| DIY (Do-It-Yourself) Guides For all DIYs. |
#29 |
I've looked at this post a couple times in the past. Thanks a lot. Let me try to make a contribution to it.
![]() I've used Rock Auto in the past. That coupon code in the how did you hear about us should give you 5% off. 96788357963687 ![]() I'll let you know how these TYC OEM spec lights are. They actually applied another discount so it came out to: $ 57.52 shipped for the pair Last edited by PhastekSport; 06-12-2013 at 12:47 AM. |
#30 |
Boosted Noob
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Let me add absolutely nothing to the original foglight post.
I bought the pair of "JDM" foglight housings, but haven't bought any actual foglights yet. The OEM ones that everyone is getting from the Outback (?) isn't too exciting IMO (no offense to anybody who already got them - I might still go down that route in the future). I was actually thinking about just using the foglight housings to make brake air ducts with. I've seen some carbon fiber ones sell for $309 over at FT86speedfactory, but maybe there's a cheaper alternative that would still look pretty cool. This is totally just for looks as I don't have any overheating problems with my brakes since I don't track my car. |
#32 |
Divine Wind - Dori
Drives: RWD
Cheap fog lights
Hey, Guys
Just wanted to share what I found So I've been really wanting fog lights so much and I did so much research on it and well I wanted to get them but not pay $80+ Im gonna install them tonight. I got the Fog lights for $16 each. What i found out is The Outback fog lights are the same for the Ford Focus Fiesta Chevrolet Cruze Peugeot 307 AND a Lot of Ford/Lincoln uses these fog lights. cheapest you can find for it is probably 25$-35. These should help you guys pay less then needed. so far i've spent only $80+ with front and rear fogs and bezel and wirings. with fog enable dash light . No stalks
| The Following User Says Thank You to Lanbaldo3 For This Useful Post: | YamahaR86 (06-11-2013) |
#33 |
Drives: Brick
They are the Valeo Fogstar fog lights. Valeo made them to be the "world fog" (think world engine) .
You will find at least a car or two has them from just about any manufactures. They are either flat like the one shown by Lanbaldo3 , or angled one which can be found on the entire line of Toyotas. The rear look identical on all of them ![]() Flat lens: (What you want ) ![]() Angle lens: (You do NOT want ) ![]() There are a few variations between how the reflector angles, models project more light to the side has less distance, while the one shoot further down the road project less light to the side. But physically they are all interchangeable. |
#34 | |
JDM Vaping Stance Nation
Drives: 2013 White
#35 |
Drives: White out Scion Frs
Do you guys know where else to get the foglight bezel for the frs?
Amayama.com (i could not find any "buy it now" nor "add to cart" or anything like that, rather than "accepted inquired" with order has not been made) nigel-jdmparts pick up option seems to be a little bit laggy (no email respond as to where or when that i can pick it up- i guess i have to order it from nigel-jdmparts.com even-though they are like 5 miles somewhere away from my house) Any input would be greatly appreciated.
#36 | |
Boosted Noob
I still haven't bought anything else (ie foglights) though.... just have the bezels right now. |
#37 |
Drives: 2013 scion fr-s
I also got them from Amayama. First time I did not get a response from them so a week later tried again and it went trough I payed and got it shipped very fast. So just try again.
Good luck |
#38 |
First 86 Driver Baby!
Drives: FR-S, Flex
#39 |
Divine Wind - Dori
Drives: RWD
@YamahaR86 I got them on ebay and they look like any other 86 fog lights its direct fit like subaru outback. saves you A LOT of money.. in my case. oh and i believe, right now i found a couple of them selling for $18.
#41 |
Drives: 2013 Scion FR-S Raven
Thank you for the excellent DIY
I finally finished the wiring correctly, this is for step 22. I bought these from Tweak'd Performance ![]() The one on the left is the only one that worked for me ![]() http://www.tweakdperformance.com/onl...&products_id=6 or maybe this one if you can figure out how to insert it http://www.tweakdperformance.com/onl...&products_id=8
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
| The Following User Says Thank You to tonystewart For This Useful Post: | PopaNolie (10-15-2022) |
#42 |
Drives: 2013 Frs
thank you for the info. I'm working on the auto switch using an aftermarket harness.
| **PHASTEK** HID Headlights, Reverse Lights, Fog Lights (FR-S / BRZ) | PhastekSport | Exterior Parts - Lighting | 18 | 07-09-2014 07:42 PM |
| FR-S smoked tail lights and reverse lights | jjdrivesajazz | Cosmetic Modification (Interior/Exterior/Lighting) | 43 | 02-21-2013 08:38 PM |
| FR-S Fog lights | ggpaul | Cosmetic Modification (Interior/Exterior/Lighting) | 14 | 11-24-2012 11:28 PM |
| FRS HID lights? | easybreazy | Cosmetic Modification (Interior/Exterior/Lighting) | 84 | 08-27-2012 10:21 PM |
| Fog lights on with parking/running lights possible? | BMWDavid | BRZ First-Gen (2012+) — General Topics | 1 | 06-16-2012 07:29 PM |
