Old 05-31-2013, 02:50 PM   #1
monkeyslide17
monkeyslide17's Avatar
Drives: frs
Question Down shiffting from 6 to 5?
Hello you guys new and first time post.
Is anyone having any type of problems when down shifting from 6 to 5? every time I down shift, it grinds. So far I have just said screw it and just gone from 6 to 4, but of course not over reving. can anyone chime in on this.
Thoughts, words. Thanks
monkeyslide17 is offline   Reply With Quote
Old 05-31-2013, 02:51 PM   #2
engee
Drives: Subaru
Have you been rev matching? I experience no problems downshifting from 6th to 5th.
engee is offline   Reply With Quote
Old 05-31-2013, 02:52 PM   #3
naikaidriver
Drives: 2013 Scion FR-S AT Asphalt
Try using the pedal that is furthest on the left.
Scott
naikaidriver is offline   Reply With Quote
The Following 23 Users Say Thank You to naikaidriver For This Useful Post:
4Running Daily (05-31-2013), AZOOZ_95 (06-01-2013), BabyPubes (05-31-2013), BRZerk (04-25-2014), Clembo (06-01-2013), Enraged21 (05-31-2013), finch1750 (04-24-2014), jstans84 (05-31-2013), Kimsey47 (05-31-2013), Mandy (06-01-2013), Marchy (05-31-2013), monkeedoo (04-24-2014), Mr.Jay (05-31-2013), OrbitalEllipses (05-31-2013), oxygen (05-31-2013), radroach (05-31-2013), raul (06-01-2013), RT87 (05-31-2013), RWD_FR-S (06-01-2013), rxpx2012 (04-24-2014), SkAsphalt (04-25-2014), Sportsguy83 (05-31-2013), Turbo95eg6 (04-24-2014)
Old 05-31-2013, 02:58 PM   #4
monkeyslide17
Drives: frs
yes on the rev matching. engee
Old 05-31-2013, 03:06 PM   #5
cfusionpm
Drives: Firestorm 6MT Scion FR-S
I skip gears often. Unless I need a constant connection to the drive line or want to engine brake efficiently, I'll jump from 6 to 4 to 2. I'll also jump up from 3 to 5, 2 to 4 to 6, whatever. That's the nice thing about an H-shifter, you can just put it where you want it and not need to run through them like an auto or sequential. As long as I'm not bogging the car going up hill or something, this works well on flat ground and down hills for daily driving.
2013 Firestorm 6MT Scion FR-S
cfusionpm is offline   Reply With Quote
Old 05-31-2013, 03:15 PM   #6
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Well if it grinds everytime something's wrong. Go to the dealer and make them drive it and they should fix it.
Rayme is offline   Reply With Quote
The Following User Says Thank You to Rayme For This Useful Post:
virobloc (06-01-2013)
Old 05-31-2013, 03:18 PM   #7
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
With the clutch fully in it should NEVER grid 6th to 5th regardless of whether you are rev matching or not.
Something is definitely wrong and I'd have the dealer look at it if it's happening all the time.
If it's intermittently doing it, is harder because things always seem to clear up when you go to show someone haha
Sent from my Nexus 4 using Tapatalk 2
Nolan
pheoxs is offline   Reply With Quote
The Following User Says Thank You to pheoxs For This Useful Post:
Old 05-31-2013, 03:32 PM   #8
Enraged21
#RememberTheBuster
Enraged21's Avatar
Drives: Firestorm FRS MT
There's been a lot of arguments about screwing up the syncros when shifting like that. Usually the proper method to do it is like:
4th gear
clutch in
put it in 5th gear
put it in 6th gear
clutch out.
And supposedly that'll save your syncros.
I'm not a mechanic or anything. I've just read this multiple times in different places.
Enraged21 is offline   Reply With Quote
The Following 3 Users Say Thank You to Enraged21 For This Useful Post:
burnt toast (05-31-2013), Hot Lava (04-25-2014), Sonolin (05-31-2013)
Old 05-31-2013, 05:21 PM   #9
cfusionpm
Did it for 8 years in a tC, no issues with the transmission there. If it messes something up I haven't encountered it in nearly a decade.
The Following User Says Thank You to cfusionpm For This Useful Post:
6speed_Sam (05-31-2013)
Old 05-31-2013, 05:26 PM   #10
thill
This...
Old 05-31-2013, 05:26 PM   #11
Raven604
I'll often start in 1st and skip 2nd when driving like a grandma or start in 2nd when rolling and skip 3rd
Raven604 is offline   Reply With Quote
Old 05-31-2013, 05:27 PM   #12
OrbitalEllipses
Drives: Attitude
But you did stay at a Holiday Inn last night.
The Following 5 Users Say Thank You to OrbitalEllipses For This Useful Post:
Laika (05-31-2013), SkAsphalt (04-25-2014), soundman98 (04-24-2014), Sportsguy83 (05-31-2013), UMB FR-S (05-31-2013)
Old 05-31-2013, 06:56 PM   #13
Takuro
It seems like a majority of FRS owners are first time manual transmission drivers.
Takuro is offline   Reply With Quote
The Following 3 Users Say Thank You to Takuro For This Useful Post:
B3yondL (04-24-2014), Propaganda (04-24-2014), Pseud0logik (04-24-2014)
Old 05-31-2013, 08:06 PM   #14
FRiSson
Drives: FR-S MT
Only 5% of transmissions sold in the U.S. are manuals, so what do you expect?
FRiSson is offline   Reply With Quote
