#99 | |
Love Boost!!!!!!!!
Drives: Whiteout Scion FR-S
We didnt try at low boost after the misfire start happening
#100 |
Drives: 2013 Asphalt FR-S
Just a quick correction / additional info... I cam across a manual section that was in relation to some VVT codes. It states that:
Bank 1 refers to the bank that includes the No. 1 cylinder*. 6/4/2012 10:29 PMFA20 ENGINE CONTROL: SFI SYSTEM: P0016-P0019: Crankshaft Pos... 7 of 10 https://techinfo.toyota.com/t3Portal...S0U/xhtml/RM00... *: The No. 1 cylinder is the cylinder which is farthest from transmission. Bank 2 refers to the bank that does not include the No. 1 cylinder. However, I did not find any similar notes when looking up the DI codes you had. I still believe that in relation to the specific codes you got: P117B Direct Injector Fuel Performance P1171 Bank 1 too lean the Bank 1 reference is meaningless, since there is no mention of P0174 (system too lean bank 2) or P0175 (system too rich bank2) in the service manual. Also, since there is only 1 primary 02 sensor there is no way for the system to differentiate between which "bank" is rich or lean.
~Namaste~ Last edited by mad_sb; 06-05-2013 at 03:21 PM. |
#101 |
Just out of curiosity, has there been any record of a Subaru dealer acknowledging this issue? All the instances I read of Subaru, have involved fighting with the dealer LOL. Good to know Scion at least takes care of their cars.
#102 | |
Love Boost!!!!!!!!
Spark plugs are good he says
| The Following User Says Thank You to whitefrs For This Useful Post: | mad_sb (06-05-2013) |
#103 |
Any Updates?
~Namaste~ |
#104 |
Love Boost!!!!!!!!
still checking but they are wondering why is there white smoke coming out and a sweet smell at start up
hopefully is not coolant contamination
#105 | |
~Namaste~ |
#106 |
Love Boost!!!!!!!!
why would the head gasket go bad?
also can this cause a misfire?
#107 |
#108 |
Drives: Pile of junk
check the oil see if it looks milky or discolored as well as the coolant. hopefully they did that already. they also make an exhaust gas tester you can hook up to check for coolant that way as well. but ya white smoke and sweet smell sounds like a head gasket
#109 | |
Yes, coolant in the chamber will certainly cause a misfire.
~Namaste~ Last edited by mad_sb; 06-22-2013 at 01:30 PM. |
#110 |
Yeah, the tester is the best way for sure. Sometimes they start by only leaking a little bit under high load, not enough to detect visually in the oil etc.. but the gas tester never lies.
~Namaste~ |
#111 |
So its been a while since this was updated... any progress?
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
#112 |
So, I'm planning on getting FI soon. Anything I should tell my tuner to do, or check, to make sure I don't have any DI issues?
If i go with this tuner, I believe this will be the first FRS/BRZ that they have done a turbo install/tune on, so I want to be armed with as much info as possible. I've already noted things like the fuel pump install (O-rings and spacer) but if there's anything else they should look for, or avoid, I'd love to know before hand. |
| Injector / seal failure or Miss-fire codes.. please post here | mad_sb | Engine, Exhaust, Transmission | 378 | 04-24-2020 07:33 PM |
| Direct Injector Leaking | Carwhisperer | Issues | Warranty | Recalls / TSB | 356 | 03-13-2020 01:35 PM |
| FRS-BRZ Port Fuel Injector (interesting) | Element Tuning | Engine, Exhaust, Transmission | 50 | 04-21-2016 05:26 PM |
| Brake fluid leaking from pistons/seals normal? | Hanakuso | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 12-06-2012 03:54 PM |
| Bad window seals? | Dzeremijs | Issues | Warranty | Recalls / TSB | 18 | 10-26-2012 04:24 PM |
