Old 05-28-2013, 11:15 AM   #15
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by track_warrior View Post
This was the cause of my engine failure. I really hope there is a recall for this as its dangerous and could cause complete engine failure like in my car. Im seriously considering parting out my car and selling.
So you went lean and boom?
Old 05-28-2013, 08:02 PM   #16
track_warrior
Track Junkie
track_warrior's Avatar
Drives: Faster than the Stig!
Correct i got a check engine light then it went away in the middle of the session around 1 min later the car went into limp mode and the engine was done. Apparently the heat is what is causing these injectors to fail.
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
track_warrior is offline   Reply With Quote
The Following 4 Users Say Thank You to track_warrior For This Useful Post:
ATL BRZ (05-30-2013), ill86 (06-19-2013), SkullWorks (05-28-2013), Sportsguy83 (05-28-2013)
Old 05-28-2013, 08:20 PM   #17
OrbitalEllipses
Drives: Attitude
Wasn't your engine covered, why part out?
Old 05-28-2013, 08:39 PM   #18
peachch
Drives: White 86 Sport Plus
Originally Posted by whitefrs View Post
how hard was to remove the intake manifold?
so a newbie can do this?
do we really need the sst tool or no?
Remove manifold is not hard, but you need SST to put the seal in. I did not have SST either. So it took time to put the seal in.
peachch is offline   Reply With Quote
Old 05-28-2013, 10:03 PM   #19
Ozzman
Drives: old
What is the SST?
Ozzman is offline   Reply With Quote
Old 05-28-2013, 10:21 PM   #20
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
This thread has gotten me worried!
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 05-28-2013, 11:00 PM   #21
peachch
Originally Posted by Ozzman View Post
What is the SST?
Special tool that Toyota recommend to use for putting seal in. It is on the service manual.
Old 05-28-2013, 11:01 PM   #22
track_warrior
Track Junkie
It got covered but i did get warned it was only going to get covered once. Im starting to worry that they wont do a recall on this and i will be going through engines every 4k miles. Hopefully they figure this out.
Old 05-28-2013, 11:49 PM   #23
Lonewolf
Lonewolf's Avatar
Drives: Moped
Originally Posted by ae86stunt View Post
If this is a common occurrence. Fuel system related, will definitely become a recall.
(ASE tech, State Inspector)
The tsb/recall process could be sped up if people filed complaints with the NHTSA. You need to create a paper trail with adequate documentation before most companies begin to even take notice...
The Following User Says Thank You to Lonewolf For This Useful Post:
yuicebox (07-07-2013)
Old 05-31-2013, 03:58 PM   #24
ToyotaTech805
Drives: Lexus
I am a Toyota tech I just replaced these seals on a customer car. #1 Teflon seal was missing/burned off. I would recommend you use special service tool, seal does get stretched on installation special tool helps to install correctly.
ToyotaTech805 is offline   Reply With Quote
The Following 4 Users Say Thank You to ToyotaTech805 For This Useful Post:
CSG Mike (05-31-2013), EL7 (06-20-2013), ill86 (06-19-2013), Spartan65 (06-12-2013)
Old 05-31-2013, 04:31 PM   #25
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
How can we get the special tool
How hard is to do this job
Sent from my HTC One using Tapatalk 2
Old 06-02-2013, 02:39 AM   #26
shellslinger
Drives: Whiteout FRS
All you folks with this problem, when did you guys buy your FRS/BRZ?
shellslinger is offline   Reply With Quote
Old 06-02-2013, 03:49 AM   #27
Marrk
Drives: Honda Fit
How many FR-Ss does your dealership service? What percentage had this problem?
Rough estimate is fine.
Marrk is offline   Reply With Quote
Old 06-02-2013, 12:57 PM   #28
FT_Monk
Drives: Over the hill WRX
Normally how many cylinders have seal missing or burned off? If only a specific location has the problem then it is maybe some source of manufacturing defect; other wise this is worry some. This car has so many problems!
FT_Monk is offline   Reply With Quote
Injector / seal failure or Miss-fire codes.. please post here mad_sb Engine, Exhaust, Transmission 378 04-24-2020 07:33 PM
FRS-BRZ Port Fuel Injector (interesting) Element Tuning Engine, Exhaust, Transmission 50 04-21-2016 05:26 PM
Direct Injector's Leaking Carwhisperer Scion FR-S / Toyota 86 GT86 General Forum 1 05-11-2013 10:31 AM
Leaking Oil? 636 Issues | Warranty | Recalls / TSB 11 01-05-2013 05:43 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Injector Dynamics ID850s! Dustin@Dynosty Engine, Exhaust, Bolt-Ons 0 08-21-2012 06:03 PM
