Old 06-12-2013, 02:38 PM   #155
Marrk
Drives: Honda Fit
I wonder why failing injector seals didn't show up in the countless miles of preproduction testing. Did they change specs prior to ramping up the manufacturing process?
Just wondering.
Marrk is offline   Reply With Quote
Old 06-12-2013, 02:59 PM   #156
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Just wondering.
The same question could be applied to the chirping, leaky taillights and window scrolling issues.
Either this is an issue that's come up recently due to differences between manufacturing and pre-production, completely overlooked during testing, or this isn't "normal" and it only affects a minority who are aggressive with their cars.
I expect an ECU reflash to be available by the end of August, they'll warranty any stock vehicle failures (hopefully regardless of track time) and it will die down like the CEL/SL did. At least, that's assuming the failure is related to the knock and not the heat, if it's the heat then they'll need to change parts or figure out how to keep the engine cooler, that would be a huge mess.
ineedyourdiddly
Old 06-12-2013, 03:10 PM   #157
Marrk
Drives: Honda Fit
No.
For three reasons:
1) Chirp is ethanol related.
2) The Japanese don't perceive the chirp to be anything other than normal.
3) Chirp does not lead to either abnormal functioning of the car nor engine failure.
Windows and tail lights are small assembly glitches remedied by a manufacturing process adjustment. Neither the windows nor the tail lights have rendered the car inoperable.
Old 06-12-2013, 04:00 PM   #158
strat61caster
No.
For three reasons:
1. What does that have to do with identifying the issue before sale to the masses? The vehicle was tested here on regular pump gas, and ethanol free solves it for SOME, not all.
2. Fair, no argument there. BUT, they did issue a TSB which indicates that something requires fixing.
3. Agreed, however IF they were aware of the noise and deemed it "normal" a TSB should never have been issued, no "new" pump designs should have been put out. But those things happened, the "solution" was put into place either due to consumer demand or they were unaware of it in testing for whatever reasons, in which case you'd be asking the same question we're asking here: "Why wasn't this caught earlier?"
You're right they're smaller scale and impact BUT they are issues which have required rework from Toyota/Subaru to remedy, it is reasonable to ask why these problems weren't known sooner. There is little reason why a test mule would have different manufacturing processes or different parts from what was sold to the rest of us (especially things as mundane as taillights, fuel pumps and windows, those should all be basically off the shelf). The question "Why has this happened to us and why wasn't it caught in testing" is valid for all the things I posted.
I admit they are not comparable to the injector seal issue but they are widespread and would have been caught on 10 randomly selected and thoroughly tested cars, at least from the pool we all bought ours from.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
Carwhisperer (06-12-2013), Marrk (06-12-2013)
Old 06-12-2013, 04:22 PM   #159
track_warrior
Track Junkie
track_warrior's Avatar
Drives: Faster than the Stig!
Originally Posted by phm14 View Post
Apologies. I was a little fuzzy on the details, since it's been ~4 months since I read the thread where you described how you destroyed your motor. This is "Wtf" I'm talking about:
http://www.trackjunkies.org/topic/24...nk-i-broke-it/
Here's how it looks to me: You find a tuner and pay him to d*ck up your car so it runs lean/hot. A tuner that you are aware "tuned" another TJ members NC Miata that subsequently blew up. You take your car to the track, where it becomes apparent that your having major engine problems, so you take it out for another session, where the problem gets worse. What do you do then? Take it out for a third session to make sure it's completely destroyed. Next, you post online that you've "broken it", and your "tuner" re-flashes it back to stock, so you can mislead Toyota into replacing your engine. You take in your fully track prepped car-cage, stripped interior, track wing and all, and Toyota generously replaces your motor. When the dealer warns you that they're only giving you one motor, instead of being grateful for the replacement you got after YOU destroyed your engine, you slam Toyota online, acting as if you had nothing to do with the damage. Your silly admonitions to Toyota about the FRS are comical. What sucks is that we Toyota customers ultimately all share the cost of the companies' generosity in case like yours. Your dishonesty may well cost Toyota and Subaru sales, judging by some of the comments here. No doubt your dishonesty has many here agitated and enjoying their cars less than they should be. A man owns up to his mistakes. I think you owe this whole community an apology, not to mention Toyota, who has gone far above and beyond what's justifiable since you voided your own warranty, then destroyed your motor like an idiot.
BTW, who is "miss inform".
Replied from my phone while i was at the airport plus english is my 4th language. I am too busy enjoying my trip in Europe while u bitch and moan about my grammar. This will be my last post for a month until i am back home. I really wont lose any more of my time with some one that is bitching about a car he does not own. Its been clear more people that are not even tuned are having this issue.
Btw guys i get to drive the ring on the 17th and they have a fr-s where im renting the race car. Ill ask them if they have had any DI issues since its a track rental, im guessing the cool temps will prove otherwise. If my mistake was posting my issue with the car to try and find a permanent fix so people dont start having the same problem some of us have had then so be it.
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
track_warrior is offline   Reply With Quote
The Following 2 Users Say Thank You to track_warrior For This Useful Post:
lazyluka (06-12-2013), Marrk (06-12-2013)
Old 06-12-2013, 06:46 PM   #160
Carwhisperer
Drives: A lot of supercars.
Guys ease up.
Carwhisperer is offline   Reply With Quote
Old 06-12-2013, 07:05 PM   #161
phm14
Loves the Smell of Track
phm14's Avatar
Drives: '13 86
Oh no. What will we do without you?
2020 86 Hakone MT build thread: https://www.ft86club.com/forums/show...31#post3326231
2013 Toyobaru 86/FR-S 6MT, Red, aka Candy O SOLD
http://www.ft86club.com/forums/showthread.php?t=7934
phm14 is offline   Reply With Quote
Old 06-12-2013, 07:57 PM   #162
Lonewolf
Lonewolf's Avatar
Drives: Moped
Interested to hear your impressions about the FRS on the ring...
Old 06-12-2013, 08:01 PM   #163
Marrk
Drives: Honda Fit
Please do report back on The 'Ring, etc. :happy0180:
Old 06-13-2013, 12:01 AM   #164
romin
romin's Avatar
Drives: BRZ, STI, 535, Tiffin Allegro
I had my injectors pulled by a 3rd party mechanic because Subaru refused to.
Here is what we found:
Cylinder #1 injector was so badly pitted that we had to completely replace it:
romin is offline   Reply With Quote
The Following 4 Users Say Thank You to romin For This Useful Post:
2forme (06-13-2013), CSG Mike (06-13-2013), mad_sb (06-13-2013), Marrk (06-13-2013)
Old 06-13-2013, 02:58 AM   #165
phm14
phm14's Avatar
Drives: '13 86
Were you running a tune when the problem started?
Old 06-13-2013, 08:34 AM   #166
Stevo22
Stevo22's Avatar
Drives: GR86
More details please....
1. Why would Subaru not pull them (no CEL)?
2. How many miles on your engine?
3. Did you just do it to check or could you hear an audible knock?
4. Anything else you think is important that we should know
Stevo22 is offline   Reply With Quote
Old 06-13-2013, 08:39 AM   #167
mad_sb
Drives: 2013 Asphalt FR-S
@romin, what did you do to clean and prep the seal seat area on the head when you replaced the injector / seal? With that much carbon on the injector i would imagine the seat area is nasty with build up as well..........
Old 06-13-2013, 08:44 AM   #168
2forme
Please tell me you rubbed it in the face of the service manager and filed a complaint with SoA to get a refund. I think someone should take this to Jalopnik or Autoblog or something. That would DEFINITELY get their attention.
The Following 2 Users Say Thank You to 2forme For This Useful Post:
vgi (06-13-2013), xjohnx (06-13-2013)
Injector / seal failure or Miss-fire codes.. please post here mad_sb Engine, Exhaust, Transmission 378 04-24-2020 07:33 PM
FRS-BRZ Port Fuel Injector (interesting) Element Tuning Engine, Exhaust, Transmission 50 04-21-2016 05:26 PM
Direct Injector's Leaking Carwhisperer Scion FR-S / Toyota 86 GT86 General Forum 1 05-11-2013 10:31 AM
Leaking Oil? 636 Issues | Warranty | Recalls / TSB 11 01-05-2013 05:43 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Injector Dynamics ID850s! Dustin@Dynosty Engine, Exhaust, Bolt-Ons 0 08-21-2012 06:03 PM
