Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
03-09-2015, 05:30 PM | #29 | |
Drives: Subaru BRZ
There is a whole mess of things going through my head. I had my gear box replaced RIGHT after i put those wheels on and the humming makes me think I need to check the drive shaft to make sure they didnt install it wrong or something. Is there any way you can install the universals 180 out from each other and cause an unbalance? I tried looking up pictures while I was at work but i didnt see if it was possible on these or not. The dunlops are SUPER loud and i think putting the super sports on there quieted it down enough to hear/feel it. Lol |
03-09-2015, 06:06 PM | #30 | |
Drives: 2013 Subaru BRZ
Sorry what did you mean universals? Maybe we have different names for some things, us canadians seem to be behind the times of our neighbours to the south. (YES neighBOURS not neighBORS, politically correct humour, kinda my thing) Ya those dunlops arent the quitest tires around, i try to avoid dunlops if possible (unless star spec 2's ) |
03-09-2015, 06:34 PM | #31 |
Drives: FRS
maybe your front shocks are blown? have you tried putting back on your stock wheels/tires and see if you still have all the same issues?
03-09-2015, 11:54 PM | #32 | |
Drives: Subaru BRZ
http://s1348.photobucket.com/user/qu...c828a.jpg.html These are universals. A buddy of mine at work mentioned that I check to make sure they were "re-installed correctly" which Im not sure if they can even be... |
03-09-2015, 11:55 PM | #33 |
Drives: Subaru BRZ
03-10-2015, 01:10 PM | #34 |
Can you post the tire specs? Name, Brand, size? Would help in the forum diagnosis..lol
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
03-10-2015, 02:19 PM | #35 |
IIRC the driveshaft will come out as a complete unit, the splines/bolts are before and after all the universal joints so unless they disassembled the shaft itself, I wouldn't think the shaft phasing/clocking would have been change at all. I could be wrong, if the pic linked above is from a BRZ then it is a 2 piece shaft, and the forward joint might need to be reclocked. If there's no deflection coming from the transmission case to the carrier bearing, then the universal joint clocking shouldn't matter. that clocking only matters when the shaft input and output are not always/ever in axis.
I'd be curious to find out whats causing the vibration, may be related to tire wear, may not. You could get the car up on jackstands and spin the rear wheels in 1st/2nd, or the fronts by hand to see of something is obviously out of round. Swap to another set of wheels to see if it goes away. Also while its up, try to wobble the wheels with your hands at 12 and 6 o'clock to rule out bearing or joint failure. |
03-10-2015, 02:23 PM | #36 |
Drives: Subaru BRZ
03-10-2015, 02:24 PM | #37 | |
Drives: Subaru BRZ
03-11-2015, 01:16 AM | #38 |
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
Stock tires for the twins are 215/45/17, so going to a 235/45/17 setup without changing alignment is asking for bad tire wear. Its both a taller and wider tire.
As for your vibration - too many variables changing. Most likely tire related but who knows. You got 2 new tires? Consider getting 4. Also consider buying the "right" size for your car. |
03-11-2015, 03:14 AM | #39 | |
The wheel alignment isn't dependent upon tire size until you get to extremes, which doesn't apply here. The new wheel and tire are still pointing in the exact same direction. The alignment numbers he had/has shouldn't create ANY abnormal wear after only 500 miles. I am still betting on the tires being worn more than he believed at first, especially if his friend's WRX was running more camber. edit- And where on earth did you read that he only installed two wheels and tires? I also have tires/wheels from a friends WRX; 225/45/17 that are on my car now and are wearing perfectly, no alignment necessary. I even had 20mm and 25mm spacers installed for a while, again no alignment necessary. A Tire Rack tech I spoke to recently says 225/45/17 is actually a recommended size for the 86 in their vehicle info database. |
03-11-2015, 09:55 AM | #40 |
Drives: 2014 SWP BRZ, MT
Driveshaft is two piece, but the joint at the center carrier bearing is bolted together not slip-spline and there's no reason to disassemble the shaft swapping a trans (I did my third 2 weeks ago lol...), so you can rule that out unless it looks unbolted.
That's quite odd... Before I got rid of my stock tires and replaced them I installed coils and drove around not aligned for about 1000 miles and the tires weren't even that bad. The before settings weren't pretty either lol. I checked for rim bends once by putting the car on stands, starting the car, and letting the wheels spin freely on the car (obviously not fast lol) but if you do slowly ramp it up you can feel a vibration develop if is really out of balance or bent. It's also a good way to find out which one it is.
The answer is racecar. Always.
03-11-2015, 10:21 AM | #41 |
Dirt Trackin'
Drives: '13 Raven FR-S MT
Might want to check the control arm bushings to make sure they're in alright shape. Having them worn out could cause a vibration and some wonky tire wear...
03-11-2015, 12:29 PM | #42 |
Drives: Subaru BRZ
I'm honestly going to chalk it up to me not inspecting them very well.... Everyone I have ever talked to says that the WRX's ABS eats the hell outta the inside of the tire. And upon inspection of his new tires, they look as if its true.
I checked everything and mechanically everything is fine. As for the vibration, I think its just the new tires "feel" that im getting used to.... And I do believe that when I replace the older front tires it will all go away. |
Similar Threads | ||||
Code P0351 Trouble shooting? | Bahraini86 | Issues | Warranty | Recalls / TSB | 46 | 09-10-2017 04:07 PM |
Stock mats/carpets wearing quickly? | Vic_RSA | AFRICA | 1 | 12-22-2013 02:06 PM |
Carpet wearing off | ironsurfer129 | Scion FR-S / Toyota 86 GT86 General Forum | 30 | 07-29-2013 03:02 PM |
Mats wearing out | Gp1666 | AFRICA | 85 | 02-20-2013 06:40 PM |
trouble shooting | tim saylor | Other Vehicles & General Automotive Discussions | 0 | 07-01-2012 01:04 PM |
