Tracking / Autocross / HPDE / Drifting What these cars were built for! |
#29 |
Drives: Slowly
It's all a matter of perspective.
You can look upon a part failure as a chance to have an argument with a dealer over your attempt to commit fraud, or as an opportunity to personalise and improve the car with something better. Once you've identified a weak part, I know which one I'd prefer. |
#30 | |
Drives: None
#31 | |
Drives: 2006 Scion tC RS 2.0
Brake. Turn. Accelerate. Repeat as necessary.
#32 | |
Drives: subaru
#33 |
Drives: 2009 Scion xD
#34 |
4AGE Enthusiast
Drives: 1986 Toyota MR2 20v, 2004 Tacoma
This has not been my experience. Not even with completely stock cars. The burden of proof of fault falls onto the owner. As an example, a friend of mine bought an 08 STI. The engine wasn't running right, and Subaru refused to do any tests to prove anything was wrong. My friend had to shell out $400 from his own pocket for a compression test to prove to them the engine was screwed. It was. Then they tried to deny warranty coverage saying that he'd clearly hit something because of a big flat dent in his transmission casing. I looked at it for him, because he said he hadn't hit anything, and told him it looked to me like it was cast that way, maybe even intentionally. He went and looked under another STI, and sure enough, same flat dent cast into every casing. He had to convince someone to drive to the dealership with him to PROVE to the dealership that his flat dent was OEM, not damage.
#35 | |
Site Moderator
Drives: Stuff
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#36 |
4AGE Enthusiast
Oh he did. This story is much much longer, and it only gets worse. The short of it is that Subaru doesn't give a hoot about honoring their warranties. They'll try to screw you every chance they get no matter at a dealership or straight from Subaru of America. Currently this particular STI is sitting in his garage, not running. Having gone through 2 engines and a transmission, now the 3rd engine toast again. My friend finally gave up trying to get things fixed under warranty and is just saving for a built Cosworth engine.
#37 | |
Site Moderator
Drives: Stuff
Back in the day they covered damage from a local rallycross that resulted in a number of damaged WRXs and STIs, the local dealer fixed them all under warranty.
-Dave
#38 |
4AGE Enthusiast
Yup. Stock engines. They tried repeatedly accusing him of abusing the engines and racing, but they had no proof. It's an STI, it's going to be driven hard. DUH.
#39 |
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
#40 |
Wiring Nerd
Drives: 1994 Supra
Here is section C of 15 USC 2302
(c) Prohibition on conditions for written or implied warranty; waiver by Commission No warrantor of a consumer product may condition his written or implied warranty of such product on the consumer’s using, in connection with such product, any article or service (other than article or service provided without charge under the terms of the warranty) which is identified by brand, trade, or corporate name; except that the prohibition of this subsection may be waived by the Commission if— (1) the warrantor satisfies the Commission that the warranted product will function properly only if the article or service so identified is used in connection with the warranted product, and (2) the Commission finds that such a waiver is in the public interest. The Commission shall identify in the Federal Register, and permit public comment on, all applications for waiver of the prohibition of this subsection, and shall publish in the Federal Register its disposition of any such application, including the reasons therefor. Notice that there are waivers to the rule, stating that they can deny warranty due to modification, but only if they satisfy #1 and #2. How would one go about searching the federal register regarding waivers to Subaru / Toyota regarding the use of OEM components? |
#41 |
[||•]=(86)=[•||]
Drives: 2017 Toyota 86
It really depends on dealer. I'm working at a Chrysler dealership and if the modification do not cause damage to the car, we don't give a $hit.
When modification cause damage then we don't cover it. And that is 100% normal. My friend have a '09 Corolla XRS and the local dealer is really a bitch for tuning parts. For exemple, his car was making some random misfires. He have a Weapon short ram air filter installed... guess what was the cause for the dealer tech? The short ram. He was in !"(&!") and leave, he call me after that. I hook up my cheap 20$ scanner to check the code, search a TSB on the net. Found one, with the date of fabrication of the car and the DTC matching, I've print and highlighted everything and he go with that at the dealership. The engine harness was to replace and they FINALLY have replace it.
#42 | |
Drives: '12 C63 P31, '23 GRC
I've also heard a lot of bad publicity about Subaru with their STIs. Someone on a local car forum here in NC blew his 2008 STI's engine while still under warranty. He hadn't been abusing it and Subaru accused him of running the engine with a low oil level. After countless attempts he had to pay for the engine replacement himself. Stuff like this (and the stories about SCCA Autox'ing voiding warranties) makes me want to stay away from Subarus.
![]() Hey ft86Fan where do you live in Basking Ridge? I spent 4 of my childhood years growing up just off Mt. Airy Road. Loved that town. As to dealerships and honoring warranties its my understanding that tracking a stock vehicle should not be grounds for voiding it. Especially a SPORTS car, which is designed to play with. Obviously if you are not a good driver then abuse is possible but in my opinion driving a vehicle hard around a track for a weekend is not abuse. This statement stands with the understanding that the only modifications you are making for the track are what's needed, like track only brake pads, stickier (but not R comp) tires and possibly brake cooling ducts if needed. My S2000 is no longer under factory warranty but is still under an extended one, and I've talked candidly with a service manager about attending track days. ![]()
Current: 2023 GRC Circuit Edition, 2012 C63 AMG P31
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R |
$125 Track Day@WillowSprings-Big Track-Dec 17-18 in Socal | Louie | Southern California | 7 | 12-17-2011 07:36 PM |
Suggestion to Toyota: Cheap steelies on a track model | DrunkenMime | Scion FR-S / Toyota 86 GT86 General Forum | 90 | 12-07-2011 12:56 AM |
$109 Track Day@WillowSprings-Big Track-August 13-14 in Socal | Louie | Southern California | 1 | 07-26-2011 04:34 AM |
Dear toyota: Please make track edition. | aphxero | Engine, Exhaust, Transmission | 7 | 06-02-2010 09:07 AM |
FT-86 to debut new GPS-track day technology for use on track and GT5! | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 17 | 01-30-2010 11:30 AM |
