Old 06-04-2013, 07:34 PM   #99
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Originally Posted by mad_sb View Post
Again, this engine has no bank 2 as far as OBD codes go so by all means check all 4 pugs and injectors. The problem could be on any of the cylinders if it is a localized problem and not something with the DI fuel delivery side.
Checking the plugs should help you determine the over all health of the motor as will checking all the injectors for seal integrity and injector tips for coloration etc.
My guess is if you have a bad injector it will be obvious when you compare the plug and injector to the other 3. One failed injector would be enough to max out the fuel trims since the others would have to compensate to maintain an average target afr in closed loop.
If all 4 are fairly uniform then you can start looking at something else like the DI driver box.
The thing is, those two codes together would indicate the Di system was not putting out enough fuel under closed loop DI only operation (which means low load on a boosted car) and even with the fuel trims maxed out the front 02 sensor was still seeing a lean condition.... Without seeing some logs all i have to go on is what JV said (ran fine on port only mode) and the rail pressure looked normal.. so that only leaves a few things... bad injector, bad injector driver box, clogged injector etc... I do think you would have a code if the injector driver box has an issue though.
When you ran into the issues at higher boost, did it still run good if you dropped the boost back down?
Thaks for the info
We didnt try at low boost after the misfire start happening
Old 06-05-2013, 12:51 PM   #100
mad_sb
Drives: 2013 Asphalt FR-S
Just a quick correction / additional info... I cam across a manual section that was in relation to some VVT codes. It states that:
Bank 1 refers to the bank that includes the No. 1 cylinder*.
6/4/2012 10:29 PMFA20 ENGINE CONTROL: SFI SYSTEM: P0016-P0019: Crankshaft Pos...
7 of 10
https://techinfo.toyota.com/t3Portal...S0U/xhtml/RM00...
*: The No. 1 cylinder is the cylinder which is farthest from transmission.
Bank 2 refers to the bank that does not include the No. 1 cylinder.
However, I did not find any similar notes when looking up the DI codes you had. I still believe that in relation to the specific codes you got:
P117B Direct Injector Fuel Performance
P1171 Bank 1 too lean
the Bank 1 reference is meaningless, since there is no mention of P0174 (system too lean bank 2) or P0175 (system too rich bank2) in the service manual. Also, since there is only 1 primary 02 sensor there is no way for the system to differentiate between which "bank" is rich or lean.
Old 06-05-2013, 01:36 PM   #101
2forme
Just out of curiosity, has there been any record of a Subaru dealer acknowledging this issue? All the instances I read of Subaru, have involved fighting with the dealer LOL. Good to know Scion at least takes care of their cars.
Old 06-05-2013, 07:39 PM   #102
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Just got a work of my tech.
Spark plugs are good he says
The Following User Says Thank You to whitefrs For This Useful Post:
mad_sb (06-05-2013)
Old 06-07-2013, 08:00 PM   #103
mad_sb
Any Updates?
Old 06-07-2013, 08:13 PM   #104
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Any Updates?
still checking but they are wondering why is there white smoke coming out and a sweet smell at start up
hopefully is not coolant contamination
Old 06-07-2013, 08:14 PM   #105
mad_sb
ugg, sounds like a head gasket
Old 06-07-2013, 08:19 PM   #106
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
why would the head gasket go bad?
also can this cause a misfire?
Old 06-07-2013, 11:06 PM   #107
jamesm
Detonation?
Old 06-07-2013, 11:31 PM   #108
Frs300
Frs300's Avatar
Drives: Pile of junk
check the oil see if it looks milky or discolored as well as the coolant. hopefully they did that already. they also make an exhaust gas tester you can hook up to check for coolant that way as well. but ya white smoke and sweet smell sounds like a head gasket
Frs300 is offline   Reply With Quote
Old 06-08-2013, 08:19 AM   #109
mad_sb
Head lift (weak head bolts, too much boost, detonation), Material failure, poor factory seal, etc.
Yes, coolant in the chamber will certainly cause a misfire.
Old 06-08-2013, 08:20 AM   #110
mad_sb
Yeah, the tester is the best way for sure. Sometimes they start by only leaking a little bit under high load, not enough to detect visually in the oil etc.. but the gas tester never lies.
Old 08-17-2013, 06:12 PM   #111
nelsmar
So its been a while since this was updated... any progress?
My flickr - Canibeat
Local magazine scout
Old 08-18-2013, 10:11 AM   #112
mike the snake
So, I'm planning on getting FI soon. Anything I should tell my tuner to do, or check, to make sure I don't have any DI issues?
If i go with this tuner, I believe this will be the first FRS/BRZ that they have done a turbo install/tune on, so I want to be armed with as much info as possible. I've already noted things like the fuel pump install (O-rings and spacer) but if there's anything else they should look for, or avoid, I'd love to know before hand.
Injector / seal failure or Miss-fire codes.. please post here mad_sb Engine, Exhaust, Transmission 378 04-24-2020 07:33 PM
Direct Injector Leaking Carwhisperer Issues | Warranty | Recalls / TSB 356 03-13-2020 01:35 PM
FRS-BRZ Port Fuel Injector (interesting) Element Tuning Engine, Exhaust, Transmission 50 04-21-2016 05:26 PM
Brake fluid leaking from pistons/seals normal? Hanakuso Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 12-06-2012 03:54 PM
Bad window seals? Dzeremijs Issues | Warranty | Recalls / TSB 18 10-26-2012 04:24 PM
