CANADA Canada
Old 05-31-2013, 10:54 PM   #1569
roddy
roddy's Avatar
Drives: '13 Ultramarine
I'll cruise up for a bit. What time do you plan on getting there?
Old 05-31-2013, 11:55 PM   #1570
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
I would try to keep it under -2, maybe 1.8 or 1.9?
The other thing I did not mention is that I kinda cheated a bit on the camber bolts, as I dremeled (sp?) the hole by another 2mm to give me more camber.
So you may be very close to the ideal camber once those two are installed.
What are you aiming at for toe settings?
Slick is offline   Reply With Quote
Old 06-01-2013, 09:09 AM   #1571
FRS_Ken
((•||=(86)=||•))
FRS_Ken's Avatar
Drives: '13 FR-S Ultramarine 6AT; '13 Yaris
Sorry I had to go at 10:00 last night - I went to see F&F6 at the Collesium.
I was worried about the parking but I found a nicely-lot corner spot and my buddy backed me up on the other side
Lots of action in the movie pretty much just like the trailers pretty wild and you have to leave reality at the door lol
Interesting that they filmed a lot in London
Gina Careno is in it - she can't act but she's easy on the eyes and has some wicked fight scenes
We paid the $14 AVX (?) to see it - I hadn't been to a movie for years so I guess it was worth it but I wouldn't want to do that too often ($$$$)
So I'll simply give it a 'thumbs up' it was a fun 2hours
FRS_Ken is offline   Reply With Quote
Old 06-01-2013, 01:55 PM   #1572
Slick
Slick's Avatar
I don't know. What do you have / recommend? Thanks!
For toe, try going with:
1/8" toe OUT on front (total, not per side) (roughly 0.20 in degrees)
Some recommend zero toe all the way around but I like a bit of toe-out on the front as it helps with turn-in. Plus it will be a bit more stable and not too darty.
Zero toe on rear
You could also go with 1/16" of toe-in on the rear to make it more stable as well. Just make sure there is no toe-out on the rear.
Phil will do a great job for you at CTC Carling (& Ralf too of course but request Phil to do the work).
Oh, and Phil would probably know this, but make sure you go to Maximum Caster as well.
Old 06-01-2013, 11:19 PM   #1573
RoryTate
Drives: 2013 Subaru BRZ
Drove through a little rain outside of Casselman tonight.
[ame="http://youtu.be/Wu5j12nvkho"]http://youtu.be/Wu5j12nvkho[/ame]
Rain was so hard that the HVAC developed a leak on the passenger side. Filled a large McD's cup in about a half hour.
RoryTate is offline   Reply With Quote
Old 06-01-2013, 11:54 PM   #1574
FiRStsc10n
Canadian FR-S Member
FiRStsc10n's Avatar
Drives: FR-S '10 Series'
Forgive me if this noob question, is this a reoccuring issue? [Looking to purchase FR-S] I searched forum and found nothing relating to HVAC leaks. I've had leaks before in my HVAC on a previous vehicle but it was due to a clog in the AC drainage line and it backed up and caused leak into the passenger footwell area.
FiRStsc10n is offline   Reply With Quote
Old 06-02-2013, 12:16 AM   #1575
Slick
Slick's Avatar
Very strange, never had it leak before.
Btw, you need more RainX....
Old 06-02-2013, 12:26 PM   #1576
RoryTate
I've read about it here once before, and under similar circumstances if I recall correctly. I believe it was a case of too much water and the drain was unable to keep up.
Old 06-03-2013, 02:54 AM   #1577
brz2013
brz2013's Avatar
Drives: 2013 wrb brz
Go the fa20club stage 2 tune and a map for e85... First tank tomorrow...big gains from e85 I've heard
brz2013 is offline   Reply With Quote
Old 06-03-2013, 11:28 AM   #1578
vignesh
Engineer
vignesh's Avatar
Drives: WRB 2022 Subaru Brz
Any reason why the borla headers much cheaper than other headers on the market
Sent from my SAMSUNG-SGH-I747 using Tapatalk 4 Beta
2022 BRZ WRB 6MT
2018 Camaro ZL1 1LE
vignesh is offline   Reply With Quote
Old 06-03-2013, 11:40 AM   #1579
brz2013
brz2013's Avatar
Didn't know they were.... But I'm happy with them and borla generally makes a quality product.....may be cheaper because they are cattless
Old 06-03-2013, 06:12 PM   #1580
brz2013
brz2013's Avatar
Running my first tank of e85 on the fa20 tune...wow what a difference!!
Old 06-04-2013, 08:04 PM   #1581
GodDamage
GodDamage's Avatar
Drives: Black Subaru BRZ
Please be careful when running e85, I am seeing a lot of issues with consistent e85 use (the fuel filter cant handle it long term and will deteriorate)
GodDamage is offline   Reply With Quote
Old 06-04-2013, 08:32 PM   #1582
brz2013
brz2013's Avatar
read this http://www.wotauto.com/2013/01/02/sc...-e85-visconti/
brz filter and pump ready for e85 from factory
