SONY.. DSX-A30 ( it is asian name, I dont know it is available in USA ). & someone of my country
use A30 for lower place install. & He said that was piece of cake, no need to cut anything. like bolt on. ..
but it's media receiver so you can't use CD .
sorry for bad english =). I hope this helpful
Can you take a few more pictures of your interior? I want to wrap my interior trim pieces in red too, but I'm not sure how it would look after it's done.
Thanks!
i_4got is offline   Reply With Quote
Old 01-06-2013, 03:48 PM   #64
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
If your referring to UTP CAT5 it Unshielded Twisted Pair, not "untwisted pair". I have no idea why it would matter if it were shielded or not.
Old 01-06-2013, 10:46 PM   #65
MaXimus
Meh!
MaXimus's Avatar
Me neither, I know guys have had issues with using printer cables n stuff like that. I don't think it should be an issue since I'm only going to need 12-14in extension. One thing I hate is that the face plate connector is 20 pins.
Old 01-22-2013, 06:52 AM   #66
Hydro
Drives: Megane 2
Any news on ELA release ?
Hydro is offline   Reply With Quote
Old 01-27-2013, 03:28 AM   #67
FSUnoles
FSUnoles's Avatar
Drives: Scion Tc
I wonder of anyone will make progress now the dock is out and they are outputting audio with the touch pins
FSUnoles is offline   Reply With Quote
Old 01-28-2013, 10:54 AM   #68
pheoxs
Link?
Old 01-28-2013, 12:28 PM   #69
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by pheoxs View Post
Link?
[ame="http://www.amazon.com/dp/B009UQZPA0/ref=cm_sw_su_dp"]Amazon.com: Asus Docking Station for ASUS Google Nexus 7 (Black): Computers & Accessories[/ame]
Old 01-29-2013, 03:42 AM   #70
Yobiwan
Yobiwan's Avatar
Drives: Toyota 86 Turbo, Lexus NX300H
yes. there is.
Someone of korean 86 forum done it. He opened all front panel . & removed that metal bar . so nothing happened.
everything is ok. =)
You can see picture from here
http://cafe.naver.com/area86/3338
Yobiwan is offline   Reply With Quote
The Following 2 Users Say Thank You to Yobiwan For This Useful Post:
CxG (04-01-2017), pheoxs (03-13-2013)
Search this Thread:
Advanced Search
Nexus 7 Tablet Lefty Electronics | Audio | NAV | Infotainment 63 06-13-2015 02:18 PM
Tablet Install Build Diary Dezoris Electronics | Audio | NAV | Infotainment 98 03-13-2014 01:40 PM
Longo Scion Demo Build Journal - Car arrives next week xravexboix Member's Car Journals 12 06-15-2012 01:00 AM
