Old 06-03-2013, 01:52 PM   #1
kurbkilla
kurbkilla's Avatar
Drives: Scion FRS (Asphalt)
Racing harness
Sorry if this is in the wrong area. I tried searching.
It looked like you could use the child seat anchor for a four point harness but if you do that the driver seat belt light and alarm will go off is there a way around that or do you have to unplug the fuse?
Sent from my DROID BIONIC using Tapatalk 4 Beta
kurbkilla is offline   Reply With Quote
Old 06-03-2013, 02:04 PM   #2
GTM_Challenge
GTM_Challenge's Avatar
Drives: On track
4 point is a big no no in my book, at least for the track.
GTM_Challenge is offline   Reply With Quote
Old 06-03-2013, 02:30 PM   #3
kurbkilla
kurbkilla's Avatar
Why is that? Would you do a 5 or leave it stock?
Old 06-03-2013, 02:44 PM   #4
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
Either do it proper or don't do it at all imo. 4 point harness are frowned upon for various reasons. Also I'd suggest using a harness bar not the child anchors. I believe the child anchors are only rated for a small amount of weight, not for a full adult
Sent from my Nexus 4 using Tapatalk 2
Nolan
pheoxs is offline   Reply With Quote
Old 06-03-2013, 04:24 PM   #5
xwd
I have a Schroth Rallye 4 which is has their ASM (anti-submarine) technology which I mainly use for autocross but have done a couple track days with. The Sparco 4-point are just normal belts and are the ones people generally ban from track events.
I have it bolted to the seatbelt mounting points.
Old 06-03-2013, 04:49 PM   #6
mla163
Overthinking it
Drives: BRZ in CS
I may be wrong, but I thought that any 4 point or 5 point harness without a full roll bar was a no-no. The reason being if the car flips, a regular seat belt will let you buckle over; a 4/5 point will keep your head in place while it is pile driven into the ground.
Even if you had a cage, you want to mount it properly, the child safety anchors are for child seats. Although, in my WRX I had a 3-point mounted there for autocross only. I would never use it for track / driving on the street.
mla163 is offline   Reply With Quote
Old 06-03-2013, 05:03 PM   #7
kurbkilla
kurbkilla's Avatar
I did it the right way before with a roll cage on my last car and it caused problems with the interior. Granted i did a lot more but i would like to leave the inside stock but still feel held in place.
Old 06-03-2013, 05:06 PM   #8
kurbkilla
kurbkilla's Avatar
I did see, i guess, a 3 point harness with out a bar. Which is why i ask
Old 06-03-2013, 05:34 PM   #9
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
OK, so about a month ago, I was convinced that a Schroth with ASM was the way to go. Then I did research and posted about it. Then I was schooled.
Saw some photos from crashes. NOT GOOD! Harness bars are not roll cage bars. They can move A LOT in a crash. If a harness bar moves forward a foot, your belts slip over and god knows where you're going to end up, but probably submarined or out the window. Definitely in pieces. Anchoring to the child seat tether won't work since you weigh far more than those anchors are designed for. Anchoring to the seatbelt anchor won't work because the angle is wrong.
So like a couple others said: Go big or go home. Either use the stock safety system completely or put in a 5/6 six point seat, belt, and cage. I'm not even sure if a half-cage is a good idea at this point. If you really want a wholehog track car, I'd buy a Formula something or other. It'll be faster more fun, uncompromised, and allow real racing. It might even be cheaper in the long run.
And of course, if you put in a full cage, you'll need a helmet on the street.
Old 06-03-2013, 05:55 PM   #10
D1cker
Drives: B9 S4/ND2
If you're not putting a roll bar with a race seat in the car, and wearing a hans device, leave the stock belts, you'll be safer.
D1cker is offline   Reply With Quote
Old 06-03-2013, 06:06 PM   #11
CSG Mike
CSG Mike's Avatar
This is one of those "all or nothing" situations. Doing it half-assed will do more harm than good.
Old 06-03-2013, 06:07 PM   #12
mla163
Overthinking it
Drives: BRZ in CS
If you want to be a little more snug, pick up a CG lock.
http://www.cg-lock.com/
While I like the feel of a 5 point harness in a race car, it's ridiculous (and probably illegal) in a street driven car. IMO, for a race car, it's all or nothing.
The Following User Says Thank You to mla163 For This Useful Post:
DjDATZ (03-25-2015)
Old 06-04-2013, 03:16 AM   #13
kurbkilla
kurbkilla's Avatar
Thanks all for the help I'll leave it as is.
The Following User Says Thank You to kurbkilla For This Useful Post:
EAGLE5 (06-04-2013)
Harness Bar diirk Tracking / Autocross / HPDE / Drifting 38 07-21-2017 02:15 PM
Cipher Racing 5 Point Quick Release Racing Harness 5 COLOR Tubano-shop Interior Parts (Incl. Lighting) 2 05-27-2013 08:36 AM
FS: BRZ engine harness Fenrir Engine, Exhaust, Bolt-Ons 2 05-17-2013 03:04 PM
FS: Sparco 4-Point Racing Harness JPxM0Dz Canada Classifieds 2 01-12-2013 01:10 PM
Wiring harness sastexan Electronics | Audio | NAV | Infotainment 0 06-17-2012 12:41 AM
