Old 05-30-2013, 11:30 PM   #141
sierra
Drives: Skoda Yeti DSG diesel 4x4
Originally Posted by ATL BRZ View Post
The issue is the direct injector seals failing due to detonation between up shifts because the transient ignition retard tables are not optimized (flawed) in the factory ecu tune. 91 octane gas and lots of heat in the block on track increases the risk of said detonation. The seals fail, cylinders run dangerously lean and boom.
I don't know how many times this needs to be repeated before people stop speculating otherwise...
Thanks for that info.
Another interesting point. Is this engine is designed for E10 or did they decide it should be alright from the spec? My car states on the filler cap 98 RON only. On my mates 2013 Ford Fiesta is says 91RON or higher and E20 compatible[something like that]. So why isn't the FA20 suitable for any ethanol in Oz but it is in the US?
sierra is offline   Reply With Quote
Old 05-30-2013, 11:31 PM   #142
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
Originally Posted by P@ul View Post
Someone has already downloaded the previously mentioned new ECU calibration that specifically identified the change in transient retard tables, extending the original 5,600 rpm all the way out to 10,000 rpm. http://www.ft86club.com/forums/showp...3&postcount=67
Hence, NO speculation.
You are speculating that our ECU mapping doesn't already account for this. If you haven't noticed, this isn't South Africa.
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
Old 05-30-2013, 11:35 PM   #143
Opie
Opie's Avatar
Don't be so quick to make legal or factual determinations, you've been wrong before...
And I'm not afraid to admit it if I am, unlike 99.999999% of everyone else here.
Old 05-30-2013, 11:36 PM   #144
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by ahausheer View Post
Lots of semantics going on. All race engines will die at some point we all know this. It is not reasonable to think you can race/track your car all you like and then keep ordering new engines when it breaks. Don't mean to be condescending but it is their right to deny a warranty claim due to race conditions or abuse.
A car that has been tracked a lot will need a rebuild earlier, sure. However, it shouldn't need one in 20,000 miles or so given that it's a stock engine we are talking about.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
ATL BRZ (05-30-2013)
Old 05-30-2013, 11:44 PM   #145
Opie
Opie's Avatar
Originally Posted by FirestormFRS View Post
The Act makes it easier for purchasers to sue for breach of warranty by making breach of warranty a violation of federal law, and by allowing consumers to recover court costs and reasonable attorneys' fees. This means that if you lose a lawsuit for breach of either a written or an implied warranty, you may have to pay the customer's costs for bringing the suit, including lawyer's fees.
I was referring to the earlier mention of the Magnussen-Moss Act that keeps getting brought up, this Act refers to the use of aftermarket replacement parts and their effect on warranty coverage, none of which applies to this case from what I've read since no one is denying warranty due to a replacement part.
Quoted from FTC.gov. Refusing to replace the engine if it is found to be a manufacturing defect would constitute a breach of written warranty.....
Correct, assuming it's a manufacturing defect. If this were the case, I doubt Subaru wouldn't waste the time fighting it.
Old 05-30-2013, 11:48 PM   #146
Opie
Opie's Avatar
I agree it "shouldn't", but I've also seen new STI's that "shouldn't" need a new clutch after only 2,000 miles either but did...Not due a defect, due to the loose nut behind the wheel.
Of course the nut cried warranty all over the place too...
Old 05-31-2013, 12:10 AM   #147
Lonewolf
Lonewolf's Avatar
Drives: Moped
Okay, so that means you're the only one...lol
Old 05-31-2013, 12:12 AM   #148
Lonewolf
Lonewolf's Avatar
Drives: Moped
The Magnusson-Moss WARRANTY Act goes far beyond that...jeezus, just stop posting, lol
Further, manufacturers fight recognizing and admitting to manufacturing, design, and assembly defects all the time...look up the Ford Pinto and the Firestone tire fiasco...looks like another swing and a miss
By the way, I am a licensed attorney unlike 99% of the people here...(pssst, that means you)
The Following 2 Users Say Thank You to Lonewolf For This Useful Post:
fuddbutter (06-01-2013), SkullWorks (05-31-2013)
Old 05-31-2013, 12:15 AM   #149
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Of course. However I don't see much evidence of excessive user abuse in this case. Unless you know something the rest of us don't...
I've seen engine, trans and clutch failures on other brands in the 20-50k mileage range, I don't know anyone who's had that denied due to track use (vs misshifts, etc).
Nate's ITR went to the dealer with track numbers on it, 49,xxx miles, cage, etc with a bad clutch, replaced no questions asked. Craig's motor went at 10k, spun a bearing, determined that it was an issue despite the cars track usage, replaced without an issue.
The problem here, IMO, is that it doesn't seem like Subaru is even willing to really determine what happened. If it was the DI injector seal problem then they should cover it. If it was a misshift, they should not.
The CSG car is a tracked car, it's not a race car though.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following 2 Users Say Thank You to Dave-ROR For This Useful Post:
SkullWorks (05-31-2013), WolfpackS2k (08-20-2013)
Old 05-31-2013, 12:24 AM   #150
dsgerbc
Drives: BRZ(sold), STI
unlike 99.999999%
Too many nines, sir.
There are only 20 thousand members here.
The Following 2 Users Say Thank You to dsgerbc For This Useful Post:
fuddbutter (06-01-2013), strat61caster (05-31-2013)
Old 05-31-2013, 12:24 AM   #151
Frozen_skidmark
Frozen_skidmark's Avatar
Drives: Whiteout FRS
Take a look at the list people with the idle problem in this thread - and take a look at the amount of catastrophic engine failures. Obviously there is catastrophic problem with this engine, whether it's driving your ass to work or at autocross.
http://www.ft86club.com/forums/showthread.php?t=15577
This is the lawyer that launched the class action lawsuit against Kia for gas mileage overstating and won.
http://www.doylelowther.com/
In the mean time enjoy the Scion Racing page: where you can sign up to participate in racing events with your brand new Scion FRS! Yay!
http://www.scion.ca/scion/en/lifestyle/racing
or Scion Track Day at Shannonville Ontario: organized by hmmmm Scion, come try our cars at the track and then go buy one because they're awesome on a track.
http://www.scion.ca/scion/en/vehicle...ille-track-day
Read the Scion RACING AGREEMENT here:
http://s3.amazonaws.com/scion.site.p..._waiver_en.pdf
I would suggest some screen shots for future reference. Before these pages disappear.
Wink, wink,
Clay
Frozen_skidmark is offline   Reply With Quote
The Following User Says Thank You to Frozen_skidmark For This Useful Post:
CSG Mike (05-31-2013)
Old 05-31-2013, 09:23 AM   #152
Hindi
Hindi's Avatar
Drives: Frs
Bad Luck twins.
-Robert
Hindi is offline   Reply With Quote
Old 05-31-2013, 10:42 AM   #153
Mikem53
Drives: FR-S 6MT
When I bought my Z06.. It came with a DVD explaining how to lower the car for the track and to add an extra quart of oil before tracking it and other tips.. Etc..
This was from the manufacturer.. Yet the warranty states that the warranty is void if the car is used on the track or any kind of racing event..
Amazing how they tell you it's made for the track, how to use it on the track... But forget the warranty if something breaks... That's like bait and switch...
Back to the statement... If you wanna play... Your gonna pay..
Mikem53 is offline   Reply With Quote
Old 05-31-2013, 10:43 AM   #154
xjohnx
Grip>Slip
xjohnx's Avatar
@CSG Mike - Have you considered going the Jalopnik/Autoblog route yet?
We Ask Toyota & Subaru about James May's Claim that Toyota Gets 90% of GT 86/FR-S/BRZ vh_supra26 Scion FR-S / Toyota 86 GT86 General Forum 94 09-15-2013 09:55 PM
Denied service... Chen Northwest 37 09-13-2013 09:37 PM
HELP with diminished value claim! zohare Scion FR-S / Toyota 86 GT86 General Forum 41 04-03-2013 12:17 PM
Hit and Run Insurance Claim CharlieChaos Off-Topic Lounge [WARNING: NO POLITICS] 9 12-26-2012 09:54 PM
Japan loses its claim to "Creepiest Asian Country" reni Off-Topic Lounge [WARNING: NO POLITICS] 3 05-08-2012 12:57 AM
