Old 06-12-2013, 12:08 AM   #15
roddy
roddy's Avatar
Drives: '13 Ultramarine
'13 6MT here, Build date 04/12, took delivery 6/12. almost 17,000 miles. I've had the left side front 1/4 window replaced due to a bad seal, and the car goes in for a new right side tail light tomorrow. Nothing major.
Old 06-12-2013, 12:29 AM   #16
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Check the Issues/Warranty/Recall subforum:
http://www.ft86club.com/forums/forumdisplay.php?f=72
There have been two confirmed issues that could affect an FRS/BRZ/86 that would require major rework.
1. Check Engine Light/Slip Light error which never got a real solid answer seems to be eliminated. This resulted in a couple blown motors, a couple replacements and a couple of services requiring replacement of camshaft/timing equipment/ecu replacement. Again this seems to have been "solved".
2. Injector seals blowing out, current root cause is said to be shifting at or near redline and when you step back on the gas the engine will knock, over time this will degrade the seals until they no longer seal the combustion chamber causing a lean condition, more knock and eventually things break. The fix should be an ECU update to fix the transient timing tables to prevent the knock under hard acceleration, but there is concern that it may be caused just by heat buildup, in which case a new seal design will have to be released or they will have to find a way to keep the engine cool (lol). If you avoid hard shifting at redline (or at least are easy getting back on the gas after a shift) there shouldn't be any major issues.
Everything else is small or a one in a couple thousand fluke.
But like everyone else here I'll post anecdotal evidence: 10k miles, zero issues.
ineedyourdiddly
Old 06-12-2013, 02:04 AM   #17
New owner here, 2013, FR-S 6MT. No problrms after 1200 miles ...
Old 06-12-2013, 06:40 AM   #18
Humpie
Can't Re Member
Humpie's Avatar
Drives: 2013 Argento AT, 2013 Firestorm MT
Originally Posted by Jertronic View Post
Out of curiosity, which set up do you like better?
I prefer MT as that's what I've always driven. Wife drives AT primarily. MT better acceleration, but I can't knock the auto. It retains the fun factor very well.
Humpie is offline   Reply With Quote
Old 06-12-2013, 07:23 AM   #19
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Originally Posted by Touge_ninja View Post
13k miles and loving every mile added!! Only regret getting the color I have right now
Carlitoz3 is offline   Reply With Quote
Old 06-12-2013, 09:12 AM   #20
13 FR-S Veteran
13 FR-S Veteran's Avatar
Drives: 2013 FR-S (Raven Black)
Originally Posted by Pandanoid View Post
So I've been reading around the thread for pretty much the entire morning about the issues and the threads about whether it is better on waiting for the >'14 FR-S.
Personally, '14 models aren't exactly far away but regardless of whether I want to be an original owner or a waiter the main issue on my mind is the issues that are showing up with the car. I'm not talking about the small issues such as water condensations and such but more to the rare cases about blown engines or faulty engines.
I don't know much about the reliability of this car (I don't plan to track it but I'll probably be putting a majority of highway mileage than city). Are blown engines and engine problems more of a tracked-car problem? Or simply the 4ugse?
I know there will probably be some recalls and known problems here and there but after that will there be a lot of extended-maintenance needed?
(sorry for being a newb)
Just over 11 000 Km's here and ZERO issues!
No regrets about pulling the trigger on the 13.
13 FR-S Veteran is offline   Reply With Quote
Old 06-12-2013, 09:54 AM   #21
Whitigir
Drives: 450 awhp twin turbo vr4
Are you smoking pipes ? Knowing it a TOYOTA and you are doubting it RELIABILITY ? What do you smoke ?
Whitigir is offline   Reply With Quote
Old 06-12-2013, 10:20 AM   #22
frslee
Just drive it
Drives: 13' FR-S
Well.. it seems like most of mechanical parts are from Subaru. Not saying Subaru is not reliable, just saying it's not 100% Toyota.
I put about 5600 miles and it's been great so far.
frslee is offline   Reply With Quote
Old 06-12-2013, 10:26 AM   #23
Whitigir
Even if it is not 100% Toyota. I wouldnt think Toyota would allow even one platform to ruine his reputation.
Old 06-12-2013, 10:28 AM   #24
DarkSunrise
DarkSunrise's Avatar
The only major widespread engine issue that I know about is the idle/CEL issue, which was fixed by a simple dealer ECU reflash.
The DI seal issue is not nearly as widespread, and so far has mainly affected guys who track their cars hard. I'm keeping my eye on it, but it looks like another dealer ECU reflash might be the easy solution. Fingers crossed.
2022 BRZ Build
2013 FR-S Build
DarkSunrise is online now   Reply With Quote
Old 06-12-2013, 11:28 AM   #25
Nsot
Nsot's Avatar
Drives: Whiteout FR-S
Thanks for all the input! I will be looking to get my first FR-S soon and officially join the club!
I'm getting mine on Friday! Maybe I'll see you around!
Nsot is offline   Reply With Quote
Old 06-12-2013, 01:19 PM   #26
PR FR-S
Drives: 2013 FR-S, Asphalt
14K plus miles on mine.Took delivery on October 11. No issues whatsoever. Great fun little car. One of the main reasons to buy my FR-S was that it was being built by Subaru. I've owned 4 Subarus in a span of 10 years and those things are bulletproof.
PR FR-S is offline   Reply With Quote
Old 06-12-2013, 04:52 PM   #27
jarviz
jarviz's Avatar
Drives: Raven FRS MT
23K miles and only had the tail-light moisture issue. And crickets of course if that is still seen as an issue. I kinda think of the crickets as the car's trademark sound now haha. if it doesn't have crickets, then it hasn't been properly broken in yet.
jarviz is offline   Reply With Quote
Old 06-12-2013, 05:25 PM   #28
jeffchap
jeffchap's Avatar
Drives: 2013 Scion FR-S Raven 6MT
Oh, just stop stewing over it and go get one. You can find the build date on a sticker inside the driver's door, if you want a more recent one. I wouldn't count on any major changes for 2014. Mine was built in March of this year, and I haven't had any problems yet, not even crickets.
Stay squatchy, my friends
jeffchap is offline   Reply With Quote
