10-23-2013, 08:20 AM | #2353 | |
Drives: WR Blue BRZ, 240Z
Further, the brilliance of the throttle switch is it eliminates the need for a BOV. Think about it; you're at WOT with the compressor spinning, you reduce throttle to shift, and as you pass through 3/4 throttle the compressor stops spinning (it has internal brakes...it stops). When you get back on the throttle you're at full boost again. The simplicity of design is one of the things that makes this kit so cool (and affordable). There are hundreds of posts in this thread where people want to make it complicated. Once you have an opportunity to drive a car with it installed you'll quickly realize that does what it is designed to do, provide boost where it is needed most, when it is needed.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
The Following User Says Thank You to Gary in NJ For This Useful Post: | Bu-Tang (10-23-2013) |
10-23-2013, 09:50 AM | #2354 |
Drives: 2013 FR-S, 2012 MCS
What other posts are just purely bad? I'm not technically sound and I knew this was like a switch based system for boost. Just thought a switch would start the charger up for passing power somewhere in the rev range without going full out...since full out stock is already not bad. It just seems like going full throttle while full throttle already isn't bad seems counter productive. I was just seeing if more power could be had just chillin on the road, press the button, make available boost, put foot down a little more, pass, let go of button, keep driving. Hope that made any sense at all. I'm on the forums for info and to voice my opinion. Sorry if that isnt up to your standards.
10-23-2013, 10:25 AM | #2355 |
Drives: Challenger R/T, CRX SI,
If the blower kicked on 80%-100% that would be great. It wasn't a bad question. If it could be tuned to the users wants needs it just makes the system better. Not everyone only wants more power at WOT.
10-23-2013, 10:45 AM | #2356 | ||
Boost under part throttle runs into a whole bunch of new tuning scenario's. For what its worth the DR does boost(1psi) when you want a little more. It gives a nice bump in torque as it pulses even when at partial throttle. |
10-23-2013, 10:54 AM | #2357 | |
Its already a great car for kicking around town but where it falls on its face in the mid range is where it really needs the help. You have to remember in any FI system most of them function are either on or off as well. In my STI when driving around normal you are always in vaccum, then when you go 50% throttle it transitions out of vaccum and sits around 0psi. Now when you go from 50 to 75% throttle goes from 0 psi to 20 psi..... if you are very careful you can hold it in between but once your revs are up it just wants to go.... thats how turbo's work. Sorry if this doesnt make sense its early in the morning still Main point is the system in its current configuration just makes sense.... once more people drive the system it becomes more clear. Initially i was the only one defending it but now with 8 testers they all agree it isnt weird or abrasive in the way the boost comes on. |
10-23-2013, 11:05 AM | #2358 | |
Whenever I find myself wanting more power, I just go WOT. We're only talking about 2-1/2 inches of total throttle movement here folks. It's not in anyway inconvenient to add an inch of throttle when you want power.
10-23-2013, 11:06 AM | #2359 | |
Drives: 2013 FR-S Argento
This system is pretty linear - on a stock car you're at 100% throttle way before your pedal is pinned to the floor. Think of it this way: Pedal 15% to floor, throttle 25% Pedal 30% to floor, throttle 50% Pedal 45% to floor, throttle 75% Pedal 60% to floor, throttle 100% With the ESC you then have Pedal 100% to floor, throttle 100% plus ESC So think if it this way, the ESC just gives you more power in that last bit of pedal travel that you didn't have before. Instead of fiddling with a button on your dash, just move the pedal further if you need it. Simple. Disclaimer: the pedal to throttle relations were just pulled out of my ass, I have no idea what the stock mappings are, and I know they can be changed by a tuner. Just using easy numbers to illustrate the point. |
The Following 2 Users Say Thank You to bfrank1972 For This Useful Post: | BlueDubbinTDI (10-23-2013), fenton (10-23-2013) |
10-23-2013, 11:17 AM | #2360 |
How does 1 go about testing this system? If its what its developing out to be, they can take my money lol.
10-23-2013, 11:31 AM | #2361 |
I bet they need some testing in this good ol Louisiana humidity.
:P Last edited by CajunFRS; 10-23-2013 at 11:32 AM. Reason: spelling. |
10-23-2013, 11:36 AM | #2362 |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
No dyno test today. Auto shop teacher forgot the laptop. Will hopefully test tomorrow.
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
10-23-2013, 04:38 PM | #2363 | |
Drives: 2013 Scion FR-S 10 Series MT
The scenario where you'd want the additional power during partial throttle would be during cornering, where you're modulating the throttle to maintain proper balance/etc. However, in these situations though, I'm not sure that the additional power of the ESC would even be needed. Actually, the only part that I think would be concerning, would be the huge difference in torque between less than 100% throttle and full 100% throttle... primarily during corner exit. I'm guessing that this would be a non-issue with a little bit of experience on the track... but it could be dangerous during the learning process if someone is not careful. Other than that little bit above (which I believe can easily be a non-issue with a driver mod), I actually prefer the idea of the ESC only spooling up at full throttle. That means 0 spool when you don't want the extra power, i.e better mpg while cruising. I'd likely keep the switch turned to "On" at all times, which actually seems like an unnecessary component for this system if you ask me, considering that it only engages at full throttle anyway. |
10-23-2013, 04:56 PM | #2364 |
Hey beta testers,
I got an interesting thing for you. For the last 24 hrs I haven't gotten a single engine code, and I can tell you sometimes I haven't followed the 3500 rpm recommended activation. I'm wondering if the reason this is occurring is because of the snorkel. (I removed mine) Am I just getting lucky here, or is it helping? By the way I'm still not running the tune.
10-23-2013, 04:58 PM | #2365 | |
You need the system to be on for the drag reduction. This helps supply power when not on full throttle.
10-23-2013, 04:59 PM | #2366 | |
Just my #1 concern atm and lookin for some knowledge |
Similar Threads | ||||
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 04:45 PM |
Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 06:43 PM |
86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
