#1499 | |
Drives: '22 BRZ
"lack of maintenance" on a sealed part? ~18k miles and 400 autocross runs with wide sticky tires. "abuse" would be a good way to put it.
The Following 3 Users Say Thank You to DocWalt For This Useful Post: |
#1500 | |
Drives: 2023 BRZ
Director of Rocky Mountain 86CUP
#1501 | |
Guilt free parts vulture!
Drives: 2013 FR-S - Asphalt 6MT
Over the weekend I installed Pedders tophats on the Trueno edition. Incredibly easy on this car, no need for a spring compressor!
The Following User Says Thank You to nextcar For This Useful Post: | DocWalt (04-03-2024) |
#1502 |
Drives: 18 Brz (Sold) / 22 BRZ
Removed the sway bars, one of the end links will need to be replaced (rusty bolt). I will have to drive slowly until the links arrive to install new ones.
#1503 |
#1504 | |
There is very little preload on the springs. If you remove the nut on the top of the struts whlie the car is on the ground and jack up the front end slowly, the tophats separate easily. You will have to remove one endlink to swaybar connection, then you can simply line up the strut with the new tophat and slowly lower the vehicle and start the top nut...
The Following 2 Users Say Thank You to nextcar For This Useful Post: | Ohio Enthusiast (04-08-2024), Stonehorsw (04-11-2024) |
#1505 | |
#1506 |
Installed RCE sway bars. Front 20mm dia and rear 16mm dia.
Front on hardest and rear on middle. Added camber bolts. Now, need to take to a good alignment shop. Last edited by Stonehorsw; 04-26-2024 at 09:03 PM. Reason: Add info |
#1507 | |
Drives: '22 BRZ
On a brighter note, I finally moved on from the V601 to a 615k+ this season and somehow managed to drop nearly 2 full seconds on a 1 mile course. Insanity! |
The Following User Says Thank You to eyeballs For This Useful Post: | Pat (05-01-2024) |
WHAT DID YOU DO TO YOUR FRS TODAY? | KalbiCool88 | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 11-04-2015 10:36 PM |
Do you know what today is? | Yruyur | Off-Topic Lounge [WARNING: NO POLITICS] | 26 | 01-21-2015 02:51 PM |
just got my OFT today...help please! | carlitosway6891 | Software Tuning | 9 | 02-20-2014 10:05 PM |
TODAY, TODAY, I GET IT TODAY!!!! :D | Trashed675 | Scion FR-S / Toyota 86 GT86 General Forum | 54 | 02-14-2013 01:16 AM |
sat in a BRZ today | NESW20 | BRZ First-Gen (2012+) -- General Topics | 8 | 03-31-2012 08:53 AM |
